changed 02 sensor - BMW Luxury Touring Community
 6Likes
  • 3 Post By Axle
  • 1 Post By bmwcoolk1200
  • 2 Post By Axle
post #1 of 6 Old Jun 8th, 2017, 6:55 am Thread Starter
Axle's Avatar
changed 02 sensor
Well after a long time putting up with the engine at idle have a cough and flutter, and stumbling, seemed like ignition fault, slowly I have been trying to fix it during routine servicing and what not, today I changed the only thing left the 02 sensor, the diagnostic tool didn't detect a problem, the engine is now idling slightly faster, seems to go a lot better and no more stumbles, I have only road tested it and not done any trips yet but i believe i might have "stumbled" haha on the problem. was averaging about 5.8 L/P100km on a trip which made me think it was not the cause. got a days ride coming up next week then I should know for sure.
cws, Nil_Time and bmwcoolk1200 like this.
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #2 of 6 Old Jun 8th, 2017, 8:08 am
bmwcoolk1200's Avatar
Re: changed 02 sensor
Good deal Linton. Once had a Nissan Maxima that ate o2 sensors for breakfast. That system was so sensitive that if the sensor got a tiny bit slow in switching, it would set a code and I would swap it out and go on. All my other vehicles never had any issue with the sensors but that doesn't mean that they were still running at an optimal setting, it just meant that it was still within design tolerance. I suspect if you compared a plot of the old one to the new one, you would see some difference but still enough within spec that it would not code.
Axle likes this.
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
post #3 of 6 Old Jun 8th, 2017, 5:43 pm
GaryEm's Avatar
That sounds just like my 03 it's been doing it a long time I done a lot of other things
I was wondering did the sensor come out all right for ya That's always been my hold back on it thinking I might strip it trying to take out
GaryEm is offline
post #4 of 6 Old Jun 8th, 2017, 7:05 pm Thread Starter
Axle's Avatar
Gary I blew my gearbox up a while ago turns out about (18 mths ago) while the exhaust was off I removed the 02 sensor and attempted to clean it, when I refitted it I put never seize on the threads. Yesterday I had to use a cold chisel to crack it loose then it came out easy. I think if I was doing this for the first time for the price of 4 new header gaskets and a little bit of time, I would remove the entire exhaust to change it. I had to remove the lower fairing, gear linkages, LH foot plate just to get at it and still couldn't get a spanner on it. .
Regards Linton
2002 K1200LT
My Toys
1976 Datsun 260Z
Axle is offline
post #5 of 6 Old Jun 13th, 2017, 12:57 pm
GaryEm's Avatar
Thanks Axle for the info I ordered one of those Irwin tool 53916 Impact bolt grip off amazon Its got a 5 star reveiw for the sensor that are hard to get off
Gary
2003 K1200LT
GaryEm is offline
post #6 of 6 Old Jul 2nd, 2017, 5:41 am Thread Starter
Axle's Avatar
Managed to get my first ride in today since fitting the sensor, have to say its running sweeter than it has for a long time 5.2l/100 @ 100kph, (45mpg.) seems to have much more power. and pulls like train
cws and Nil_Time like this.
Regards Linton
2002 K1200LT
My Toys
1976 Datsun 260Z
Axle is offline
Final Drive Changed, now ABS/Speed sensor problems vladhd RT Series 0 Jul 22nd, 2016 6:20 am
Help, O2 sensor cables mixed! pozo_izquierdo K1200LT 4 Oct 20th, 2015 11:24 pm
Beryl Beemer Engine oil changes and filter replacements PhillWard Australia, New Zealand, and AsiaPac 1 May 28th, 2013 1:05 am
Rain Sensor Problem - X5 bbbngai Chit Chat 15 Nov 10th, 2008 7:43 pm
Question on Oxygen Sensor MNTodd K1200LT 1 Sep 21st, 2008 4:05 pm
