ABS Magnetic interference from add-ons - BMW Luxury Touring Community
post #1 of 2 Old Sep 14th, 2011, 8:30 am Thread Starter
palarimer's Avatar
While researching HID lighting I came across this article where the positioning of the ballast caused interference with the ABS system. I did a deeper search on Magnetic interference and the ABS systems and this does seem to be true. I'm sure this is a non-brainer for some, but I hadn't considered it myself and am sure others are alike .
This particular quote I found repeated on several sites ....
When installing any "add on" electrical accessories' (CB's, Telephones, Stereos, etc.), it is important that any antennas or other wiring be located away from the ABS computer and sensor wiring. A magnetic field is generated as current flows through this additional wiring. The magnetic field that is created produces electro-magnetic interference (EMI) that can affect the signals from the wheel speed sensor to the ABS computer.
Just something to keep in mind if you suddenly get ABS faults after you add an accessory.
Some links I found ..
http://orca.st.usm.edu/~jmneal/tiburon/hids.htm
http://www.swedishbricks.net/700900FAQ/BrakesABS1.html
http://www.absbrakes.co.uk/brake_job_tips.html
-Preston
-Preston
‘02 K1200 LTC | ’94 K75 RT | '02 R1150 GS
palarimer is offline
post #2 of 2 Old Sep 14th, 2011, 10:17 am
jers99lt's Avatar
Re: ABS Magnetic interference from add-ons
My ABS woes started years after upgrading the lighting. I added my HID balasts, using heavy duty Radioshack velcro, just above the headlight assembly, as such:
I wouldn't think it's an issue in this location.
HTH,
Jer
Jerry Palma
85 R80RT 'Lady in Red'
08 535xi Space Gray metallic
09 328i Silver Convertable
17 X3 Glacier Silver metallic
jers99lt is offline
It works!!! - ABS 2 fault reset (long) BDC K1200LT 114 Nov 24th, 2018 6:17 pm
2000 K1200LT ABS unit disassembly CharlieVT K1200LT 13 Sep 11th, 2011 2:40 pm
ABS unit gone again plonk K1200LT 9 Jun 17th, 2011 4:06 am
