Starter Relay Problems - BMW Luxury Touring Community
post #1 of 6 Old Jun 23rd, 2011, 11:26 pm Thread Starter
Richco's Avatar
About 6 Months ago I had the starter relay replaced on my 2002 K1200LT Trike. It was not cheap. They put in a kit with the newer style starter relay. Well I am having the same problem. The bike won't start. All I hear is a light click from what I assume is the starter relay. The bike was stored in the garage for about 2 months (Due to illness). I had an automatic trickle charger on the 6 month old Gel Cell Battery. When I measure the voltage of the battery, It shows 12.6 before turning on the ignition. With the ignition on (Including the lights), the voltage drops to a little over 11 volts. Then hitting the starter button makes no difference in the Voltage.
Any ideas?
Richco is offline
post #2 of 6 Old Jun 24th, 2011, 1:40 pm
Razmataz's Avatar
Re: Starter Relay Problems
Me thinks you need a new battery. I'm pretty sure its supposed to be about 13.2 or so. The gurus will confirm or deny.
BMW 1200 LTC 2002
Razmataz is offline
post #3 of 6 Old Jun 24th, 2011, 3:07 pm
Gold Supporter
Any ideas?
Try jumping the battery to be sure, if the voltage is low the relay will not pick. If the relay is bad again it should all be under warranty.
Jim Davidson
2007 R1200RT
hp1bmw is offline
post #4 of 6 Old Jun 24th, 2011, 3:52 pm
johnbaker15's Avatar
Richo,
Don't know if this helps much but mine measures 13.5 key off and 11.8 key on. It's an 2005. I would try a full overnight charge, not the trickle charger and try again.
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
johnbaker15 is offline
post #5 of 6 Old Jun 24th, 2011, 6:24 pm
Originally Posted by johnbaker15
Richo,
Yours is also marginal.
The, not fresh off a charger, sit over night, terminal voltage on a good fully charged 12V battery should be around 12.6 to 12.8 volts. With the key on it should not drop below 12.5. The voltage sensitive relay will not engage below 11.2 volts.
post #6 of 6 Old Jun 26th, 2011, 3:16 pm Thread Starter
Richco's Avatar
Good News.....
It was the Battery. I replaced it with a temporary battery and the bike started.
Now at my leisure, I will look for a permanent battery. I am thinking of the new Lithium battery. Has anyone had experience with it? At a little under $200, it's not cheap. I did see a demonstration on Utube, where a harley was cranked for almost 2 minutes. They had to stop because the starter motor was getting fried.
Thanks all for the help.....
Richard
Richco is offline
Wiring info needed for the redesigned starter relay. zuchero K1200LT 27 Jun 26th, 2016 8:00 am
No head light, no start. Everything else is normal??now baffeled k2steve K1200LT 17 Aug 31st, 2011 7:38 am
Starter Relay Question DakotaDude K1200LT 4 Mar 12th, 2011 10:39 pm
Fried Starter Relay and Dead Battery btcarver K1200LT 6 Jan 11th, 2011 12:50 pm
Electronic Starter Relay Diagnostics mmalof K1200LT 3 May 18th, 2009 7:25 pm
