Out of control seat-heat. - BMW Luxury Touring Community
post #1 of 4 Old Mar 19th, 2007, 8:35 pm Thread Starter
harrowbmw's Avatar
greetings all.
Just a quick question for you all.
How does one remove that three-way seat-heat switch for inspection, from the beneath the riders seat? I can't turn the blasted thing off and it's cooking my figs big time. It's still quite warm here in Australia this time of year.
Kindest regards to all.
Paul Harrington
AU
[email protected]
1999 K1200LT Champagne "Bismarck"
1983 base K100 "Bavarian Belle"
harrowbmw is offline
post #2 of 4 Old Mar 19th, 2007, 11:24 pm
tbarstow's Avatar
Paul,
The electrical connection is under the driver's seat, under your left leg. It should be a white, 2 wire, quick disconnect. The wiring will be tied in with the main wiring harness that goes up the left side of gas tank, then turns right under the trim panel below the oddments box. From there it snakes its way out to the seat. Disconnecting the power should save you from roasting things futher.
After looking at mine, to get to the actual switch, I believe you'll have to disassemble the seat or cut the seat pan to get it out. I would email Ron Miller (of Kontour Seats) to ask about the switch set up that is under the foam.
Tim Barstow
2004 GSA Silver
2007 X Challenge
tbarstow is offline
post #3 of 4 Old Mar 20th, 2007, 2:10 am
Miles of Smiles
Hilton's Avatar
Smile Three Way Switch
Paul, it's a three way switch. Off is the central posion and IIRC, back is high, forward is low. HTH
Jenna: Ocean Blue '06
Rena: The Committee.
ET4 Thing 1
ET4 Thing 2
Hilton is offline
post #4 of 4 Old Mar 20th, 2007, 5:48 pm Thread Starter
harrowbmw's Avatar
Thankyou Tim & Jenna.
I was somewhat afraid you'd say to remove the switch it required a surgical procedure of the seat Tim. And Jenna, yes, I ensured I had that rocker switch in the middle position, being the off. I replace the fuse and work the switch a little in case the contacts are a tad dirty within it.
Thanks for that people, I'll endeavour to find the solution.
Paul Harrington
AU
[email protected]
Older seat on ?05 bike pozo_izquierdo K1200LT 7 Apr 13th, 2011 11:07 pm
Section speed trap in The Netherlands vvk Europe 4 Apr 18th, 2006 3:40 am
Ariís winter farkle projects part 4 (power seat height adjuster) pozo_izquierdo K1200LT 21 Apr 7th, 2006 11:45 am
Speed traps in The Netherlands vvk Chit Chat 0 Oct 24th, 2005 9:38 am
