Will this charger work on my LT? - BMW Luxury Touring Community
post #1 of 8 Old Feb 18th, 2009, 3:57 pm Thread Starter
Would it hurt anything to leave this on the battery of my LT and just plug it into an extension cord every night?
http://www.harborfreight.com/cpi/cta...emnumber=99857
Dang, it doesn't look like that pasted as a link.
wyliedave is offline
post #2 of 8 Old Feb 18th, 2009, 4:02 pm
cccpastorjack's Avatar
Re: Will this charger work on my LT?
Well, it should be fine if you do not have a GEL battery, and even then it might. The GEL batteries need a special charger (according to the experts).
I have a GEL battery on my GT and have been using a "regluar" battery tender for about a year and it seems to be working fine. I figured I would try it and see and if it didn't work, I'd replace the battery. But..this is a TEST...this is only a TEST...I cannot yet recommend it to you
Jack Homesley
Cornelius, NC USA
Too many others to list...
cccpastorjack is offline
post #3 of 8 Old Feb 18th, 2009, 5:16 pm
Old Slow Guy in A Fast Car
katnapinn's Avatar
Dave it SHOULD work but.... From the looks of that one you'll have to mount the charger on the bike, Or cut the leads and put in a quick disconnect in line. If it was me I would go with something like THIS. It is what I use.
Stevie Shreeve
katnapinn is offline
post #4 of 8 Old Feb 18th, 2009, 7:07 pm
silverlt2002's Avatar
Dave,
Never forget that you'll get exactly what you pay. I can't think of a good place to mount that unit that wouldn't get in the way of something under the seat and I don't think I'd want that under my seat in case it decides to heat up while charging. I'd strongly recommend you look at a Deltran charger. Great units, small size, very reliable. Get the right one for your battery as mentioned. If you don't have a gel battery you can share the charger between the bike, car, and even a lawn tractor if you have one.
Steve
Steve Green
US Army (Ret)
2002 KLT
Titan Silver
silverlt2002 is offline
post #5 of 8 Old Feb 18th, 2009, 10:31 pm
Yamadog's Avatar
Battery choices:
GEL battery
AGM battery
Flooded Cell
Dry Cell
are all of these mutually exclusive or are some subsets of others?
If you put the federal government in charge of the Sahara Desert, in 5 years there'd be a shortage of sand--Milton Friedman
Yamadog is offline
post #6 of 8 Old Feb 19th, 2009, 1:50 pm Thread Starter
Those all excellent tips. I never really thought about catching my butt on fire but I guess that is a possibility with the charger mounted under the seat. I think I will follow your lead Steve.
post #7 of 8 Old Mar 9th, 2009, 5:42 pm
BennyBob's Avatar
Originally Posted by Yamadog
Battery choices:
GEL battery
AGM battery
Flooded Cell
Dry Cell
I ran across this thread looking for battery recommendations because mine died between Friday & Saturday. I ended up with a AGM, best balance of economy & reliability IMHO. Anyway, Flooded Cell, AGM & GEL are related. AGM uses same electrolyte (+/-) but with fiberglass mat between plates which greatly enhances shock & vibe resistance and almost eliminates evaporation, plus it is sealed to avoid spills. GEL goes the extra step of using an advanced electrolyte that is very resistant to flow or evaporation. The only drawback is the GEL is susceptible to breakdown due to overcharging. I'm not sure about Dry Cell. I think it is still lead based but not sure.
On chargers, I have one each Deltran "Battery Tender Jr." $30 and "Battery Tender Plus" $60. Both are excellent and are rated for use with GEL batteries. The new "Battery Tender Waterproof 800" $50 looks cool and I would opt for it instead of Jr. I would not use a non-GEL rated charger with a GEL battery. It might work OK, but why take the chance? If you have $80 burning a hole in your pocket and you want to stimulate the economy, the BMW charger (made by Deltran) is your answer. The BMW ACC adapter $15 fits the models above and is my connector of choice.
Hope this helps.
Benny C. (Central Texas)
BennyBob is offline
post #8 of 8 Old Mar 10th, 2009, 8:59 am
VRodPete's Avatar
Hope this helps.
If you really want the Harbor Freight model that is close to the Deltran, this is it: Harbor Freight Tender I prefer the Deltran models myself, but I know others that use the HF one without any problems. This one is cheaper than the one you were looking at too.
Live Slow... Fly Fast
Check out our
blog that chronicled our trip to Alaska and back.
<- The Boy
The Toys
2001 K1200LT-C that's been to the Alaskan Arctic Circle and back
2008 VRSCAWA H-D V-Rod with a few goodies
2005 VRSCA H-D V-Rod
1981 Mooney M20J
VRodPete is offline
Battery charger question PhantomK12LT Batteries, Chargers, & Electrical 5 Jul 24th, 2008 3:38 pm
Any special Instrciton on new battery install? su_jumptd K1200LT 17 Nov 15th, 2007 5:49 am
Has my BMW charger died? ronlray K1200LT 3 Aug 25th, 2006 6:06 pm
