HID Hi Beam wires - BMW Luxury Touring Community
post #1 of 5 Old Dec 11th, 2009, 7:14 pm Thread Starter
harrowbmw's Avatar
HID Hi Beam wires
Greetings guys.
I hope you're all getting geared up for the festive season. Just one thing....keep it safe.
My DDM HID kits arrived last week. I purchased the H7 and H3 kits. The low beam really was snap out the old bulb and clip in the new HID bulb, drill the 22mm hole in the back cover, pass the wiring loom through and tie up the ballast and away. However, it seems BMW in its infinite wisdom use a unique hi beam bulb holder in there. What is the process in modifying the bulb holder to allow the HID bulb to function?
Cheers to all
Paul
sa.
1999 K1200LT Champagne "Bismarck"
1983 base K100 "Bavarian Belle"
harrowbmw is offline
post #2 of 5 Old Jan 5th, 2010, 3:12 am
Re: HID Hi Beam wires
Paul, I just joined the group and this is my first post. I installed the HID H3 kit to Kay just before leaving for Queensland at Chrismas time. I had to drill, ream & file out most of the plastic part of the holder before the globe would fit through, but then had the problem that the globe would not stay in place, so used Hi-temp silicone to hold it there. A small problem surfaced in that the globe is not exactly positioned right, so the hi beam was too high in relation to the lo beam, so I adjusted it all the way down, resulting in a lo beam that is too low. I will correct that when I get home, when I install the lo beam kit I ordered. The hi beam is SO much brighter than lo, that I straight away realised I needed both!
PeterVadas is offline
post #3 of 5 Old Jan 6th, 2010, 5:48 am
Hi Paul (& welcome Peter!)
If I recall correctly, when I did mine I did some surgery on the tabs of the bulb.... not the holder
yep.. just did a thread search, here's what I wrote at the time..
"With the high beam (H11) I'd read the comments of others about not fitting, and looked closely at the plastic tabs. The flatter top tab is fine, but the 2 lower angled tabs are a little too long, and too wide at the bottom edge. I used a fine Dremel tip to cut down these 2 edges until the bulb could fit snugly into the socket like the original halogen. No need to hot glue or use any tape or adhesive."
These were with Fashtek group buy bulbs, dont know if they are same as yours...
Hope you got it together OK.
best
[SIGPIC][/SIGPIC]
post #4 of 5 Old Jan 11th, 2010, 6:57 am
onions's Avatar
Hi all,
Yep, same deal as Chris with me...worked on the bulb not the housing...
Cheers and hope all are well,
Ian
Ian
Melbourne, Australia
2000 K1200LT Grey - 'The Airbus'
onions is offline
post #5 of 5 Old Feb 3rd, 2010, 11:23 pm Thread Starter
harrowbmw's Avatar
Thanks for that info gentlemen. It's very much appreciated.
I'm also toying with the idea of purchasing the new Zumo 660 too. I've been running my super faithful Nuvi 760 for three years now without problems, but I'm waiting for vibes or a little moisture to take its toll on this amazing GPS unit. I'd hate for it to die that way...it deserves so much better. I guess I'll just keep it for the cars and finally pull my finger out and stop trying to save a few bucks and get the bike dedicated Zumo model.
Cheers gents.
Paul Harrington
E: [email protected]
HID Low beam problems ipokebadgers Lighting 7 Apr 27th, 2010 12:26 am
HI LO HID Installation on 99 K1200LT With Pics ! JPSpen Lighting 37 Jul 13th, 2008 12:44 am
Hid Hi Beam murray Lighting 36 Nov 24th, 2007 11:45 am
HID High Beam on '99 LT dlbushey Lighting 4 Jan 24th, 2007 10:56 pm
HID High Beam on '99 LT dlbushey Lighting 2 Jan 23rd, 2007 2:58 pm
