Just saying Hi - BMW Luxury Touring Community
post #1 of 10 Old Jun 29th, 2011, 3:08 am Thread Starter
Colinh's Avatar
Just saying Hi
Hi All
Been lurking around the forum for a while great information and helped me purchase a 2001 LT.
I live in the Northern Beaches in Sydney, haven't ridden recently due to some problems with the bike but hope to have it sorted out in the next few weeks and then look for some good weather and happy days.
Colinh is offline
post #2 of 10 Old Jun 29th, 2011, 3:55 am
Axle's Avatar
Re: Just saying Hi
g'day mate we are but a few welcome
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #3 of 10 Old Jun 29th, 2011, 6:47 am
GJPinAU's Avatar
Re: Just saying Hi
Another one in Sydney town!
Welcome Col. What problems have you had with the bike?
2005 K1200LT, Light Yellow Metallic
Ulysses member #60049
Fixed the cowbell • replaced quick disconnects• replaced stereo x 2• installed Trunk
latch kit• installed DRLs• performed minor service• replaced rear shock• Z-technic windscreen• Wilburs front shock• HID upgrade• Serviced EHCS
GJPinAU is offline
post #4 of 10 Old Jun 29th, 2011, 7:36 pm
K100Dennis's Avatar
Re: Just saying Hi
G'day from Tasmania Colin. I was the same, had a 1988 K100RT previously then needed a good forum since purchase of 2005 K12LTE. PM me if you intend to travel across Bass Strait, some great roads over here. best regards and ride safe, Dennis Brown
K100Dennis is offline
post #5 of 10 Old Jun 29th, 2011, 10:46 pm
Re: Just saying Hi
Hey, good on ya Colin! Welcome (formally) to the mad-house....
So did you get in touch with Motohansa? Hope they can sort it for you (dicky ABS) at a "reasonable" price...
Now about going to the Snowy ride and boosting the LT numbers...
post #6 of 10 Old Jun 29th, 2011, 10:50 pm
Re: Just saying Hi
Glad to have another "rider" on board! Hope you get things sorted real soon! Then ENJOY
If we can help, just ask!
J.M.J...
Dcn Channing
post #7 of 10 Old Jun 30th, 2011, 2:51 am Thread Starter
Colinh's Avatar
Re: Just saying Hi
Thanks for the welcome all,
Thanks for the info Chris will book it in with Motohansa next week, need to check it still starts haven't ridden since Easter,
GJPinAU, yeah the dreaded ABS failure, Master caution lite and flashing ABS light, symptoms are not what I have read on the boards anywhere, As long as I do not touch the back brake the front (linked system) brake leaver puts the brakes on (real hard) if you are not ready for it, it nearly throws you over the front. As soon as you touch the rear pedal the brakes revert to emergency braking only (soft braking and hard to pull the front lever) from then on, the brakes had been bled in the past which did not cure the symptom, one thing whilst checking I found the rear ABS sensor with a reading greater than 10Mohm (which doesn't sound right) but I think this is also the speed sensor for the speedo and it is working ok. so the reading may be a furfy. Also had some problems after towing a trailer in the wet weather of easter, RH indicator came on with the brake lights then lost RH indicator (front and rear) also no tale light or brake light after disconnecting the trailer. So two problems one I expect to be expensive parts and the other will need some searching.
Colinh is offline
post #8 of 10 Old Aug 7th, 2011, 8:53 pm
Re: Just saying Hi
Hey Colin, hows the bike going..... got it back yet?
post #9 of 10 Old Aug 8th, 2011, 9:34 pm Thread Starter
Colinh's Avatar
Re: Just saying Hi
Yes, no, maybe.
Got it back after ABS pump and other work, after about 300klms, got the alternating 1hz flashing abs, master caution signal, checked the reservoir and it was low, sent it back as was putting new tyres on it anyway, they could not find any leaks and there is no evidence of leaks, so last week got it back after they toped up the fluid (air in the system working its way through maybe?) Jumped on the bike yesterday morning and, the bloody lights are flashing 1hz again. Thinking low fluid level again, meaning the only place the fluid can be leaking and not show itself maybe in the new ABS pump internally. Rode it home last night and no flashing lights, if they come on again will book it in again.
Colinh is offline
post #10 of 10 Old Aug 14th, 2011, 11:35 pm
PhillWard's Avatar
Cool Re: Just saying Hi
Originally Posted by Colinh
Yes, no, maybe.
Hmmmmmmm sounds a bit odd....worth letting whoever is doing your repairs that the ABS warning lights activated....just to keep them aware of the history file....
Phill
1950 Sunbeam 500cc S7 Combo
19XX BSA 500cc single B33
1960 Triumph 650cc Tiger 110
1970 Honda 750cc four K1
1999 K1200LT "Beryl Beemer"
Ulysses 18430
PhillWard is offline
