Trickle Charger - BMW Luxury Touring Community
post #1 of 11 Old Oct 22nd, 2009, 12:28 am Thread Starter
cadent50's Avatar
Trickle Charger
So, I have never used the BMW trickle charger. My battery has not shown signs of discharge, but I don't want to take a chance. Can I just plug it into any of the outlets on the bike? How long should I leave it on? Thanks!
2006 K1200LT, sold
2007 HD Ultra, sold
2004 R1150RT, sold
1993 HD Fatboy, long gone
1983 Yamaha Virago, ancient history
& too many dirt bikes to list.....
cadent50 is offline
post #2 of 11 Old Oct 22nd, 2009, 1:30 am
shoswell's Avatar
Re: Trickle Charger
Should be a plug an play type of deal. I have outlets by both pegs, however I know that the shift side of the bike will not take a "charge" but works. The brake side on the other hand will. When you attach the charger the lights should tell you if it is correctly connected. Simple stuff!
Hoss
'05- K1200LT - Gretchen
MOA, IBA, EXR & RCB and TMI
shoswell is offline
post #3 of 11 Old Oct 22nd, 2009, 4:58 am
motorman587's Avatar
Re: Trickle Charger
If it is a trickle charger forever. Should go into a "float" mode once the battery is topped off. That is what mine do.
Florida
2004 BMW R1150R Black
motorman587 is offline
post #4 of 11 Old Oct 22nd, 2009, 7:33 am
AlaskaFish's Avatar
Cool Re: Trickle Charger
If the one on the left, or "shift", side of your Bike will not work for the charger then someone has messed with the wiring, because it is wired directly to the battery. I have been using that plug for my LT for the past eight years with no probs.
John & Marilyn Fisher
'00 K1200LTC "Katie"
'95 Triumph "Tigger"
Hillsboro, Oregon
AlaskaFish is offline
post #5 of 11 Old Oct 22nd, 2009, 7:51 am
Re: Trickle Charger
I keep mine connected to the outlet on the left ( shifter) side when in use. The one on my 02 near the top case is switched and will not get the charge to the battery. I only use a trickle charger when I'm not going to ride for several weeks. Sort of fun to have a volt meter installed on the bike to watch the electrons trickle away when different items are switched on / off.
Name:	bmw volt ohm meter 003.jpg
post #6 of 11 Old Oct 22nd, 2009, 10:02 am
Patric's Avatar
Hi , I usually keep one of these http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=42292 plugged into my LT . I took the allegator clips off , & put on a BMW plug on instead . I keep one on all my motorcycles , & ... most everything that has a battery , & is not in daily use . Harbor Fright will have them on sale a few times a year , but there not real expensive anyway .
Patric Blackman
2002 K1200LT/Hannigan2+2
AMA Charter Lifemember
Patric is offline
post #7 of 11 Old Oct 22nd, 2009, 4:54 pm
mwnahas's Avatar
Re: Trickle Charger
Make sure the charger is rated for a Gel battery if that is what you have. They have a rest period during the charge to avoid damage to the battery.
Just Go
Cleveland Ohio
2014 K1600 GTL Grey Wolf.
mwnahas is offline
post #8 of 11 Old Oct 22nd, 2009, 6:48 pm
shoswell's Avatar
Re: Trickle Charger
Kinda thought the same thing, until I got deep into "Barbara". Seems that, only that one will accept a charge. Tried the other side as well as the top case, nuttin! I can't see any changes to the wiring, but who knows she has been in quite a few "good" hands...
Dan, where did you get your volt meter? Is it four digits? I have a surface mount and like the recessed look....
Hoss
shoswell is offline
post #9 of 11 Old Oct 22nd, 2009, 7:19 pm
Re: Trickle Charger
Hoss,
A member of this site recommended it. I initially made a mistake when ordering and was able to catch it at the company and make the change with no problem. Seems a good company to order from. It is 4 digits.
http://www.datelmeters.com/cgi-bin/w...onfig=ent-home
post #10 of 11 Old Oct 22nd, 2009, 10:17 pm
shoswell's Avatar
Re: Trickle Charger
Originally Posted by dandiver
Hoss,
You da man! I cam across their site a while back but for the life of me could not find it again.
Hoss
shoswell is offline
post #11 of 11 Old Oct 23rd, 2009, 7:56 am
Re: "Taking charge"
I do not know if it applies to the 2006, but in both my 2000 and 2001 LT's I had to make sure to leave the key in the first "off" position - not in "lock" when charging through the power sockets. Lock disconnects the power outlets.
As said above, the lights on the charger will tell you whether you are connected correctly.
Robert in Northern NJ
rdwalker is offline
How do I connect a trickle charger? Arby60 GS Series 2 Dec 6th, 2008 1:38 pm
Solar Battery Charger for the K1200LT??? JohnnyBSurfing Batteries, Chargers, & Electrical 11 Feb 4th, 2007 11:53 am
Trickle charger jiminabqnm K1200LT 4 Nov 30th, 2006 9:42 pm
Trickle charger for 05 LT mpillis Batteries, Chargers, & Electrical 17 Nov 28th, 2005 1:01 pm
