Battery Advice Needed - BMW Luxury Touring Community
post #1 of 9 Old Dec 26th, 2005, 6:17 pm Thread Starter
Question for the Collective:
I need to replace my battery. I live in San Diego (moderate temperatures year round). Is a gel or lead/acid the best replacement. If gel, any suggestions on make/model?
Bob Wood
Oceanside, CA
BeemerBob is offline
post #2 of 9 Old Dec 26th, 2005, 6:30 pm
tomandrosie's Avatar
Bob Wood
Oceanside, CA
Lead-acid batts are fine, provided you keep them topped-off. The gel batts, particularly the BMW one, are not living up to the hype that accompanied their introduction. They are fussy about charging, and don't handle deep discharge well.
You omitted the third category, the AGM (absorbed glass mat), which are working very well. The Odyssey 680 and the Westco are both outstanding choices, and not terribly expensive. $75 - $90. HTH
Tom and Rosie Sperry
IBA 303, 304
Hanford, CA
tomandrosie is offline
post #3 of 9 Old Dec 26th, 2005, 7:04 pm
Odyssey!
post #4 of 9 Old Dec 26th, 2005, 7:27 pm
Portguyofva's Avatar
Originally Posted by dshealey
Odyssey!
David,
Thanks for sharing. Never heard of the Odessy but the specs are incredible and price not bad ($83 at the BatteryStore) http://www.batterystore.com/Odyssey/OdysseyProducts.htm
Regards, Ray
04 K12LT (Dark Graphite Metallic)
03 K12GT (Orient Blue)
99 Triumph Daytona 955i (Roulette Green)
99 Triumph Trophy (Viper Red)
Portguyofva is offline
post #5 of 9 Old Dec 26th, 2005, 7:37 pm
Bob,
I just enlightened myself. Recommend you take a look at the Battery sub forum under the Accessories, Gadgets, and Gear thread. All the info you could want.
Regards, Ray
post #6 of 9 Old Dec 26th, 2005, 7:54 pm Thread Starter
Thanks David. Had never heard of them before but will do some investigating. Hope you get back on a bike soon.
post #7 of 9 Old Dec 26th, 2005, 8:03 pm
Gold Supporter
gulfxray's Avatar
Odyssey!
David, do you think using the BMW 'gel' battery charger on an Odyssey would be safe?
I'm going to have to replace my gel pretty soon - she doesn't crank like she used to - and am planning on the Odyssey.
Shawn
Bartlesville, Oklahoma
'03 K1200LT Titan Silver "Big Iron"
BMWMOA #118204
gulfxray is offline
post #8 of 9 Old Dec 26th, 2005, 10:04 pm
The Oddyssey battery can be charged with a normal lead acid battery charger, not sure about the BMW Gel battery one. It won't hurt the battery though, so there should be no issue with trying it.
Also, there are usually a lot of PC680s on eBay, usually for the $60-70 range. I bought my last one from an eBay supplier, got it in 2 days.
post #9 of 9 Old Dec 27th, 2005, 3:05 am
rovero's Avatar
Battery Choice
The Westco 12v20p seems to have better capacity than Oddyssey PC680.
PC680 12v20p
16 amp hours 22 amp hours
222 cold cranking amps 275 cold cranking amps.
Both are AGM and charge fine with battery tender. Also Westco has same terminal type as stock BMW battery.
$79.01 for Westco at this link location.
http://www.casporttouring.com/store/merchant.mvc?
rovero is offline
I am buying one,which one? Advice needed jbuffalo K1200LT 26 Nov 29th, 2005 6:19 pm
Advice needed for fairing fix SoberBiker K1200LT 6 Oct 31st, 2005 7:37 am
