RIM/Blackberry Device powered from LT - BMW Luxury Touring Community
post #1 of 13 Old Aug 22nd, 2006, 8:31 am Thread Starter
Has anyone hooked up a Blackberry/RIM device by powering it off the USB port to the cycle?
Any ideas on how to do this?
Not sure if I can hook up the power and ground from the USB directly to the battery. It will probably fry doing this.
ehaughn is offline
post #2 of 13 Old Aug 22nd, 2006, 9:00 am
I don't have one, but I have a recommendation.
  1. Buy a car charger for your RIM/Blackberry.
  2. Remove the cigarette lighter portion of the charger.
  3. Wire the rest directly to the LT's battery, or your fuse block. Just make sure that it's fused.
post #3 of 13 Old Aug 22nd, 2006, 10:08 am
mneblett's Avatar
Interesting thought -- I'll look into this. I've been carrying a BB charger on longer trips, but IIRC, the voltage spec for USB includes 12V, so one should be able to hack the end off a cable and take 12V directly from the bike -- that certainly is the case with IEEE 1384; that's how I power my old second generation iPod (hack-off Firewire cable to unused power source in radio housing).
I want to confirm the USB charger output voltage really is 12v, so I'll probe my charger with a voltmeter tonight and report back. If it is, I'm but a hack-and-solder away from on-board charging
Mark Neblett
Fairfax, VA
mneblett is offline
post #4 of 13 Old Aug 22nd, 2006, 1:23 pm
Careful there, Mark. I believe the USB voltage spec is 4.40V - 5.25 Vdc.
FireWire has a much broader input range (something like 9 - 30 Vdc) so a direct bike connection isn't a problem. That may mean this direct connection trick wouldn't work on a newer USB 2 iPod either.
I'd stick with a modified car charger cable.
'13 Dark Graphite Metallic K16GTLD, 24K miles and counting...
'09 Magnesium Beige Metallic K13GT, 63K miles miles and counting...
All lower 48 states plus Alaska on the K13GT in two weeks . . .
post #5 of 13 Old Aug 22nd, 2006, 1:28 pm
mneblett's Avatar
Thanks, Ken -- that's *precisely* why I wouldn't hook something like this up until I probed with a voltmeter. Wouldn't want the magic smoke to escape now, would we?
Mark Neblett
Fairfax, VA
mneblett is offline
post #6 of 13 Old Aug 22nd, 2006, 1:45 pm
I know you're smart enough to figure that out, Mark. But I thought I'd add the details to the thread for future searches.
In the mean time, I gotta go to work and help put the magic smoke into the little black boxes.
post #7 of 13 Old Aug 22nd, 2006, 4:21 pm Thread Starter
I believe the USB can only handle 5 VDC.
How do I modify the cigarette adapter?
Anyone got any pics on this?
ehaughn is offline
post #8 of 13 Old Aug 22nd, 2006, 4:33 pm
I'll take a pic of my cell phone cable that I'm about to install on my GT tonight. I'll post it in a few minutes.
post #9 of 13 Old Aug 22nd, 2006, 4:49 pm
Here's a pic of my modified cell phone charger cable that used to plug directly into a cigarette lighter socket. It's a bit ugly , but it works and nobody sees it anyway. It worked for over 40K miles on my LT.
post #10 of 13 Old Aug 24th, 2006, 8:19 am Thread Starter
Thanks Joe.
I assume I could get any USB charger for the cig lighter socket and it should work???
ehaughn is offline
post #11 of 13 Old Aug 24th, 2006, 8:28 am
Yep. Just don't be surprised at how tiny the wires are inside those things.
post #12 of 13 Old Aug 24th, 2006, 8:36 am Thread Starter
One more question.
What is the power plug name used on these bike? Used for running accessories. There is a socket by the passenger by the intercomm and also by the drivers left foot.
ehaughn is offline
post #13 of 13 Old Aug 24th, 2006, 8:40 am
One more question.
Powerlet.
Economobile powered by BMW eljeffe Chit Chat 4 May 17th, 2006 7:45 pm
Timing chain ALIGNING DEVICE measurement ? Frenchy K1200LT 15 May 15th, 2006 5:54 pm
BMW Powered V8 and V12 powered bikes eljeffe Chit Chat 2 Apr 25th, 2006 2:06 am
Help with old post .. Multi Chainsaw powered bike motorhead Chit Chat 3 Dec 24th, 2005 6:50 am
