2019 R1250RTW OBD-II Port - BMW Luxury Touring Community
 1Likes
  • 1 Post By Boxflyer
post #1 of 13 Old Mar 3rd, 2019, 5:03 pm Thread Starter
Anyone know the location of the diagnostic port on the 2019 R1250RTW?
deserttan is offline
post #2 of 13 Old Mar 3rd, 2019, 5:32 pm
kellenbenz's Avatar
Re: 2019 R1250RTW OBD-II Port
I'm not totally sure but I think it is the same as the 2017 and newer R1200RT. They are located just in front of the battery on the right side under the black cover that is above the engine. The cover requires a t-25 torx to remove the 2 screws for removal.
Ron
IBA 45658 MOA167437
Total BMW miles 509,508
Goldwing miles 238,383
kellenbenz is offline
post #3 of 13 Old Mar 3rd, 2019, 5:46 pm Thread Starter
Ron
I looked there and didnít see it, I donít think itís round anymore. Thatís where it was located on my 2015.
post #4 of 13 Old Mar 3rd, 2019, 6:16 pm
kellenbenz's Avatar
No it isn't round anymore. They changed it to a normal OBD2 trapezoidal shaped connector. It is lodged in a holder than can be difficult to remove. I tab must be depressed as the unit is pulled out.
IBA 45658 MOA167437
post #5 of 13 Old Apr 13th, 2019, 4:44 am Thread Starter
I found the port, I also found out the GS-911 program has not been updated to include the R1250RT. So it didnít do me much good.
post #6 of 13 Old Apr 13th, 2019, 9:44 am
I just updated my GS-911 WiFi on Wednesday and it showed all new models with the R1250.
beech likes this.
2016 R1200RT
Boxflyer is offline
post #7 of 13 Old Apr 13th, 2019, 1:20 pm Thread Starter
Thanks I will check it again now
post #8 of 13 Old Apr 13th, 2019, 7:04 pm Thread Starter
You were correct, thanks I updated mine and will add my new R1250RT to the list
post #9 of 13 Old May 14th, 2020, 3:44 pm
2019 R1250RT OBDLink LX Not Working (using OBDwiz on a PC)
I just received my OBDLink LX, but I'm having issues connecting to my 2019 R1250RT. I tried it first on my car (Subaru), and it worked fine, so I have the bluetooth paired, so I don't think that's the problem. I'm using a Windows laptop running OBDwiz. When I try to connect I can see that both the interface and ECU are connected (the little lines go from red to yellow. But it seems to hang up on the step trying to run OBD Protocol, which is set to automatic. It attempts three times, it confirms that both the ecu and the IBD are working, then I get the standard message to check 4 things: scan tool is connected, ignition is on, check that OBD2 protocol is set to the right one or Automatic, and that the bike is OBD2 compliant. I pretty sure all that is okay. I have some questions in my mind about whether the ignition is in the correct position. I have the pushbutton start system. I press the button once, all the gauges go through their test, and that's where I leave it. Is that correct? If I press the button again, it turns off everything.
What am I missing? It worked fine on my Subaru. The bluetooth is paired, and the proper lights are flashing on the OBDLink. Thanks in advance.
mverzola is offline
post #10 of 13 Old May 15th, 2020, 7:56 am
PadG's Avatar
Re: 2019 R1250RT OBDLink LX Not Working (using OBDwiz on a PC)
To use it on your RT, you need the MotoScan app, that is only available on Android.
https://www.bmwlt.com/forums/rt-seri...-gs-911-a.html
Pad. Gajajiva
Solon, OH, USA
2007 R1200RT (Sold!)
Once Upon a Time........
1963 Norton Dominator 650 SS
1960 Triumph Thunderbird (6T)
1952 Triumph Thunderbird (6T)
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #11 of 13 Old May 15th, 2020, 10:05 am
I had read your long entry about all this, and it was the basis for my purchasing the OBDLink LX. I understood you (and Amazon's specs) to say that this setup would require an Android smart phone OR a Windows PC or laptop. Is there something different about the R1250RT? The Windows PC worked fine on my Subaru.
mverzola is offline
post #12 of 13 Old May 15th, 2020, 1:16 pm
PadG's Avatar
The key thing is the MotoScan app! Without that app, you won't be able to communicate with the bike! R1250RT should be quite fine, since I do see it listed in the app.
Pad. Gajajiva
Solon, OH, USA
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #13 of 13 Old May 15th, 2020, 3:49 pm
Quick followup: OBDLink Support got back to me and confirmed what PadG said. Unless I want to buy an Android phone, I guess I'm out of luck. I asked the Support guy if the OBDLink MX would work, since it can be used with an iPhone. He said I'd have the same issue....only Android and MotoScan app can be used on some motorcycles. Has anyone tried using the the OBDLink MX with an iPhone running MotoScan? Any luck?
mverzola is offline
2019 BMWís Tame the Tail of the Dragon GaryCulb18 Rides, Rallies and Get-togethers 24 May 7th, 2019 5:04 am
2019 RTE Ride To Eat Northwest TN Saturday April 6, 2019 See the Eagles Deerhead Rides, Rallies and Get-togethers 0 Feb 16th, 2019 11:23 am
Diagnostic Port power capacity JavaDave RT Series 6 Sep 4th, 2017 3:37 pm
com III port wiring layout sittonb K1200LT 0 Jul 2nd, 2011 10:22 am
