Loose body panel screw - BMW Luxury Touring Community
Thread Tools Display Modes
  #1
Old Sep 2nd, 2013, 4:38 pm
Toby6938 Toby6938 is offline
I found the forward most t25 screw on the brake side body panel loose, (holds the pointy end firm). A '13 RT and my 1st. The screw won't tighten or loosen because I can't figure out how to grasp/stabilize the retaining clip into which the screw goes and I'm presuming it's not supposed to be free turning. A search shows how to remove the panels but no mention of this particular problem. Has anyone had a similar experience? My fingers, which are mostly thumbs, tell me this clip/nut is dislodged or broken off from it's mounting point. Thanks.
Old Sep 2nd, 2013, 5:36 pm
oldspice's Avatar
oldspice oldspice is offline
Re: Loose body panel screw
I've not had this issue on my RT. The (cheap) retaining clip should not spin freely. I'm thinking it may be held on by a plastic tab or something and perhaps yours has broken off. If you can't get behind it with a pliers or some such device to hold the clip while you tighten the screw, you may just want to take the screw out (so you don't lose it) and see if your dealer can give you a hand. The tupperware shouldn't fall off - what with other 1000 screws that hold it all on.
I would suspect, if the part is indeed broken, you'd be able to have the repair done under warranty.
__________________
"Looks like I picked the wrong week to stop sniffing glue..."
2012 BMW R1200RT
1985 Ford Escort L (for Luxury) - Ol' Blue - gone, but not forgotten
BMW MOA 175432
BMW RA 41108
__________________
  #3
Old Sep 2nd, 2013, 6:01 pm
hopz's Avatar
hopz hopz is offline
Yo, Toby...
Welcome on board. I hope you find this board friendly helpful and entertaining.
As for your body panels... let me be presumptuous and say that reading your post suggests, to me, this may be your first BMW and maybe it is still pretty new to you. Let me assure you, first, that there is nothing to be alarmed about. Next, taking the body panels off and the back on is a rite of passage that most of us have gone down.
The expected pattern is for you to be nervous as all get out, then do some research on how they go off/on, then sweat a half day doing to then discover the loose screw probably did/does not have some deep/costly/impossible problem.
After that you will be taking it on/off with no real concerns and doing it will take you about 15 minutes, if you stop to have a beer and watch the ball game. Someday you might just feel like taking it all off, just to poke around, clean a little bit and see how things look.
Welcome aboard.
p.s. if there is a problem let us know if we can help.
__________________
BMW 2005 R1200RT,
BMW R1100S and
CLK 350
Be careful what you think, it may not be true.
  #4
Old Sep 2nd, 2013, 6:14 pm
Good point, I'll show it to the dealer at next service which'll be 12k. Thanks.
  #5
Old Sep 2nd, 2013, 6:20 pm
Then again, taking the panels off sounds like a plan.
  #6
Old Sep 3rd, 2013, 2:55 am
Phillo's Avatar
Phillo Phillo is offline
Dowload video from MAX BMW very helpful if you have never done it before !
  #7
Old Sep 3rd, 2013, 12:04 pm
lkchris's Avatar
lkchris lkchris is offline
The clips should not spin and their mountings are usually designed to prevent this. I'd vote for improperly mounted clip over broken clip mount. The mounting system is in no way chintzy or fragile, but there are some unbeliveably not mechanically inclined folks touching these bikes on occasion.
__________________
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
  #8
Old Sep 3rd, 2013, 8:01 pm
racer7 racer7 is offline
Panel and fastener fit on BMWs is typically excellent.
Something isn't lined up or a wrong screw is subbed or maybe swapped with an existing one elsewhere- are only 2 types used to put the 2 side parts on the camhead fairing and most are the same- all the screws for the pointy piece are the same as are the fasteners.
Just pull that side piece and inspect- then put back. Hopz told you right- many owners get used to servicing their own for which this is needed. The bike is really pretty simply once you get a little practice..
You may not post new threads
You may not post replies
Forum Jump
Body panel removal for transmisson fill? Jim-Mer RT Series 2 Oct 13th, 2012 7:58 pm
little help? remove left body panel Thumperjon K1200LT 2 Jan 8th, 2012 10:38 am
Body Panel Removal Guide hopz RT Series 4 Feb 11th, 2010 12:45 pm
Loose instrument panel... cmattingly K1200LT 8 Aug 9th, 2007 10:05 pm
Oddments Panel Too Loose sogen K1200LT 1 Mar 29th, 2007 12:52 pm
