Battery Draining after iPhone Charger Installed - BMW Luxury Touring Community
post #1 of 5 Old May 4th, 2014, 6:23 pm Thread Starter
Here are the details:
2008 K1200 GT purchased from BMW of Ventura in Oct of 2013
Original OEM Battery failed 2 months later, replaced with the Odyssey PC 680 Battery. All good for 14 months.
Then I had the dealer BMW of Ventura install a powerlet iPhone 5 battery harness in March of 2014. This was to deliver power to my iPhone mounted in a ZTechnik holder. All worked perfectly for 2 months.
This weekend I return (begin away from the bike for 4 weeks), I have dead battery? Now, I jump the battery and recharge it. As I am recharging the bike again, I plug in the iPhone and go riding. About an hour into the drive, the iPhone signals that it is low on battery? I've got it plugged in? WTF?
Now the BMW service team told me that with the powerlet battery harness I cannot leave the iPhone plugged into the power while the engine is off because it will run the battery down. OK. I get that. But can the power harness somehow draw down the battery just sitting there with nothing connected?
Any help?
RubioRyder is offline
post #2 of 5 Old May 4th, 2014, 7:46 pm
Re: Battery Draining after iPhone Charger Installed
Yes, it's possible.
What the harness does is convert the bike's normal 12Vdc down to the 5Vdc that the iPhone needs. That internal circuitry can still draw some small amount of power even when the iPhone is not plugged in.
Is this the harness that they installed, with a direct-to-battery hookup?
A power harness like that needs to be installed on a switched circuit that goes completely dead when the key is off. You can use an existing CanBus switched circuit (like the GPS plug or extra power port plug), but sometimes that extra draw tricks the CanBus into keeping that port open longer (like it does for the CanBus battery charger). This can run down your battery, even with the key off.
A second choice is to use a relay that's only switched on when the key is on (and even better, only when the engine is actually running). This is a slightly more complicated (and thus slightly more expensive) install.
The best option is to add a separate fuse block that has relay switched circuits that go completely off when the key is off. This also adds expense, but is the best solution, especially if you want to add additional accessories (GPS, lights, heated gear, etc.).
'13 Dark Graphite Metallic K16GTLD, 24K miles and counting...
'09 Magnesium Beige Metallic K13GT, 63K miles miles and counting...
All lower 48 states plus Alaska on the K13GT in two weeks . . .
post #3 of 5 Old May 5th, 2014, 8:37 am
Lynn_Keen's Avatar
For what it's worth, not sure why but I've had good luck charging multiple devices over night using the bike battery with no problem. I have a SENA head set, an SR10 two way radio adapter, and a Bluetooth transmitter connected to the rear radio speaker circuit. I use a multi point USB connector plugged into a 12 v outlet connected directly to the battery to charge all three devices over night. Used this set up many times on extended trips and so far have had no battery issues.
Lynn Keen
North East Florida
MSF #28271 Retired
'01 R1150 GS- totaled
'02 R1150 GS sold
'85 K100/EML sidecar sold
Lynn_Keen is offline
post #4 of 5 Old May 5th, 2014, 9:54 am
deanwoolsey's Avatar
Ken is correct. A voltage supply which does not have a switch on it (whether it's a DC rectifier or an AC transformer) will draw power all the time. The amount it draws will vary with the load, but it'll normally kill your battery in a week or less.
Another good way to visualize this is to understand that the LT has a 19 amp hour battery. You get one amp for 19 hours or 19 amps for one hour and it's dead. A tenth of an amp gets you 190 hours. A hundredth of an amp gets you 1900 hours or less than three months before your battery is completely dead. S0... a few hundredths of an amp isn't much, but it'll kill your battery in a week or two when you add it in to what the memory section of the engine controller draws.
Like Lynn I charge things overnight and have had no problems, but the power supply does not remain attached after the I-pod is unplugged.
deanwoolsey is offline
post #5 of 5 Old May 5th, 2014, 10:36 am Thread Starter
Yes, this is exactly the assembly they put on the bike. Ok so I need to have a separate fuse block installed. got it. Thank a lot. Really!
Reed
Tags
dead battery-iphone plug?
Battery Charger cfmpilot K1200LT 5 Jan 9th, 2008 5:34 pm
New Battery Installed hschisler K1200LT 11 Aug 27th, 2007 3:41 am
'05 Lt Battery And Recharging With An Electronic Low Amps Tender ajs K1200LT 2 Apr 9th, 2007 10:11 am
Dead battery and car charger TimVipond K1200LT 3 Jan 7th, 2006 7:27 pm
