OMG - how much body work is there - BMW Luxury Touring Community
 2Likes
  • 2 Post By brouhaha
post #1 of 2 Old May 3rd, 2015, 1:20 am Thread Starter
Hi all,
As mentioned I'm replacing my old brake lines with Siegler SS lines and whilst the body work is off I thought I'd take the opportunity to replace the air and fuel filter (plus other service jobs)
OMG... how much work was involved in just getting to that air filter :-(
Thought I'd share some photos because we all love photos :-)
Wow, what a lot of work to get at the air filter (not hard work..just lots of it)
What a decent sized fuel tank it certainly puts my old Honda Shadow tank to shame
A pleasant surprise to find an Ohlins unit installed (I found the invoice indicating it was a dealer aftermarket $2488 job in 2005 )
Just hope I can put it all together but I have zip-locked bagged and labelled most screws and bolts just to make it easier..
Interestingly, also found a 2012 dealer invoice for a clutch replacement in 2012 cost $3412 wow ... plus a 55000 K service in 2012 so low miles. I was dubious about the sellers low K's because... I just was :-( but reading the service and technical booklet, I've found its service history up till the 30 000km (18 000M) dealer service and that's stamped 2009. Looks to thus be 30 000km in 2009 so the 58000 km in 2015 bodes well.
There is also a local dealer 55 000 service and full clutch replacement dated 2012 and the invoice list the odometer at 53000 (dealer did a 55 000k service at 53 000km). I'm really only missing the service history from 2009 - 2012 and 2013-2015.
The current low Km looks promising and seem confirmed making this a documented very low Km bike.
cheers, Pete
Cheers, Pete
Nil_Time and bfree like this.
brouhaha is offline
post #2 of 2 Old May 3rd, 2015, 10:53 pm
Re: OMG - how much body work is there
Nice Pete.. looks like you've got a good area to work on her.
And since its recently had a clutch job done, you can put off buying a bike lift to do your services...
Hope you get many good k's out of her... she's only really just broken in.
While you've got her that stripped down, have a think about aftermarket electricals you might want... like upgrading the headlight to an HID, LED driving lights... GPS,
whatever.... much easier to run all the cables now with the tank off than later. I can recommend a Fuzeblock FZ-1 for that extra gear... great unit.
Even if you can't think of any, run a good heavy positive and negative wire along the cable run on the right-side under the tank where the wiring loom lies and tie it off somewhere both ends.... might save you some work later on.
cheers
Body Shop Painting PMitchell K1200LT 2 Feb 17th, 2008 9:56 am
Throttle Body dpaz K1200LT 2 Oct 14th, 2006 6:36 pm
