Shorai battery - BMW Luxury Touring Community
post #1 of 1 Old Jul 18th, 2015, 2:05 pm Thread Starter
Triker's Avatar
Smile Shorai battery
As usual, I did not get on here and check out any discussions regarding batteries before I searched for and found one that I ordered from batterystuff.com. The battery (which was on a chart for the LT) is a LFX18L1-BS12. It is a 12v, 18AH which has a cranking rating of 270. It weighs slightly less than 3 lbs. It is very small, 5.8 x 2.63 x 4.23 inches. It is packed in a box with several 1/8 inch pads which are to be used as shims to make up for its reduced size. It is a Lithium ion battery. Does anyone have any experience with these/this battery? I haven't installed it yet and am hesitant to do so. I read some info on it and its supposedly much more reliable than the lead-acid type of battery. Any help/comments are welcome.
The brand is Shorai. Their web site is shoraipower.com. After ordering this battery, I get this letter with it telling me to check their web site to make sure I have the right battery, etc. So, I get on and check out my 2005 LT, and it says that the standard recommendation is not the one I ordered, but a higher rated one, the LFX21L6-BS-12 which is slightly larger in height (1 inch taller) and has 315 cold cranking amps as opposed to the one I received which has 270.
Triker
Longmont, CO
2005 LT Hannigan Trike
Triker is offline
Shorai battery in 2011 RT Phillo RT Series 3 Aug 3rd, 2013 11:30 am
Shorai battery Voyager K1200LT 10 Mar 7th, 2012 7:26 pm
Battery question CMV K1200LT 9 Aug 25th, 2010 11:13 pm
Is a charger a charger? graydude Batteries, Chargers, & Electrical 28 Dec 10th, 2005 11:13 pm
