Westco Battery - BMW Luxury Touring Community
post #1 of 7 Old Mar 23rd, 2011, 2:44 pm Thread Starter
Westco Battery
Need information on installing Westco battery on K1200LT 2009
Iwrench2 is offline
post #2 of 7 Old Mar 23rd, 2011, 4:11 pm
Re: Westco Battery
Isn't it equivalent?
I did not use a Westco on the LT - I have a no-brand gel cell in mine with an adapter connector - so I cannot comment on your problem.
Hopefully others will join in, but in the interim: I do have a Westco on my GS and it was a direct fit.
Robert in Northern NJ
rdwalker is offline
post #3 of 7 Old Mar 23rd, 2011, 5:03 pm
donsobeck's Avatar
Re: Westco Battery
Just put one in a 03, it fell right in.
The only thing that raised a question was the voltage is high.
In the bike after a run the voltage was 12.93?
Why do you need a battery? My BMW battery was 8 years old.
DON
donsobeck is offline
post #4 of 7 Old Mar 23rd, 2011, 6:58 pm
Re: Westco Battery
DON
OK why was that a concern? You just had it exposed to 14.5 volts from the alternator, it will remain high for a while. Check it the next day and it will be around 12.75, which is a fully charged 12 v battery terminal voltage.
post #5 of 7 Old Mar 23rd, 2011, 7:33 pm
Fountain's Avatar
Re: Westco Battery
The Westco was a drop in replacement for my 2000 LT. Mine is five years old and doing fine.
Why would a 2009 need a new battery?
Fountain is offline
post #6 of 7 Old Mar 24th, 2011, 10:31 am
donsobeck's Avatar
Re: Westco Battery
Hey John was two weeks long enough?
DON
post #7 of 7 Old Mar 27th, 2011, 5:32 pm Thread Starter
Re: Westco Battery
DON
T
The BMW Exide after a few cranks drops off and then it loads up wth fuel.
Doesn't seem to have enough to crank over and fire the plugs.I had this same problem with my GL1500 Gold Wing. I charged it with Deltron battery tender.
Iwrench2
Iwrench2 is offline
Battery question CMV K1200LT 9 Aug 25th, 2010 11:13 pm
Westco battery for 2005 R1200RT zaasu RT Series 0 May 14th, 2009 7:06 pm
My battery story. motorman587 K1200LT 3 Nov 26th, 2008 3:19 pm
'05 Lt Battery And Recharging With An Electronic Low Amps Tender ajs K1200LT 2 Apr 9th, 2007 10:11 am
