03 Alarm Removal - BMW Luxury Touring Community
post #1 of 3 Old May 5th, 2009, 3:33 pm Thread Starter
03 Alarm Removal
I bought an 03 LT 2 years ago with the factory alarm. I never use the alarm and have now lost the fob. The wiring is different than described for the dealer installed alarm. I need to know which wires to jump in the 12 pin plug at the alarm.
pilotdude is offline
post #2 of 3 Old May 5th, 2009, 9:52 pm
Re: 03 Alarm Removal
Mark,
The pins on the 12 pin connector are as follows:
"To get the bike running again you need to jumper the following pins on the 12 pin connector. Pin 3 (black/white/yellow) to pin 11 (black/yellow); this is the starter button signal to the starter relay. Then jumper pin 10 (green/violet, switched power) to both pin 2 (blue/red, flasher module) and pin 6 (blue/violet, engine electronics relay). Now the bike will start and run normally."
This was developed for the 05 units but the wiring is pretty much the same. Except the wire color on pin two which is blue/red vs.blue /blk on the 05.
post #3 of 3 Old May 6th, 2009, 3:11 pm Thread Starter
Thanks so much I will try it tonight and see how it goes.
HELP! Alarm went off now bike won't start! blavenia K1200LT 12 Jul 22nd, 2009 10:33 am
Alarm system on late 07 philh24 K1200LT 1 May 1st, 2009 3:57 pm
alarm removal Rocky Bike Talk 11 Jun 6th, 2008 6:27 pm
Help! Alarm Smoked, Killed bike, 2001 LT Wood614 K1200LT 9 Jun 1st, 2008 8:36 am
Possible Alarm Solution Jinks K1200LT 3 May 26th, 2007 9:18 pm
