Flickering headlight, turn signals cancel - BMW Luxury Touring Community
post #1 of 1 Old Mar 18th, 2007, 1:18 pm Thread Starter
Friends,
Although I am aware that there are posts that address this problem, I wanted to expand on what I have read here. Others have discovered that flickering lights that begin when the engine is revving upwards of 2500 rpm can be traced to a loose bolt that holds the starter in position. The starter provides the ground path for the current that energizes the load relief relay. This relay feeds a number of systems on the K12LT. Among these systems is the turn signal flashing unit. If the starter is loose, it will make intermittent contact with the engine.
This causes the load relief relay to chatter, causing the lights to flicker, the signals to cancel, the radio to misbehave, and possibly other symptoms. This bolt is tough to reach, requiring removal of the fuel tank, and some ginger fingerwork. Be sure to use some Loktite (blue would be best) so that the bolt doesn't work its way loose again. Have fun with this one!
Bill McGrath
Chandler, AZ
Zippy is offline
Increased Visibility of Front Turn Signals deputy5211 Bike Talk 10 Jan 20th, 2007 10:37 pm
help, wiring, turn sig cancel, autoswitch hdfan K1200LT 6 Nov 24th, 2006 10:41 am
Turn signals dont cancel Empath K1200LT 20 Oct 4th, 2006 2:21 pm
why are cancel-ing turn signals so lame? KYchris02 K1200LT 4 May 6th, 2006 12:29 am
Make mine smoked please...Turn Signals Tbird Lighting 4 Nov 15th, 2005 6:33 pm
