Headlight and Hi beams belly up - BMW Luxury Touring Community
post #1 of 4 Old Apr 4th, 2008, 8:26 pm Thread Starter
My headlight and Hi beam on my 2002 K1200lt don't work now. Several days before they went belly up, I noticed that when I got on to go to work, at O dark:30 the hi beam indicator light had a faint glow, when I flicked the hi beams on an off the faint glow would go away, but it would slowly come back. It was never very bright, but both the head light and hi beams worked.
Now that the light and hi beam a out the hi beam indicator is on like as if the hi beam was on.
I called the my local dealer, but all they said was, "sounds like a ground problem".
I drive 2 hours on way to work and back every day and I really need my lights.
Can some one please give me some idea of what to do or where to look?
Aubrey
akaigler is offline
post #2 of 4 Old Apr 4th, 2008, 8:52 pm
Re: Headlight and Hi beams belly up
I think you have a bad ground connection in the headlight assembly. It's a weak point subject to failure. Solution is a heavier gauge ground wire that has been described on the forum in the past.
Motor On ,/'
jkersh1 is offline
post #3 of 4 Old Apr 4th, 2008, 10:29 pm
Smile Re: Headlight and Hi beams belly up
I think jkersh1 has it right
A couple of threads that may be of some help:
Click
And one that is mentioned in the above thread that explains the problem very well:
Click again
Good Luck
Duane
Check the obvious first!
73 Z1 Kawi
and 7 long gone
Dman is offline
post #4 of 4 Old Apr 5th, 2008, 8:03 pm
S.O.B. I woke up in Roswell NM this morning, and not only that both my headlights were out. They were both working in the previous morning when I left Waco, so I guess I'll be doing the ground wire fix now I'm home.
Motor On ,/'
jkersh1 is offline
XENON HEADLIGHT QUESTION - Need to Upgrade! cccpastorjack Lighting 44 Jan 20th, 2012 3:46 am
'02 Headlight with HID Low & High a headlight on ebayon EBay carl_faller Chit Chat 1 Sep 7th, 2007 2:36 am
Anybody break a headlight from a rock? TimVipond K1200LT 11 Oct 1st, 2006 5:40 pm
Headlight modulator lets guy off!!! tmgs Chit Chat 20 Apr 29th, 2006 9:39 am
