Replacement Hand Grips for a 2006 Lt - BMW Luxury Touring Community
post #1 of 7 Old Jun 18th, 2006, 9:59 am Thread Starter
Tarkusny's Avatar
Hi folks,
I'm planning a cross country run ( I have 3 days to get from Eastern NY to Vail, Co) on a 2006 LT. I would like to replace the original heated hand grips with a larger set. I haven't seen anyone advertising them. Can someone recommend a set?
Also, I have a 29 inch inseam, any recommendations on highway pegs (bike has the comfort seat) would be appreciated as well.
I'm scheduled to leave in the middle of July.
Any other recommendations would be welcome as well.
-cg
Tarkusny is offline
post #2 of 7 Old Jun 18th, 2006, 10:14 am
Several of us have used tennis racket grip tape. Goes on easy and provides a good cushion. Still lets the heat through when you need it. You can wrap it in a barrel shape for improved comfort.
post #3 of 7 Old Jun 18th, 2006, 11:28 am
DavidTaylor's Avatar
Originally Posted by Tarkusny
Hi folks,
-cg
The heated drips from the R1200 CL can be put on the LT. The grip is larger in circumference and lots of folks have changed to them with no troubles.
As for highway pegs, I would recommend the standard Jpegs. I've used Jpegs (standard and XL) on all three of my LTs and wouldn't take long trips without them.
David Taylor
San Jose, CA
2010 R1200RT Polar Metallic
AMA, BMWMOA
Booze Brother #4
DavidTaylor is offline
post #4 of 7 Old Jun 18th, 2006, 10:48 pm Thread Starter
Tarkusny's Avatar
Jpegs
Thanks for the replies, it's appreciated. I'm surprised that some aftermarket grips don't (or at least I haven't found them) exist.
I installed the lowering kit from Suburban, and they are a excellent. I put a few miles on the bike today, and it was the first time my leg muscles didn't get stressed from the tight seating position. I've tried the seat in the lower and up position, however it didn't really help with my legs getting cramped. However, the Suburban Kit made the seating position comfortable for a few more hours then the stock peg location.
How difficult is the installation of the JPEGS?
Tarkusny is offline
post #5 of 7 Old Jun 19th, 2006, 6:02 am
Tomakazie's Avatar
I too have a 06 LT.. The Surburban peg lowering kit does work. I installed both the Surburban pegs and the Jpegs XL in aprox 2 hours. I did take the advice from many LT owners who have installed the XL Jpegs. They say once you have drop your ride (not yet for me) the Jpeg pokes a hole in the fiberglass due to the soft compound of the bolts holding the peg . Many people have taken a dremel tool and cut a small opening in the fiberglass. You would not know it was not factory, looking at it. This seemed to be better than the peg making it's own hole. To each their own. Both really help in the long ride.
Good luck
Tom & Donna
2006 BMW K1200LT
Unigo Trailer
Albuquerque, New Mexico
Tomakazie is offline
post #6 of 7 Old Jun 20th, 2006, 11:51 pm
dmatson's Avatar
Another consideration is the Highway Ottomans. I really like mine, I have an inseam of 30", here is a pic from last weeks 5 day trip.
14' KTM 1190
03' KTM 450 EXC Dually
72' Honda SL 100
67' Triumph Bonneville
65' Honda CB160
70' Honda CB350
dmatson is offline
post #7 of 7 Old Jun 21st, 2006, 6:54 am Thread Starter
Tarkusny's Avatar
Good luck
Is that a problem only with the XL JPEGS? Or do both the standard and the XL have the issue with poking a hole into the fiberglass?
-cg
Tarkusny is offline
Press release: BMW Navigator III will arrive in April 2006 ģwin GPS 18 Feb 12th, 2008 7:18 pm
Trade up from a 2000 to a 2006 avidude K1200LT 8 May 8th, 2006 7:40 am
800cc Ducati MotoGP Bike Breaks Cover May 2006 Patric Chit Chat 2 May 2nd, 2006 5:56 pm
Need replacement Xenon bulb for 2006 LT Scotter Lighting 23 Jan 31st, 2006 12:16 pm
