R1200rt - BMW Luxury Touring Community
Thread Tools Display Modes
  #1
Old Jul 13th, 2013, 10:36 pm
Maximus's Avatar
Maximus Maximus is offline
R1200rt
My bike has been in storage for a year and a half. What is recomended to get this bike back up and running frome it's deep sleep?
__________________
Maximus
2007 R 1200 RT
2005 R 1200 RT-sold
Old Jul 14th, 2013, 12:22 am
Hiram's Avatar
Hiram Hiram is offline
Re: R1200rt
Fresh fuel, and a correct dose of Sea Foam.....Check your oil level, ride it to op temperature then change your fluids...Not a big deal really.
Sea Foam is a magical substance that will stabilize, clean, and otherwise treat your whole system, down to the injector nozzles. Kinda like a Listerine for Gas motors. Techron works good too, and BMW makes their own stuff, but they also approve the Techron. I bought my recent 04 and it had set up for 3 years, with the occasional start and ride around the block. I drained and refilled and used Techron for the first 2 tanks (it was on hand), and sea foam every tank there after for 5 tank loads. PRIOR to sync'ing TBs, etc. The results are immediate and amazing. It went from a rough idle, poor cold start beast to a kitty cat in 1 tank, and my rough 600rpm idle went to 1k and smooth in 2 tanks, THEN I sync'd and fine tuned. Also (I don't know about the newer 1200s) if you hear a rattle internally when cold that doesn't really go away when warm, check your cam chain tensioner. Mine did it and I popped that sucker out and it was cruddy and sticky. Cleaned her up and voila, no more noise (other than the normal Boxer Concert of Purity and Righteousness)
Good luck, and welcome back from wherever the hell you were that caused you to neglect and not take care of your duties as a Boxer Jockey. Poor bike...In that cold dark place with no wind in it's cooling fins....No sweet slippery oil oozing around and caressing its inner most bearings, no spark coursing through it's wires causing it to explode with precise chaos and sumptuous harmony. No subtle manipulation of it's sensitive throttle and curvaceous clutch... Nay...She patiently waited, loyal, proud despite her dusty haze wondering if she would ever feel that torque curve pulsing through her prop shaft ever again.....Never straying, never complaining...If only women had Boxer engines.....
In other words RIDE THE SHIITE OUT OF IT...LOL
__________________
Ride it, Live it, Love it...It don't last forever
  #3
Old Jul 14th, 2013, 6:39 am
6speedTi's Avatar
6speedTi 6speedTi is offline
Re: R1200rt
If you have any fuel in the tank I would drain it out. Fuel with Ethanol has about a six month shelf life. Fuel without Ethanol has about a one year shelf life. If the oil in the crankcase has been in use before storage I would change it. Even Synthetic oil has a one year in use service life. Petroleum based oils are less.
__________________
2012 R1200RT
1985 T5 Vespa
2007 Piaggio X9 500 EVO
  #4
Old Jul 14th, 2013, 7:20 am
hopz's Avatar
hopz hopz is offline
Re: R1200rt
All the above is spot-on but if you prefer...
Check tire pressure...
Start her up and ride down to the gas station and fill'er up with Chevron premium and maybe add in a dose of Techron.
Then I highly advise a good long ride.
__________________
BMW 2005 R1200RT,
BMW R1100S and
CLK 350
Be careful what you think, it may not be true.
  #5
Old Jul 14th, 2013, 12:27 pm
LeftCoastMan's Avatar
LeftCoastMan LeftCoastMan is offline
Re: R1200rt
I'm not sure if this is a good recommendation, but if your bike has just been sitting there without a battery tender, wouldn't it be best to replace the battery after 18 months of being dead? I would, but I'm not sure it's necessary.
__________________
"Extraordinary claims require extraordinary evidence." That's why we know the earth is 4.5 billion years old, that vaccines are safe and effective, that GMO crops don't cause cancer, that anthropogenic global warming is a thing, and that sasquatch does not exist. But mostly it means that any oil works as well as another one.
On my fourth RT, a 2011 beast with all the cool stuff.
  #6
Old Jul 14th, 2013, 2:43 pm
jeffonthefly's Avatar
jeffonthefly jeffonthefly is offline
Re: R1200rt
Originally Posted by Hiram
.... Cleaned her up and voila, no more noise (other than the normal Boxer Concert of Purity and Righteousness)
Well said Hiram! ...
__________________
2012 BMW R1200RT
Airbus 319/320/321
  #7
Old Jul 14th, 2013, 8:35 pm
racer7 racer7 is offline
Re: R1200rt
First thing is hope you don't have a set of gummed injectors. EtOH containing fuel is pretty good at mucking them up if they sit that long- hope yours still function OK. If it doesn't start of they hang open and it blows fuel you'll know...
  #8
Old Jul 14th, 2013, 8:45 pm
tactical1 tactical1 is offline
Re: R1200rt
Good suggestions all - I'd check the air filter for critters and change the brake fluid. As I recall, BMW recommends an annual brake fluid change.
  #9
Old Jul 14th, 2013, 8:51 pm
Re: R1200rt
Its actually every 2 except for new bikes which are 1 yr from placing in service, allowing for time since manufacture, etc, probably
  #10
Old Jul 17th, 2013, 8:53 am
rapz's Avatar
rapz rapz is offline
Re: R1200rt
Ditto on SeaFoam. Check tires for cracks. Battery. Ride it a good while.
__________________
Website: www.airheadmoto.com
2013 BMW 90th Anniversary R1200RT
1979 BMW R100RT
2008 Harley Davidson 105th Anniversary Ultra Classic
IBA No. 58411
  #11
Old Dec 31st, 2013, 3:17 pm
Maximus's Avatar
Re: R1200rt
The Hell was called Afghanistan……..
__________________
Maximus
2007 R 1200 RT
2005 R 1200 RT-sold
  #12
Old Dec 31st, 2013, 3:58 pm
Dann323's Avatar
Dann323 Dann323 is offline
Re: R1200rt
Welcome back
Ride safe
__________________
Daniel
If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
IBA # 56396
MOA # 171966
R1200RT 2007
You may not post new threads
You may not post replies
Forum Jump
R1200RT Vibration issues……. Xavier6162 RT Series 122 Jul 28th, 2013 1:49 pm
Are there any issues with the 2006 R1200RT? Humbucker RT Series 11 Sep 12th, 2012 7:17 am
Is a used 2007 R1200RT a good choice vs. the newer ones? Humbucker RT Series 13 Dec 8th, 2010 7:49 pm
Is the R1150RT a good(cheap) alternative to the R1200RT? Humbucker RT Series 12 Jul 12th, 2010 10:07 am
Looking at the R1200RT (again) as my next bike. Humbucker RT Series 2 Jun 6th, 2010 12:56 pm
Copyright ©2013, VerticalScope Inc
