Battery Tender - BMW Luxury Touring Community
post #1 of 4 Old May 28th, 2007, 7:54 am Thread Starter
mikeinpgh's Avatar
Angry Battery Tender
I did something stupid.
I turned the key to look at the clock on the bike and when I turned it off I turned it to parking.
It was hooked to the battery tender.
The battery drained and it seems I used all the electricity in the tender also.
here is the question
Does the battery tender have a fuse inside or did I fry it?
I wanted to check before I drilled out the rivets and looked
TIA
Mike in Pittsburgh
2000 K1200LT Canyon Red
1983 Honda GL650I Silverwing Interstate
mikeinpgh is offline
post #2 of 4 Old May 28th, 2007, 10:15 am
If the battery went completly dead the tender will NOT charge it up. It only works on a weak battery not a dead battery. Give the battery a bit of time on a regular charger first, lacking that hook it up to a car battery (car engine off) with jumper cables. Make sure you monitor it while you do that for heating of the battery. 15 minutes should do it, then try the tender.
post #3 of 4 Old May 28th, 2007, 10:46 am Thread Starter
mikeinpgh's Avatar
The bike and battery are fine. Used my regular charger to take care of that
the tender is dead
Mike in Pittsburgh
post #4 of 4 Old May 28th, 2007, 3:04 pm
PMitchell's Avatar
the tender is dead
The fuse is usually in the external cord between the unit and the battery contact connections (clip-on or bolt-ons).
If not, open up the Tender and take a look-see.
pm
Ride till you can't!
"Der Weg ist das Ziel"
2006 Tuscany
2008
2011 South Africa
'18 R1200RTW
Sold in '67
PMitchell is offline
battery tender hook up?? MN.GT K1200/1300GT (The Next Generation) 3 Aug 24th, 2007 1:26 pm
'05 Lt Battery And Recharging With An Electronic Low Amps Tender ajs K1200LT 2 Apr 9th, 2007 11:11 am
BMW Gel Battery Tender rjhammetter K1200LT 2 Nov 3rd, 2006 9:04 pm
Error light on battery tender pozo_izquierdo Batteries, Chargers, & Electrical 7 Apr 1st, 2006 11:35 am
