It's Happened... - BMW Luxury Touring Community
post #1 of 3 Old Feb 25th, 2014, 10:11 pm Thread Starter
Rodders's Avatar
Question It's Happened...
Hi All,
Has anyone in Oz had the dreaded ABS module failure lately? My GS-911 comes up with a different fault code after each bleed, the fault cleared once until I used the pumps to bleed the rear brake and hasn't cleared since.
The random fault codes make me think the problem is electronic.
I live in the mid-north coast of Queensland, so no handy dealerships, and I'm bleeding without any of the trick tools.
There was a post somewhere that said BMW in the states has dropped their price to a grand US..........I'd tip that's not the case here.
I would be glad to hear of anyone's experiences getting this problem sorted
'02 K 1200 LT
'85 K100 RT
Rodders is offline
post #2 of 3 Old Feb 25th, 2014, 11:52 pm
Re: It's Happened...
Hi Rod, can't recall off the top of my head anyone reporting it... but then I do have a bit of a short-term memory :-)
When you say you are "bleeding without any of the trick tools", what precisely are you doing?
Pretty sure your 2002 ABS is slightly different to mine (2005) so can't comment on correct procedure there apart from basics - having done it a whole once myself, though I'm sure you've already researched the relevant posts/tech articles etc...
What errors codes is the GS911 reporting?
I've just gotten mine recently and still trying to figure it all out...
post #3 of 3 Old Feb 26th, 2014, 2:21 am Thread Starter
Rodders's Avatar
Hi Chris,
Yes, I'm following the posts of more experienced people bleeding the thing. I first got "pressure in front cc't too high", which later changed to the rear circuit, which later became faulty pressure sensor in one or the other cc't.
The pressure sensors are digital load cells right in the very bottom of the housing, so if any moisture does get into the system, it's a safe bet they will be the first component to die.
'02 K 1200 LT
'85 K100 RT
Rodders is offline
Yes! The obligatory tip over finally happened. KI_OTE K1200LT 8 Sep 14th, 2013 4:23 pm
Has This Ever Happened To You? Razmataz Humor 3 Apr 1st, 2010 8:46 pm
This never happened before? ronnieds K1200LT 20 Dec 2nd, 2009 9:08 pm
Finally it happened Alpac K1200LT 16 Jul 19th, 2008 9:18 am
Not going to believe what happened Friday KYchris02 K1200LT 16 Nov 19th, 2007 11:25 pm
