dead battery - BMW Luxury Touring Community
post #1 of 4 Old Aug 26th, 2008, 6:36 pm Thread Starter
dead battery
my bike is not well, been idle for a while and the battery has gone flat, no response at all. 04 plate with immobiliser so cant open the seat to charge the battery. the 12v is not showing to be charging, any ideas or how can i get to the battery with the central locking on?
pombiker is offline
post #2 of 4 Old Aug 26th, 2008, 10:37 pm
Re: dead battery
Howdy...
There is a lever you can pull to release the seat. I suppose you know where that is located on the left side of the bike. It will take a bit of effort, but if you can push the seat cushion back a bit you'll be able to get a finger on the release lever and push it outward.. there should be just enough room to release the Riders seat.
If there isn't enough room then look between the rider and pillion seat from directly above. You should be able to use a long, thin shank screwdriver to move the latch toward the rear.. that will allow the seat to raise....
REPLACE the BATTERY!!!!
J.M.J...
Dcn Channing
post #3 of 4 Old Aug 27th, 2008, 10:12 pm
ArthurKnowles's Avatar
Re: dead battery
Got a battery charger? Or a male powerlet adapter? If so, you can supply 12 volts to the motorcycle though the drivers side (lower left by the foot peg) powerlet socket. It's live all the time.
Once you give it power you should be able to access the side case and open the seat without potential damage.
ArthurKnowles is offline
post #4 of 4 Old Aug 27th, 2008, 10:58 pm
Miles of Smiles
Hilton's Avatar
Smile Re: dead battery
You have an LT ? Ignition key in saddle bag lock, turn 45 degrees and open. Open seat as normal. I do it all the time. HTH
Jenna: Ocean Blue '06
Rena: The Committee.
ET4 Thing 1
ET4 Thing 2
Hilton is offline
Dead Battery Charging azredline K1200LT 15 Dec 6th, 2007 6:43 am
Dead Battery? k12robert Batteries, Chargers, & Electrical 2 Mar 11th, 2007 10:34 pm
Dead Battery, Just venting Lzyellodog K1200LT 5 Jan 30th, 2006 3:06 pm
Dead battery and car charger TimVipond K1200LT 3 Jan 7th, 2006 7:27 pm
Dead Battery Caused by Bad Reverser PhilD K1200LT 9 Oct 11th, 2005 11:18 am
