Power source when engine running? - BMW Luxury Touring Community
post #1 of 8 Old Jan 18th, 2008, 7:28 am Thread Starter
pozo_izquierdo's Avatar
Hi all wire gurus!
A friend of mine would like to hook up pilot current for some relays from a wire that has power ONLY when engine is running. So not just the regular switched source like rear seat heater or map light. I could not advise him as I have never needed this myself.
Does anyone have any ideas where to look for such a cable? I know spark plug cables have power when engine is running but the voltage is probably too high...
Thanks in advance
PS. His bike is ´05 LT
Regards
Hyvinkää, Finland
pozo_izquierdo is offline
post #2 of 8 Old Jan 18th, 2008, 8:40 am
Wolfgang's Avatar
Here is one way that should work:
Use a standard automotive relay:
85 to oil pressure switch
86 switched power (15)
30 Battery power
87 to whatever you want to turn on.
Wolfgang
K1200LT 1999 Champaign SOLD
R1100RS 1994 Teal SOLD
R1150RT 2003 Blue (Sold)
R1100RT 1997 Blue
Pest, Budapest Hungary
Mark Twain
Wolfgang is offline
post #3 of 8 Old Jan 18th, 2008, 8:50 am
sparky_k1200lt's Avatar
I remember reading, somewhere on this site, of using the 'ALT' dashboard light for that purpose.
...Bob
1978 GL1000
sparky_k1200lt is offline
post #4 of 8 Old Jan 18th, 2008, 11:19 am
You have to be VERY careful attaching anything to the Alternator light. That circuit is the 'excitation' circuit for the alternator, and depends on the small current through the bulb to magnetically 'excite' the rotor so that the alternator will start charging, then the charge voltage takes over.
You can use a very small high coil resistance relay on that circuit to drive a larger relay though.
Best to use the oil pressure switch circuit to drive the relay though.
post #5 of 8 Old Jan 18th, 2008, 11:53 am
Woolly's Avatar
Has he got an intercom - if not, there's a switched power outlet under the stingray which he can get volts from - I was using mine for my Aux amp for an iPod.
  • MB SLK 350 MT
  • 1974 Triumph Bonneville 750
Woolly is offline
post #6 of 8 Old Jan 18th, 2008, 1:11 pm
Miles of Smiles
Hilton's Avatar
Smile Use the Rear Power Socket
Which I did, via a 6 point distribution bus, to power relays as required directly from the battery. HTH
Jenna: Ocean Blue '06
Rena: The Committee.
ET4 Thing 1
ET4 Thing 2
Hilton is offline
post #7 of 8 Old Jan 18th, 2008, 3:31 pm
Wolfgang's Avatar
But that is power with the key on as opposed to "engine running" only. I believe that was the request.
For that the oil pressure switch is the best way. Because the engine better not be running without oil pressure. And if it does, you have much bigger problems than the farkel that you are powering up.
Wolfgang
R1100RT 1997 Blue
Mark Twain
Wolfgang is offline
post #8 of 8 Old Jan 18th, 2008, 3:43 pm
Miles of Smiles
Hilton's Avatar
Smile Woops
Been a while since I added that bit Wolfgang, so you're probably right. My bad.
Rejoining "Jenna" the end of Jan so no way to check now.
Name:	Rear Wiring.jpg
ET4 Thing 1
ET4 Thing 2
Hilton is offline
Missing bits... cfell BMWLT Site Support Forum 3 Oct 9th, 2007 9:51 pm
Running Engine Speeds rglassma K1200LT 3 Jul 15th, 2007 7:57 am
iWay 500c audio problem was GPS 11 Apr 26th, 2007 8:07 pm
Light Power Source cfmpilot K1200LT 12 Apr 13th, 2007 9:37 am
Best switched power source for HID relays? Schweintechnik Lighting 6 Nov 17th, 2006 9:17 am
