Speedo flicker - BMW Luxury Touring Community
post #1 of 7 Old Sep 2nd, 2010, 11:41 pm Thread Starter
Axle's Avatar
Speedo flicker
Hi all
I have a problem with the speedo needle fluctuating up to 40kph while the engine is idling, I can actually see the odometer spinning does any one have any clues, I have just replaced the battery so its not that, it has been doing it for a fair while and mainly when I first start the motor
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #2 of 7 Old Sep 3rd, 2010, 1:43 am
Miles of Smiles
Hilton's Avatar
Smile Re: Speedo flicker
Hi Axel, seem to remember an issue with the feed cable from the rear drive. Check for abrasion near the brake line support. HTH
Jenna: Ocean Blue '06
Rena: The Committee.
ET4 Thing 1
ET4 Thing 2
Hilton is offline
post #3 of 7 Old Sep 7th, 2010, 1:50 am
PhillWard's Avatar
Cool Re: Speedo flicker
"Axel" ??? is this a new spelling for our friend down south?hahhah
yep the old abraided speedo sensor cable eminating from the rear drive...I shoulda spliced mine with an extra bit of cable when I was changing out the olde rubber brake lines and had the RHS rear side panel off. Started to flicker, then completly died for a month or two (means yer odometer is not ticking over though)....eventually I got to place the cable in a position that the conductors are made, so the speedo works fine, but as you can see from the pix the stress on the cable has even broken the outer sheath protection....just another job to do <sigh>
cheers
Name:	DSCF1055 1280x960.jpg
Phill
1950 Sunbeam 500cc S7 Combo
19XX BSA 500cc single B33
1960 Triumph 650cc Tiger 110
1970 Honda 750cc four K1
1999 K1200LT "Beryl Beemer"
Ulysses 18430
PhillWard is offline
post #4 of 7 Old Sep 7th, 2010, 3:09 am Thread Starter
Axle's Avatar
Re: Speedo flicker
thanks guys
I have cut all the plastic ties off and had a look at the cable but didnt see anything wrong, riggled the cable with the bike idling over nada!! oh well maybe the new battery has done something
Regards Linton
2002 K1200LT
My Toys
1976 Datsun 260Z
Axle is offline
post #5 of 7 Old Sep 7th, 2010, 3:38 am
Re: Speedo flicker
Interesting.... I had that problem on my K75RT for a while, trying to think of what I did that caused it to start, and then what I did to get it to stop!
If I remember I'll post back... but it was a few years ago now...
post #6 of 7 Old Sep 7th, 2010, 5:27 am
Re: Speedo flicker
Originally Posted by Axle
thanks guys
One other item to check is the sensor atop the final drive unit. Undo the screw and wiggle out the black sensor; clean the tip and reinstall. Check result.
Good luck on finding the gremlin, Axle.
Edit: actually, I don't think a frayed cable NOR a dirty sensor should affect the odometer and make it spin while engine is at idle. Usually the bad result of either is evident when there is up/down movement of the drive train while riding. Check the sensor anyway - just prolly not the cure.
post #7 of 7 Old Sep 8th, 2010, 9:04 am
Re: Speedo flicker
Linton, just remembered that my problem was caused by my mobile phone at the time (Nokia)... I had it mounted in a holder on the bike dash, and for some reason when I was sitting at the lights waiting the rev counter would start playing up, and the km meter actually started running backward !!... so I guess some sort of electrical interference causing it? Never did figure it out.... had to remove the phone holder.
hope you have better luck.
speedo vs. gps speed Red_5 K1200LT 23 Sep 22nd, 2009 1:23 am
My speedo is fixed !!! STARFIGHTER RT Series 6 Dec 26th, 2008 5:06 pm
Speedo Fix ndmunro K1200LT 1 Aug 4th, 2007 8:00 pm
Speedo failure 1st bustedknuckles K1200LT 6 Feb 15th, 2007 9:17 pm
speedo correction for older RT retiredjj RT Series 0 Sep 13th, 2006 10:18 pm
