Hooking up trickle charger. - BMW Luxury Touring Community
post #1 of 8 Old Mar 14th, 2010, 10:02 pm Thread Starter
MountianMama's Avatar
What is the best way to hook up a trickle charger to the LT.
Can I use the power plug ( ie: for heated clothing )
Eric
MountianMama is offline
post #2 of 8 Old Mar 14th, 2010, 10:21 pm
Hulkster's Avatar
Re: Hooking up trickle charger.
The power plug is most convenient..... do not think you get a better charge by going directly to battery. It does matter if you plug into wall socket or bike first... can not remember which one come first. I believe it is wall socket first than the bike. If that is wrong try the opposite. Charger needs to recognize the battery.
Hulkster 2002 BMW K1200LTE "Hulkster Green"
Hulkster is offline
post #3 of 8 Old Mar 15th, 2010, 7:01 am
highroamer's Avatar
Power plug is fine. I don't think it matters which end is connected first. The modern chargers/conditioners figure out what they need to do once the circuit is completed. One little peculiarity I discovered is that the bike wouldn't always unlock with the remote when the charger was connected. Pulling the plug solved the problem.
highroamer is offline
post #4 of 8 Old Mar 15th, 2010, 7:16 am
UltraLT's Avatar
Power plug is fine for the LT. Just don't do it with a Canbus bike.
Ultra LT
UltraLT is offline
post #5 of 8 Old Mar 15th, 2010, 8:11 am
CharlieVT's Avatar
Yes, most folks use the power outlet.
NOTE that on my LT (maybe all of 'em?) the front outlet is the one to use.
The passenger outlet is switched by the ignition key and isn't continuous to the battery when the key is off.
So use the front one.....
CharlieVT is offline
post #6 of 8 Old Mar 15th, 2010, 9:39 am
I have a seperate Gerbings connector that comes up in front of the seat, I made a cable up for the battery tender that plugs into that. It has its own fuse in line with it.
2000 K1200LT - 94,000 mi. (49,000 mine since July 4th weekend, 2009)
BMW MOA 151654
rcoolbaugh is offline
post #7 of 8 Old Mar 15th, 2010, 8:45 pm
mrbiker's Avatar
YOU MUST always unplug the charger before you do any hooking or unhooking. Better for the bike and more importantly, MUCH BETTER for the charger.
This is a well-researched subject for me.
mike p
2005 BMW K1200LT (got it in July 2007)
2002 Kawasaki Ninja ZX-12R (parked next to the LT)
1982 Suzuki GS-750EZ (paid $500
for it in 1985, sold it for $450 in 2000)
1978 Honda CB-500F (sold in 1980)
1976 Honda CB-400F (drowned to
death in the blizzard of 1978 in Boston)
mrbiker is offline
post #8 of 8 Old Mar 15th, 2010, 9:24 pm
silverlt2002's Avatar
I use the direct to battery pigtail that came with my Batterytender. Feeds out under the left side of the seat near the grab handle with no problems. No guessing if it makes a good connection or is the right plug.
Steve Green
US Army (Ret)
2002 KLT
Titan Silver
silverlt2002 is offline
Problem with BMW Charger after fitting Autocom golden_retrievers_rule_me RT Series 9 Mar 20th, 2010 4:23 pm
Trickle Charger cadent50 Batteries, Chargers, & Electrical 10 Oct 23rd, 2009 8:56 am
How do I connect a trickle charger? Arby60 GS Series 2 Dec 6th, 2008 2:38 pm
Trickle charger jiminabqnm K1200LT 4 Nov 30th, 2006 10:42 pm
Trickle charger for 05 LT mpillis Batteries, Chargers, & Electrical 17 Nov 28th, 2005 2:01 pm
