Now What The Hell Do I Do? - BMW Luxury Touring Community
post #1 of 5 Old Jul 3rd, 2009, 9:15 pm Thread Starter
Moot's Avatar
Question Now What The Hell Do I Do?
So I ordered the Centech fuse block. Easy enough to install as far as that goes. Now I want to power my Valentine, GPS (Tom Tom) and iPhone. Do I just snip thecigar lighter plug off of the car accessory charger, strip the wires and run those wires to the Centech? How do I tell + and - ? Thanks.
2004 R 1200 C (Fire Starter)
2007 R 1200 RT (Heavy Feather)
2008 Ducati 999 S (Shock and Awe)
Moot is offline
post #2 of 5 Old Jul 3rd, 2009, 9:21 pm
Re: Now What The Hell Do I Do?
First I would figure out if the cigar lighter plug is just a pass through of 12V and it does not contain any poer conditioning. I know that was not much help. Best to have a friend with a meter check them out before you go whacking the end off. The one for my xm radio only fed 6 volts to the radio out the back of the cigar plug so I wired up a recepticle and plugged it into that.
post #3 of 5 Old Jul 3rd, 2009, 11:50 pm
shoswell's Avatar
I fried my GPS by cutting the end off and wiring it directly. Now I have a cig. adapter under the rear box and plugged the original harness into that. Not wanting to replace it AGAIN! thier is most likely a resister of some kind.
Hoss
'05- K1200LT - Gretchen
MOA, IBA, EXR & RCB and TMI
shoswell is offline
post #4 of 5 Old Jul 4th, 2009, 12:12 am
A "quick way" to wire things in correct polarity.. +/-
- Cut off the "lighter plug", leaving about 3-4 inches of wire sticking out of the plug.
- Strip the ends of the remaining wire about 1/2 inch.
- Connect your "voltmeter" probes to the remaining stripped wires and plug in the "lighter plug". (be sure not to let the exposed remaining wires or meter probes touch).
- If the meter shows "positive" voltage, then the red probe is connected to the positive (+) and the black probe is connected to the negative(-)
Now, with this knowledge, check the remaining wires for any variance such as a molded line (usually white) on one of the leads... now you know which is which for that device.
post #5 of 5 Old Jul 4th, 2009, 10:38 am Thread Starter
Moot's Avatar
Has anyone ever disconected the R1200 Rt powelet stock outlets from the Canbus system and rewired them to a fuse block such as the Centech?
Moot is offline
EPA Sticker - DMV Hell kamuter K1200LT 19 May 20th, 2008 1:14 pm
Today's thermodynamics lesson dwsdad Humor 1 Feb 4th, 2008 8:28 pm
HELL: A Chemistry Student's Explanation DaFlake Humor 1 May 9th, 2007 3:46 pm
Boyle's Law PMitchell Humor 1 Feb 5th, 2007 3:35 pm
hell byke33 Humor 2 Jan 31st, 2006 3:00 am
