Battery time - BMW Luxury Touring Community
post #1 of 6 Old Jan 2nd, 2007, 7:55 am Thread Starter
Battery time
Okay, the 03 is about due for a battery. Been shopping around. Found the new yuasa AGM battery for $69 delivered for free. Says "activated and ready to install". Or the old wet cell type for $50, has to be filled and charged. OR BMW dlr $100 for whatever kind they are using (wet cell, I presume).
I've looked in the tech articles and the HoW for more tips but battery stuf is sorta lacking.
What are the current recommendations for 03 LTs at this point? I have a 1 amp trickle charger, pretty simple kind, with nothing other than 6 or 12 v settings. I am willing to upgrade this also, if I must.
Pros and cons of each type? I have seen some negatives associated with the gel and AGM type batteries so I am wondering which may be best. I do try to ride at least once a month in the winter and am actually getting to ride a lot this winter, which helps keep it charged. but I basically have to charge it every day now, so want to know best bet for a new one.
Rando
rando is offline
post #2 of 6 Old Jan 2nd, 2007, 9:19 am
The battery in my '03 is also on it's last legs. It came from the factory with a gel battery-it doesn't have any openings in the case.
There appear to be several options, Odyssey, Panasonic, and wet cell among others. The Odyssey (PC680) is about $90 and the Panasonic (LC-X1220P) is $56 from Digikey. It looks like you made need to get an adaptor to connect the Odyssey as the terminals look to be different.
Alan Stuber
2003 K1200 LTC Titan Silver
Austin, Texas
astuber is offline
post #3 of 6 Old Jan 2nd, 2007, 9:58 am
Alan.. just found this:
http://www.gotbatteries.com/items.as.../all/LC-X1220P
$47!!!
Shipping unde $11.
or
http://www.portablepower.com/items/b...PC680/37L105S5
for $76.95 and ships in 24 hours.. will need this for use on the LT.. http://www.portablepower.com/items/s...1/all/30Z105B1
J.M.J...
Dcn Channing
post #4 of 6 Old Jan 2nd, 2007, 10:52 am
murray's Avatar
Thumbs up Odyssey PC 680
The pulse on the board has suggested the Odyssey PC 680 batteries.
www.odysseybatteries.com
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #5 of 6 Old Jan 2nd, 2007, 11:49 am
mtrevelino's Avatar
Or you can purchase a Westco from:
http://adventurersworkshop.com/Merch...ode=WESTCOBATT
for $79.95. In my 2000LT, the Westco cranks the engine faster than the Odyssey.
Mike Trevelino
Williamsburg, VA
2008 RT
mtrevelino is online now
post #6 of 6 Old Jan 2nd, 2007, 12:20 pm Thread Starter
What about chargers for the "fancy" batteries? Best bang for the buck? Battery Tender? Which one should I consider? I will need a different charger, from what I have read, to use with the gel opr AGM batteries.
RAndy
rando is offline
Help. The battery gremlins have got me! paulcbrowne K1200LT 6 Jul 7th, 2006 8:46 pm
I've tried to read everything on this site but I'm still confused kdale K1200LT 11 Jul 3rd, 2006 6:44 pm
ABS faults:Odyssey Battery better? dshealey K1200LT 11 Mar 16th, 2006 2:48 pm
Battery Charger bugged Batteries, Chargers, & Electrical 4 Dec 11th, 2005 9:55 am
need battery help/tips brianh178 K1200LT 6 Nov 2nd, 2005 9:51 pm
