Brass battery coupling for the R1200RT - BMW Luxury Touring Community
post #1 of 3 Old May 8th, 2009, 6:08 pm Thread Starter
zaasu's Avatar
This connector is a solid brass rectangle measures 3/8 " square and 3/4" long. It's function is to screw into the battery terminal and allow you to attach the battery cables facing up (instead facing to the side).
It has a threaded hole on the 3/8" square end for the battery and a threaded hole on top for the cables..
It turns battery removal and hook up into a 20 second job.
I have one brass block and need two.
Anyone know a source for this thingy?
zaasu is offline
post #2 of 3 Old May 8th, 2009, 6:18 pm
BMW Guru
Ted Shred's Avatar
Re: Brass battery coupling for the R1200RT
Is this what you need?
http://www.odysseybatteries.com/acce...s/bmwposts.htm
__________
2016 R1200GS Adventure
2006 DRZ400E
2007 G650 X Challenge
2006 GT200
2005 R1200GS
Ted Shred is offline
post #3 of 3 Old May 8th, 2009, 6:31 pm Thread Starter
zaasu's Avatar
Smile Re: Brass battery coupling for the R1200RT
Not the same, however it looks like it will do the job.
Thanks.
zaasu is offline
My battery story. motorman587 K1200LT 3 Nov 26th, 2008 3:19 pm
'05 Lt Battery And Recharging With An Electronic Low Amps Tender ajs K1200LT 2 Apr 9th, 2007 10:11 am
Bike only 14 months old - battery problems Thor1340 K1200LT 14 Aug 30th, 2006 4:59 pm
R1200RT battery question ben1364 RT Series 2 Mar 27th, 2006 7:28 pm
Is a charger a charger? graydude Batteries, Chargers, & Electrical 28 Dec 10th, 2005 11:13 pm
