wheel bearings - BMW Luxury Touring Community
 2Likes
  • 1 Post By Axle
  • 1 Post By saddleman
post #1 of 4 Old Jul 19th, 2015, 4:48 am Thread Starter
Axle's Avatar
wheel bearings
changed the front wheel bearings today, what a prick of a job
they are both interference fit, couldn't knock them out with the pipe thingy that's between the bearings. So I borrowed an internal bearing puller from my local bike shop, very nice of them, and with much grunting swearing and heat I got them out. Don't attempt this yourself if you don't have the correct tools it is near on impossible to get them out. Also note the tricky circlip hiding under the seal.
I am waiting for new wave washers for the rotor and the bearing seal to come from Melbourne oh by the way I only intended to fix the rotor, the bearings were extra. I bypassed the BMW dealer and got bearings from a bearing shop $8 for the smaller one and $25 for the other so I saved about $70.00 got to be happy with that
Nil_Time likes this.
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #2 of 4 Old Jul 19th, 2015, 7:43 am
Enjoy The Ride
saddleman's Avatar
Re: wheel bearings
Did you heat the wheel with a heat gun before you removed the bearings & again before you installed them ?.
Patric likes this.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #3 of 4 Old Jul 19th, 2015, 6:58 pm Thread Starter
Axle's Avatar
Re: wheel bearings
yes I did they were still very hard to get out, the puller did the trick I heated the hub again to put back in but I had to tap the larger bearing in the last 3 mm to seat it
Cheers
Regards Linton
2002 K1200LT
My Toys
1976 Datsun 260Z
Axle is offline
post #4 of 4 Old Jul 19th, 2015, 9:26 pm
Bighopper's Avatar
Re: wheel bearings
Cheers
Just did the same job on my '06 LT. I used a propane torch to heat the hub, this made the job a lot easier to remove the bearings. I used a 2 leg puller that I had to use a flat blade screw drive jammed between the legs so they didn't come off the inner race of the bearing. The 2nd bearing I just heated the hub & punched out with a larger piece of pipe.
For the install I heated the hub to around 170F & I also placed the bearings in the freezer for 30 mins, they just dropped into the hub.
BIGHOPPER (Phil)
BGB 602
2006 K1200LT Grey
1973 Norton Interstate
1965 Atlas 750
2014 Tour Balkans
2017 3 mth tour of Australia
2018 Tour Namibia,Botswana, Zimbabwe
2019 Tour Peru
2020 Tour Greece (Sept/Oct)
Bighopper is offline
Electronic Cruise Control - R1150RT LaChuparosa RT Series 10 Feb 6th, 2020 10:38 pm
Front wheel bearings MartyBlok K1200LT 11 Aug 20th, 2013 7:35 pm
"WHAT"..only 202,580kms outta a set of wheel bearings PhillWard Australia, New Zealand, and AsiaPac 2 Jan 27th, 2012 6:16 pm
front wheel bearings JTEC K1200LT 4 Oct 10th, 2009 10:01 pm
Front Wheel Bearings DanMartin K1200LT 10 Feb 13th, 2008 5:08 pm
