Centec and PC680 - BMW Luxury Touring Community
post #1 of 1 Old Mar 30th, 2009, 12:30 am Thread Starter
Super Moderator
dfinazzo's Avatar
Centec and PC680
So take a look at my recent improvements:
1. Mounted a Centec Fuse Panel above the battery - included extra long lines with covers to enable the wiring harness to be moved to the side so the battery can come out easily.
2. Flattened all the battery connections so you do not need any right angle adapters for the PC680.
3. Added studs and nuts to the connections. Makes for real easy connections for battery chargers to connect directly to the battery. Why you ask - I do not get good results from battery tenders on the PC680. In the winter I just let is drop its charge and in the spring I put a big car charger on it for about 18 hours and we are back in business. This was recommended to me by the West Coast distributor of the Odyssey batteries. I have gone through two Junior Battery Tenders that crapped out and no longer charge the Odyssey.
ID:	22412   Click image for larger version
Dan Finazzo
dfinazzo is offline
