K1200lt Clutch Problem - BMW Luxury Touring Community
Thread Tools Display Modes
  #1
Old May 11th, 2006, 1:02 pm
ACKERS ACKERS is offline
Angry K1200lt Clutch Problem
Has Anyone Had Clutch Problems With The Lt.i Have Had The Bike From New,purchased In 2002. It Has Done 10,500 Miles And The Clutch Has Started To Slip. Bmw Have Quoted Me A Price Of Approx 800.00 To Fix It. My Dealer Tells Me This Is Not An Uncommon Fault.i Am Not To Happy With This To Say The Least. Can Anyone Give Me A Bit Of Amunition Please.
Old May 11th, 2006, 1:34 pm
dshealey's Avatar
dshealey dshealey is offline
The most common problem is failure of the clutch slave cylinder, and when it does fail, BMW in their infinite wisdom SEALED it to the rear of the transmission so that the leaking brake fluid has no where to go but through the tranny mainshaft and right into the clutch assembly.
Many of us have taken it on ourselves to drill a drain hole in the bottom of the boss to which the cylinder is mounted onto the tranny so that in the case where the cylinder does fail, the fluid can drain out rather than be forced to the clutch. Cylinder replacement is approx. 3 hours, less than $100 US part, but clutch replacement is MUCH longer, and a lot more expensive.
Also, if either of the transmission main shaft seals fail, you still get clutch contamination. Once the drain hole is drilled, failure of the rear tranny seal will drain out, but the front one will still contaminate the clutch.
__________________
I don't want to achieve immortality through my work...I want to achieve it through not dying.
David Shealey
Dandridge, TN
EX: '01 Black LT, BAT BYKE (Totaled at 110,000 miles)
IBA SS, BB, BBG, 10/10ths.
No bike now, but maybe in the future.
  #3
Old May 13th, 2006, 1:24 pm
Thank You David.that Gives Me A Bit Of Amunition When I Contact Bmw.i Need Them To Give Me A Good Excuse As To Why This Has Happend. So Far My Local Bmw Agent Has Told Me "well Its A Heavy Bike And This Is Not An Uncommon Problem".
Kind Regards
Dave
Ps Hope You Get Back On The Road Soon
  #4
Old May 13th, 2006, 2:00 pm
dshealey's Avatar
-----------------So Far My Local Bmw Agent Has Told Me "well Its A Heavy Bike And This Is Not An Uncommon Problem".
Don't buy that one! If the clutch was worn out (which we almost NEVER see), that excuse could carry a little weight. But, if there is a slave cylinder or seal failure, those absolutely in no way can be attributed to bike weight.
These slave cylinders are failing WAY more than is acceptable.
Strangely, after all the years they have known about it, seems that some of the '05 bikes had slave failures EARLY in life.
On my 2001 LT, I had a tranny seal failure at 400 miles, requiring complete clutch assembly replacement, then at only 4500 miles, the clutch slave failed, requiring yet another clutch assembly replacement, all under warranty. The slave failure could have been accelerated by the leaking transmission oil, so they should have replaced the slave when they did the clutch the first time.
I would argue hard with them if they try to make you pay for the clutch stating the "wear item" crap, if in fact it is slipping because of a fluid leak. The leaks are warranty items, and a slipping clutch because of resulting fluid contamination should also be covered. Have them show you the clutch disk, and if it is not worn down, MAKE them pay for it.
__________________
David Shealey
Dandridge, TN
  #5
Old May 20th, 2006, 2:27 am
Thank You David. I Will Keep You Posted As To The Outcome. The Bike Goes In To My Local Bmw Dealer On The 27th Of June. Your Advice Has Been Very Helpfull. We Are Doing A Tour Of Spain In July And Would Like To Think All Is Going To Be Ok With The Bike. Kind Regards. Dave Acton
  #6
Old May 20th, 2006, 10:04 am
Petre Petre is offline
Are there instructions somewhere on the site on where and how to drill this hole ?
Wouldn't want to drill in the wrong place
  #7
Old May 20th, 2006, 5:16 pm
ecirwin's Avatar
ecirwin ecirwin is offline
As usual Dave is dead on. The slave cylinder is a common failure. My bike has had it replaced 3 times in under 15k miles with two clutches to go along with them. BMW has covered each one under warranty. I bought the bike last year after 2 slaves and one clutch. I know that this is above and beyond what others have seen, but it does show that this is not uncommon.
If the slipping started suddenly and rapidly progressed to the unrideable stage (say less than 100 miles), it is definitely a slave failure. My failure happened close to 2000 miles from home, but fortunately in a town with a dealer. The only town within 500 miles with a dealer. How lucky is that?
I too would like to know where this hole gets drilled. I am sending my seat off to Kontour next week. So, I have about two weeks to do all kinds of maintenance.
Eric
  #8
Old May 22nd, 2006, 1:11 am
meese's Avatar
meese meese is offline
IBR# 366
Just search this site for drill slave cylinder and you'll get lots of useful info, including detailed pics.
__________________
SoCal
'13 Dark Graphite Metallic K16GTLD, 2K miles and counting . . .
'12 Mineral Silver Metallic K16GTLD, 59K miles and gone.
'09 Magnesium Beige Metallic K13GT, 32,690 miles & now rebuilt!
'07 Dark Graphite Metallic K12GT, 138,220 miles & now rebuilt!
'02 Mauve Metallic K12LTC, 106K miles and sold
BMWLT#145, IBA# 366, MOA# 111996, SCMA# 24032
All lower 48 states plus Alaska on the K13GT in two weeks . . .
Some people see the gas tank as half empty. Some see it as half full. All I care is that I know where the next tankful is coming from . . .
You may not post new threads
You may not post replies
Forum Jump
Slipping Clutch - Clutch Slave Cylinder lhendrick K1200LT 24 Mar 29th, 2009 7:02 pm
Help, clutch lever does not feel right! paulcbrowne K1200LT 1 Apr 13th, 2006 12:55 pm
Electrical Problem 2002 k1200lt reds K1200LT 1 Apr 7th, 2006 4:53 am
Starter Sprag Clutch TimVipond K1200LT 3 Nov 17th, 2005 2:33 pm
New LT w/a Clutch Problem hschisler K1200LT 14 Oct 20th, 2005 7:27 am
