power consumption & batterys - BMW Luxury Touring Community
post #1 of 4 Old Feb 12th, 2011, 9:55 am Thread Starter
bobst2's Avatar
Question power consumption & batterys
my battery still works ok but is coming up on five years old.with the lt,s large # of accessories and high output alternator what kind of battery should i be looking at
bobst2 is offline
post #2 of 4 Old Feb 12th, 2011, 10:17 am
Re: power consumption & batterys
i am on my second westco battery and i am very staisfied. beemerboneyard sells this. a lot of guys like the odessey, also a very good battery
edmann is offline
post #3 of 4 Old Feb 12th, 2011, 10:28 am
My preference was always an AGM (Absorbed Glass Mat) battery. I do NOT like the Gel batteries. AGM batteries are sealed, maintenance free batteries, will hold charge for a LONG time just sitting with no load (The LT does put a little load on the battery when just sitting though), and best of all, does not need a special charger like the Gel batteries do. It will work fine with a standard lead acid battery charger (if you use one).
My bikes never sat long enough to ever need a charger.
AGM batteries are made by Odyssey (what I used), Westco, and I think the Panasonic is AGM. Check before you buy. Odyssey has become very proud of their batteries though, considerably more expensive now than when I was using them.
post #4 of 4 Old Feb 13th, 2011, 4:48 pm
BillCav's Avatar
After 6+ years, I just purchased a new Panasonic battery from Polar Batteries on Boundary Rd (Vancouver/Burnaby). Fits perfect but you need a negative side extension so the cable from the bike can screw into it. Ask them for one. They gave me one when I showed them what I needed. Polar Batteries is on the Burnaby side of Boundary just three or four blocks North of 1st Avenue. It cost me $68.00. BMW wanted $272.
Try them out or maybe you have a battery store closer to you.
Good luck!
Bill
05
K1200 LT
BillCav is offline
Switched power from power outlets - caution pilgrim RT Series 8 Sep 16th, 2010 7:12 am
iWay 500c audio problem was GPS 11 Apr 26th, 2007 9:07 pm
No power at lower Power Outlets MattKas K1200LT 7 Mar 6th, 2007 11:49 am
WARNING: The consumption of alcohol may make you.... bmwjason Humor 1 Jun 22nd, 2006 5:18 pm
