Another Stupid Battery Question - BMW Luxury Touring Community
post #1 of 6 Old Oct 23rd, 2008, 1:22 pm Thread Starter
jsciullo's Avatar
Does the battery start to charge when you turn it on or does the bike have to be moving? How about when you blip the throttle standing still?
Jim
Jim in Dublin, OH
2000 - Moto Guzzi V11 Sport
jsciullo is offline
post #2 of 6 Old Oct 23rd, 2008, 2:08 pm
Rockdoc's Avatar
Re: Another Stupid Battery Question
The amount of energy produced by the alternator is related to its rotational speed. At tick-over the chances are it isn't producing much more than is required to cover the basic outgoings. Blipping the throttle will increase the energy but only instantaneously so its effect is practically immaterial to the state of charge in the battery.
Although the alternator output is related to speed, it will normally be able to produce a lot more than the system requires, the maximum output being set to cope with the highest power draw. Early, permanent-magnet alternators (as on my 1950s and 1960s British bikes) had no internal regulation and the excess had to be literally burned off as heat. Modern control systems mean that alternators produce only what is required as it is required.
Keith
UK 2004 K1200LT Lux - Katie
Rockdoc is offline
post #3 of 6 Old Oct 23rd, 2008, 2:17 pm
The LT idles at approximately 1K RPMs. The alternator doesn't approach full output until somewhere between 1.5K - 2K RPMs, if I recall correctly. So basically, the battery is not getting charged until you are riding. That is why, so often, you will see your aux lights dim when you're sitting at a red light or stop sign. Blip the throttle = the lights get brighter. This especially happens when you put a lot more demand on the electrical system by adding farkle upon farkle. Halogen lights and heated gear are the worst offenders, obviously.
post #4 of 6 Old Oct 23rd, 2008, 7:37 pm
Originally Posted by messenger13
... That is why, so often, you will see your aux lights dim when you're sitting at a red light or stop sign. Blip the throttle = the lights get brighter. This especially happens when you put a lot more demand on the electrical system by adding farkle upon farkle. Halogen lights and heated gear are the worst offenders, obviously.
and that is why I have started turning everything off as we approach an interstate exit, for example. I turn off all the heated gear (rider and passenger), heated grips and seat(s), radio, etc. I'm doing that because my battery is acting like it's time to be replaced and I want to be able to pull away from the next rest stop without getting out the jumper cables.
post #5 of 6 Old Oct 23rd, 2008, 9:48 pm
When the alternator light on the instrument panel just goes out the alternator voltage is the same as the battery voltage, so it is just keeping up with the current draw for the bike. Any RPM above that is charging the battery, slightly just after the light goes out to higher as the RPM increases.
The alternator light is a very important part of the alternator circuit. The current flow through the light before the engine starts running is used to "boot" the alternator. Without that small current through the rotor winding there may or may not be enough residual magnetism in the rotor to start the voltage producing process.
Some of us have had charging problems related to the wire from the indicator to the rear of the alternator getting loose or coming off, causing a no charge condition which you will not be aware of until it is too late since there will be no indicator light.
Always glance at that light when you turn on the ignition to be sure it is on before starting the ignition, and that it then goes out after start. If it never comes on, you have a problem.
post #6 of 6 Old Oct 23rd, 2008, 10:41 pm
Or you could just put a PC680 in it and forget all that other nonsense.
'13 Dark Graphite Metallic K16GTLD, 24K miles and counting...
'09 Magnesium Beige Metallic K13GT, 63K miles miles and counting...
All lower 48 states plus Alaska on the K13GT in two weeks . . .
Battery charger question PhantomK12LT Batteries, Chargers, & Electrical 5 Jul 24th, 2008 2:38 pm
BMW Battery Charger Question mrkolivers RT Series 6 Dec 27th, 2007 8:34 am
Stupid Electrical Question LTPenguin K1200LT 6 Sep 4th, 2007 3:00 pm
Dog-Gone battery charger question! Yuck! wardenross K1200LT 17 Oct 24th, 2006 1:31 pm
Battery Charge question? Dochatley K1200LT 16 Sep 30th, 2006 2:51 pm
