Starter engages without key - BMW Luxury Touring Community
post #1 of 7 Old May 23rd, 2008, 10:31 pm Thread Starter
rguppy's Avatar
Exclamation Starter engages without key
I replaced my battery that had died thinking that i didn't maintain it well over the winter. The key was not in the ginition. When i reconnected the battery the starter engaged when the starter cable touched the battery positive terminal. Luckily i disconnected it before the bike lurched forward enough to drop off the kick stand....could have been a worst disaster!!!
Has this happened to anyone in the past??? I removed all the fuses and even then it tried to start but i had dropped the gear to neutral so it didn't lurch ahead.
Instructions to get to the electronic box appear exhaustive and if there's a tip to try something else before i'd like to at least try.
Obviuosly this is a serious problem
thanks
rguppy is offline
post #2 of 7 Old May 23rd, 2008, 10:35 pm
Just ridin'
Randy's Avatar
Re: Starter engages without key
thanks
You have a stuck starter relay. Put the bike in neutral, connect the battery, then tap the starter button repeatedly while the bike is cranking. That will sometimes unstick the contacts. If that doesn't work you will need to replace the relay.
Randy Prade
Aurora, CO
Just ride it!
Meet Riley
Randy is offline
post #3 of 7 Old May 24th, 2008, 7:46 am Thread Starter
rguppy's Avatar
Thanks for the reply. Right after i posted the thread i was directed to similar threads and lo and behold there's the answer which you just coroborated. I did try the tap to the battery while the starter button is pressed and to no avail! Now it's tupperware party time with even more work after that.
thanks to this web site i at least know what happened!
ciao
rguppy is offline
post #4 of 7 Old May 24th, 2008, 10:08 am
Just ridin'
Randy's Avatar
Actually the only way this will work is to fully CONNECT the battery then repeatedly tap the starter BUTTON. This has to be done with the ignition on and the bike in neutral. By activating the relay coil repeatedly it is possible to unstick the contacts.
Randy Prade
Aurora, CO
Just ride it!
Meet Riley
Randy is offline
post #5 of 7 Old Jun 6th, 2008, 12:50 am
I have the same problem on a 1999 with 1500 miles on it. Does anyone know where the relay is located? I am new to BMW Bikes (Harley Rider) and am very impressed with the ride and quality of the bike.
ResortRealtorJoe is offline
post #6 of 7 Old Jun 6th, 2008, 12:42 pm
The starter relay is located in the electronics box, under the fuel tank. A bit of a bear to get to. There should be plenty of threads/posts covering this procedure - some may be among the 5 "similar threads" below your post, and others will turn up following some keyword searches.
I doubt your relay is covered on the TSB for this problem that occurred mostly with the '99 model LTs, butt it sure wouldn't hurt to ask your dealer about it - especially if you're on good terms with 'em. Maybe other service can be included while they're in there?! Good luck.
post #7 of 7 Old Jun 6th, 2008, 12:49 pm
grifscoots's Avatar
If punching the started button doesn't work, try riding it off a curb. The jolt sometimes breaks them loose.
-=grif=-
Grok
grifscoots is offline
Starter spins but won't engage Scotty2 K1200LT 12 Jun 4th, 2008 8:10 pm
Starter engages with new battery??!! Route66 K1200LT 13 Feb 21st, 2007 7:00 pm
Press starter, whizzzz, no turneee... rmg08057 K1200LT 37 Jan 15th, 2007 10:01 am
Starter problems Yiet K1200LT 5 Aug 14th, 2006 1:32 pm
Starter Sprag Clutch TimVipond K1200LT 3 Nov 17th, 2005 2:33 pm
