EOI - Rear Drive Yoke - BMW Luxury Touring Community
post #1 of 5 Old Jun 26th, 2009, 5:26 am Thread Starter
big dog's Avatar
G'day all
Slowly getting my bits and pieces together for the trike conversion. I just recently did the clutch plate swap and was able to get some confirmed measurements for the trike frame. I'm now looking at how I can tie in the Commodore diff to the BMW drive shaft, might be able to convert a final drive yoke (the one actually attached to the FD) onto a bolt on base plate to the Commodore diff. Anyone have a dead FD hanging around in their shed that they may be willing to part with this yoke for a reasonable price? I'd be greatly interested.
On another note, anyone doing the Nullabor next year for the Ulysses AGM?
Cheers
David
Regards
Big Dog
'04 K1200LT
Ulysses #33984
Cogito Ergo Sum: I think, therefore I am.
What am I?
big dog is offline
post #2 of 5 Old Jul 14th, 2009, 2:13 am
Re: EOI - Rear Drive Yoke
thought someone better say hello to you Dave... ;-)
no, no spare final drives... only got one and I want to keep it
not planning to do the Nullabor for the Perth meet either (damn, I couldn't even make it to Penrith!)
But I still hold a faint hope of doing the big circle later next year, if work-stuff times out OK... guess that will involve the long straight bit at some point, just a few months later on.
Hows the rebuild going?
cheers
post #3 of 5 Old Jul 14th, 2009, 5:50 am
Cheers
David
About a dozen of us so far from Macedon Ranges. I don't think there'll be much casual accommodation across the Nullabor that week (or weeks, there and back)
Heli is offline
post #4 of 5 Old Jul 14th, 2009, 10:27 am
battlestar's Avatar
Question Re: EOI - Rear Drive Yoke
Hi David
What exactly was involved in the clutch plate swap and what did you swap it to/for?
Brett
'03 K1200LT EX Night Black
'89 K100LT
'81 Ducati SD900
battlestar is offline
post #5 of 5 Old Jul 18th, 2009, 12:24 am Thread Starter
big dog's Avatar
Thanks for everyones reply. At this stage Mrs Dog and I are looking at the lemming run across the Nullarbor, depends on finances and how she goes with her rhuematoid arthiritis once we're on the trip. I don't think that we will have the funds to complete the trike coversion before the westerly run but I'm aiming for later next year doing the swap over.
As for the universal joint, I've got a couple of ideas floating around in the brain so we'll see what happens over the next few months.
Brett, the clutch swap out is heavily written about on the forum and you can find the details in the Hall of Wisdom. Reader's Digest version:
- Read the workshop manually very, very closely and there will still be things you miss.
Couple of tips when doing it:
- Before you remove the upper gearbox bolt from the frame, put some chocks under the motor. Makes it easier to drop the frame back over the box than lift motor and drop frame. This isn't mentioned in the manual
- Read the electrical section of the manual, it will tell you how to remove the gear shift indicator properly. Not like my effort where on removing it, it fell apart on me and now doesn't work. Getting replaced ATM. I originally thought this could've been my problem with the lack of start but not now.
- When re-assembling the reversing unit siwth assembly, watch out for the little grey sensors inside it, they are fragile and break easy. When you put the cam type assembly inside, use caution.Yes, you guessed it. This looks like it could be my problem at the moment of the bike not starting, the computer thinks it's already in reverse and won't turn the starter motor over. Getting replaced ATM.
- You don't have to remove the fuel injection rail as it says on the book.
- Allow at least 3 days to do the job and that's with all the tools needed. I spent a lot of time fabricating clutch plate pullers, centering tubes and guides just to get to the next stage. Also handy if you have friends or family with mobile hoists and heavy duty jacks.
- It's easier to have the centre stand / side stand arrangment removed from the bottom of the box.
I know I could've taken the bike to a dealer or mechanic to get the job done, but I'd rather get to know my big girl like this and do the work myself. I'd recommend Munich Motorcycles in Perth to get your spare parts, I saved at least $250 on getting the parts form the west coast of the country including the overnight freight costs, than going to one of the east coast dealers.
Enjoy
Regards
Big Dog
'04 K1200LT
Ulysses #33984
What am I?
big dog is offline
Rear Drive Survey Results eljeffe K1200LT 10 Dec 9th, 2007 3:53 am
Oil Leaking from Rear Wheel Drive Clamping Strap sully2028 K1200LT 2 Oct 22nd, 2007 5:03 pm
Another rear drive bites the dust (possibly).... ustasub K1200LT 10 Oct 5th, 2007 7:23 pm
Tools needed to change out rear drive? pdrstraw K1200LT 5 Jun 29th, 2006 9:36 am
