FD Failure on 2010 RT - BMW Luxury Touring Community
post #1 of 10 Old Jul 28th, 2013, 11:49 pm Thread Starter
I thought that it would never happen to me - after all, the FD failure issue was meant to be sorted out and that newer models were OK. I had checked it out before I bought my December 2012 RT. Turns out its still a problem - funny noises coming from the FD - took it in for 50k service - FD is stuffed.
The good news is that even though it is out of warranty (time and kilometres), BMW have agreed to pay all material, freight and labour costs ($3,500 for a new FD alone!!!!).
Currently planning a coast to coast run from Sydney, so it will be a good test for the FD when I get it back on the road (minimum 2 weeks to get a new FD here as it has to come from Germany).
Sixty6north is offline
post #2 of 10 Old Jul 29th, 2013, 12:02 am
PCH
PCH's Avatar
Re: FD Failure on 2010 RT
so did it happen on a 2010 or a 2012 year RT ? do u know which component actually failed ( Crown Pinion or needle bearing? )?
regards
PCH
R 1200GS 2015
R 1200 RTSE 2013 90th Anniversary
R 1200 RTSE 2008 gone at 100k km
R 1100 RT 1999 Gone at 60,000 kms
Various other Japanese bikes over many years.
"Be kind to everyone, it is easier and a whole lot less trouble"
PCH is offline
post #3 of 10 Old Jul 29th, 2013, 12:08 am Thread Starter
oops - confusing. It is a December 2010 RT.
The main ball bearing has collapsed - probably damage to the crown and pinion as well.
By the way, it has been serviced by a dealer for every scheduled service, so fluids will have all been changed when recommended (in theory anyway).
post #4 of 10 Old Jul 29th, 2013, 12:12 am
It will be the main bearing which chops the seal ,always is ! ....No later model Beemer escapes the dreaded FD issue.
2001 k1200lt
2010 r1200gsa 30yr
2006 Harley Deluxe
1996 gsxr 750
2006 gsxr 1000
2007 ktm 525 exc
Alpha1 is offline
post #5 of 10 Old Jul 29th, 2013, 12:38 am
PCH
PCH's Avatar
No accurate in all cases. The roller bearing collapsed on my 2008 model. The final drive fluid has no effect on that bearing as it is seperated by a seal. What usually kills it is water.
there are several spots they fail in.
Just wondering exactly which one ? There is a theory that the way the bike is washed can contribute to failures . Not totally substaniated but worth considering.
If it was every one above a certain mileage I would agree , but I know a lot in the 100+ kms with no issue. It will be interesting to see what happens with my 2013 model.
regards
paul
PCH
R 1200GS 2015
PCH is offline
post #6 of 10 Old Jul 29th, 2013, 1:50 am
Point taken ,mines a 2001 model and the FD went at 49000 Kay's ,I don't use a pressure washer and I have always done my own services as im a mechanic and never found any water contamination .Before it failed I had heard about failures so I changed to synthetic which obviously didn't work.The main bearing that completely collapsed in my unit does run in oil and I also own a GSA with the new design FD and according to ADVrider they are failing all over the world hence the FD comment .
2001 k1200lt
2010 r1200gsa 30yr
2006 Harley Deluxe
1996 gsxr 750
2006 gsxr 1000
2007 ktm 525 exc
Alpha1 is offline
post #7 of 10 Old Jul 29th, 2013, 2:29 am Thread Starter
regards
paul
I never wash mine, so unlikely to be ingress. Looking back, I noticed that the outer seal was weeping a bit about 5,000km ago when I was on a ride to Brisbane (i was sitting next to the bike having a break when I noticed it). I am not sure what came first - was the weeping seal because the FD was starting to let go, or did it let go because of the weeping seal (i.e. some rubbish getting back in)
post #8 of 10 Old Jul 29th, 2013, 5:00 am
Sad,why can't BMW get it right,I had earlier BMWs and never had a final drive problem and wore clutches out.When I started riding Ducati had all sorts of reliability issues and BMW had a reputation as the reliable bike,now my friend who rides a Ducati shakes his head when you mention my BMW which has not finished rides with oiled clutch and final drive issues.
Pedro is offline
post #9 of 10 Old Jul 29th, 2013, 5:05 am
You will find that the bearing was on its way out first and the lateral movement of the failing bearing caused the seal to leak...IMHO
2001 k1200lt
2010 r1200gsa 30yr
2006 Harley Deluxe
1996 gsxr 750
2006 gsxr 1000
2007 ktm 525 exc
Alpha1 is offline
post #10 of 10 Old Jul 29th, 2013, 5:12 am
I read somewhere recently that Yamaha got hold of a BMW shaft drive assembly and redesigned it to be bulletproof and to be fitted to the new Super Tenere 1200 .Spose time will tell if it has longevity ,maybe BMW could buy it off Yamaha to refit to theirs !......Just sayin.
2001 k1200lt
2010 r1200gsa 30yr
2006 Harley Deluxe
1996 gsxr 750
2006 gsxr 1000
2007 ktm 525 exc
Alpha1 is offline
Poll...How many folks have had final drive problems missusfinz RT Series 126 Aug 16th, 2015 8:59 pm
R1200RT 2010 Brake Failure buiduc_hung RT Series 17 Mar 9th, 2013 1:51 pm
What are the suspected reasons for final drive failures av8trto K1200LT 49 May 31st, 2012 8:02 pm
2010 BMW R1200RT Clutch Failure? 99chromehead RT Series 24 Oct 29th, 2010 1:00 pm
