WOW Wilbers WOW - BMW Luxury Touring Community
post #1 of 10 Old Oct 6th, 2012, 5:58 am Thread Starter
WOW Wilbers WOW
Hi all,
I have been reading how everyone describes the ride on the LT as smooth and comfortable. I have, since owning the bike, found any slight alteration in the road being felt either through the bars, pegs or seat. To the point where I started to question my riding ability. If you read some of my earlier posts I have noted some issues.
Yesterday I installed Wilber shocks front and rear. OH MY GOD, what a difference. I ride roads that I have previously approached with trepidation, calmly. I find that my grip on the bars is easing and my confidence returning.
In a nut shell WOW. The transformation is beyond my expectations. I now have a new bike that I need to get used to.
I am looking forward to taking the wife for a ride. Last time out we bottomed out repeatedly and she all but refused to get on the back until I fixed the issue. I now feel it is fixed and some.
For those considering a shock/spring upgrade, do yourself a favour, do it.
One happy rider.
Brian.
bfree is offline
post #2 of 10 Old Oct 6th, 2012, 6:46 am
GJPinAU's Avatar
Re: WOW Wilbers WOW
Hi Brian,
Where did you get them from and how much?
Greg
2005 K1200LT, Light Yellow Metallic
Ulysses member #60049
Fixed the cowbell replaced quick disconnects replaced stereo x 2 installed Trunk
latch kit installed DRLs performed minor service replaced rear shock Z-technic windscreen Wilburs front shock HID upgrade Serviced EHCS
GJPinAU is offline
post #3 of 10 Old Oct 6th, 2012, 6:51 am Thread Starter
Re: WOW Wilbers WOW
Greg,
They were from SOS Suspension near Penrith. Were Aus$2,278 and made to measure.
Brian
bfree is offline
post #4 of 10 Old Oct 6th, 2012, 6:55 am Thread Starter
Re: WOW Wilbers WOW
Oh, and to fit. no issues. More time spent on Tupperware than fitting the units. You can do it without removing any where near the amount of bits some state. I took some guidance from John W on not removing the stearing damper. Did not remove the tank. The rear actually took longer to fit the dampers.
Brian.
bfree is offline
post #5 of 10 Old Oct 6th, 2012, 7:43 pm
motorhead's Avatar
Re: WOW Wilbers WOW
They are SWEET indeed ... 45K + miles worth here
Our "semi" quiet riot
*** Trailer Too ***
T
wisties Required
motorhead is offline
post #6 of 10 Old Oct 8th, 2012, 7:36 pm
Thumbs up Re: WOW Wilbers WOW
another happy customer.... good one Brian!
post #7 of 10 Old Oct 8th, 2012, 11:57 pm
PhillWard's Avatar
Cool Re: WOW Wilbers WOW
Originally Posted by bfree
Greg,
Brian
Hi, Yes I bought a front Wilbers unit from Sean at SOS Suspension in Penrith, probably about 6 years or so ago (think that was about $1000 then).
I have also had Sean regas the BMW rear unit, which he needed to modify of course. I think he installs a Honda top section seal to the rear suspension unit which allows him to take the unit apart, and have a gas valve installed. Again that was probably about 6 or so years ago.....
Time flies..and I would be pretty sure that I need to get both done again as Beryl is a bit rickety on these potholesforroads we have.
Just a hassle in taking Beryl off the road in order to take the bits n pieces off (I'm sure I would have done a write-up on replacing these units and posted here somewhere).
Beryl is over the 211500kms, and just chugs along as she should...
Phill
1950 Sunbeam 500cc S7 Combo
19XX BSA 500cc single B33
1960 Triumph 650cc Tiger 110
1970 Honda 750cc four K1
1999 K1200LT "Beryl Beemer"
Ulysses 18430
PhillWard is offline
post #8 of 10 Old Oct 9th, 2012, 3:35 am Thread Starter
Re: WOW Wilbers WOW
Phil,
If you need either of the shocks to keep you going whilst you do a refit, they are yours, gratis.
Brian
bfree is offline
post #9 of 10 Old Oct 14th, 2012, 4:30 am Thread Starter
Re: WOW Wilbers WOW
Hi to all.
An update on the shocks.
I have been on a few short trips and find the shocks one up fantastic. More ground clearance and a heap more stability in corners. Mainly from the front end.
Two up, the wife and I went on a quick trip to Wiseman Ferry and back. It was a 95% success. The first thing that was noticed, The technicians at Wilber's need to recalibrate there weights and measures for the shocks. When I adjusted the pre load to the weight that we supplied Wilber's, it did not support the wife's weight sufficiently. I needed to add a few extra turns to the preload to stop scrubbing out.
Now, I am not saying that the weight my wife gave me is wrong, it just has to be the Germans read scales differently to my wife. I am sure that the weight she gave me was visible in the half moon viewing panel of the scales. It was just not Top Dead center.
With the preload corrections made all went sweet. Arrived home and asked how she enjoyed certain parts of the ride. Only to find out she slept through the best part which was smooth road with gentle curves at moderate speed. She just remember being rocked to sleep.
Now we need to plan our next outing, extending the distance till we get up to day rides.
Let me know if any others have experienced the same displacement issues.
Brian
bfree is offline
post #10 of 10 Old Oct 14th, 2012, 6:43 am
K100Dennis's Avatar
Re: WOW Wilbers WOW
You are a brave man Brian, I'm thinking your wife went to sleep after the ride because she was already very tired,.............. and you have taken the opportunity to post while she is asleep ! My rear shock appears to be spot-on based on the weight I provided to Wilbers. Fully loaded with luggage and wife I use about 12 turns on the preload. Solo I run with 1 full turn only and I have wound on 1 more turn of both high and low speed compression damping. There is no wallowing in corners at all, tracks like on rails, which was not the case with the OEM shocks. What rebound damping setting are you using on the front ? I am not convinced I have mine set up quite right yet. My front shock was factory set at 12 clicks (about mid way), I've since wound off the damping by 3 more clicks.
Dennis
1987 Yamaha TY250R
1991 Aprilia Climber 280
1988 K100RT (the pack horse)
K100Dennis is offline
Wilbers ESA Review MeanGene Shocks and Suspension 0 Aug 3rd, 2011 2:13 pm
wilbers USA done? tmgs K1200LT 27 Apr 22nd, 2007 11:45 pm
Klaus loosing Wilbers distribution rights??? zaphod Dealer Experiences 3 Apr 19th, 2007 8:21 am
Wilbers Ordering Mishap rattso K1200LT 12 May 16th, 2006 2:27 pm
Wilbers Shocks Questions rattso K1200LT 10 Apr 11th, 2006 10:08 am
