Charging Via The Rear Jack? - BMW Luxury Touring Community
post #1 of 5 Old May 2nd, 2006, 2:51 pm Thread Starter
Sorry if this question has been asked before - I'm new here.
Over the last few years I have routinely plugged my Battery Teder Plus into the rear power accessory jack of my 2002 K1200LT-C using a cable I built with the BMW connector.
This past weekend, my local dealer told me that the rear jack should not be used for this as it does not pass power back to the battery - I'm guessing he's suggesting there's a diode on there somewhere. He said that the charger should only be connected to the front jack.
Using the rear jack has always seemed to work just fine.
He also said that the Battery Tender Plus was not the best choice as the battery on my bike is 13.8V and the BTP is only putting out 12V. Again, I've been using this charger for 3 years and have never had any issues. I'm just curious.
Can anyone confirm or deny this information?
Matt
2002 K1200LT-C
m_salerno1 is offline
post #2 of 5 Old May 2nd, 2006, 2:58 pm
motorhead's Avatar
So if it's been working why give credit to the dealer knowing more than you ?
The rear jack while maybe not a dirrect connect to battery and not able to run high current, will tackle low current trickle charge duty just fine.
IMHO.
Scott
Our "semi" quiet riot
*** Trailer Too ***
T
wisties Required
motorhead is offline
post #3 of 5 Old May 2nd, 2006, 3:20 pm
BLBantz's Avatar
I've used mine for two years now through the rear jack. The lights on the charger indicate it is recognizing that a battery is present, hooked up properly and then goes into the appropriate charge cycle, either full charge, 80% trickle or monitoring. I don't think it could do all of this if it was not connected to the battery. Like the others have said, I'd stay with it.
Brian
Fanwood, NJ
2003 K1200LT Anthracite
BLBantz is offline
post #4 of 5 Old May 2nd, 2006, 5:08 pm
Rockdoc's Avatar
The rear socket is linked through the ignition switch so if you lock the steering you'll isolate the socket. While the switch is in the accessory position it will charge the battery just fine. The front socket seems to be always on so I guess your dealer's about half right.
Keith
UK 2004 K1200LT Lux - Katie
Rockdoc is offline
post #5 of 5 Old May 3rd, 2006, 9:47 am
eatanner's Avatar
Dave, have you used your solar unit as a trickle charger while the bike is setting still? I seem to remember you using it as a supplemental charger while traveling. Any details?
I've charged the LT battery using front & back acc plugs with no issue.
Trust your experience.
Edgar Tanner
2009 Piaggio MP3 500
2003 Titan Silver LTC (Angel-returned to the heavens)
2000 Basalt LTC (Down for the count)
Kansas City, MO 64153
eatanner is offline
Very specific wiring question - Rear Speakers midwilshire Intercom, CB, & 2-Way Radios 11 Nov 21st, 2011 4:37 pm
Loose Rear Wheel thalpin K1200LT 15 Apr 13th, 2006 1:47 pm
'05 LT OEM Front/Corbin rear seats ajs K1200LT 2 Apr 8th, 2006 9:49 pm
Replacement of rear shock suspension unit PhillWard Australia, New Zealand, and AsiaPac 3 Jan 17th, 2006 5:01 pm
