K1200LT Trunk Latch - BMW Luxury Touring Community
Thread Tools Display Modes
  #1
Old Jun 27th, 2013, 12:51 pm
ltdrum ltdrum is offline
Cool K1200LT Trunk Latch
Hi Guys, just bought an LT, and no sooner had I got it home the dreaded trunk latch snapped at the corner (Bugger!). I live in the UK and was wondering if anyone knows if a replacement is available here. Tried to repair it with Araldite metal epoxy and some metal reinforcing strips but it hasn't worked. Thanks in advance to anyone with helpful info.
Old Jun 27th, 2013, 1:18 pm
bruce60's Avatar
bruce60 bruce60 is offline
Location: Oak Park, Ventura county (Los Angeles), CA, USA
Re: K1200LT Trunk Latch
there there is a vendor on the homepage LTtrunk latch . Com, that has repair kits,
good lucK! post pictures and a story about your repair
__________________
Bruce - pilot
Belynda - pillion
Oak Park, CA.
'99 K1200LT Champagne, 25,600mi
'04 R1150R Silver, 18,200 mi
  #3
Old Jun 27th, 2013, 1:50 pm
AlaskaFish's Avatar
AlaskaFish AlaskaFish is offline
Wink Re: K1200LT Trunk Latch
And his is better quality than the OEM latch! Not cheap, but worth it. And cheaper than the whole Trunk, which I believe is what BMW would try to sell you.
__________________
John & Marilyn Fisher
'00 K1200LTC "Katie"
'95 Triumph "Tigger"
'12 Triumph 800XC "Tigger II" (RIP)
'12 Triumph 1200 Explorer "Shadow Tigger"
Hillsboro, Oregon
  #4
Old Jun 27th, 2013, 1:57 pm
gary45 gary45 is online now
the vendor does not recommend it but I used the fix it before it breaks kit to put everything together in the right place/alignment and then epoxied it also reinforcing it, has
been OK
the assy needs to be lubricated which is as far as I am concerned the main problem why it does break, it probably stays cleaner dry but eventually to much friction
__________________
Gary
2000 K1200LT
Past rides
1992 K1100LT
2000 V Star 650/Velorex sidecar
1985 K100RT
1965 R60/2
1960 AJS 500 single
  #5
Old Jun 27th, 2013, 2:02 pm
JNW003's Avatar
JNW003 JNW003 is offline
Cool Re: K1200LT Trunk Latch
I was afraid of having what happened to you happen to me, so I bought a "Fix-it-Before-It-Breaks" kit from the sponsor vendor. It is expensive (not like the "fix it after you broke it" version though), but is very well made and I don't anticipate ever needing to repair the latch now. Good luck on your project, if you haven't fixed it yet...!!
  #6
Old Jun 27th, 2013, 4:06 pm
deanwoolsey's Avatar
deanwoolsey deanwoolsey is online now
The latch assembly is not available without the trunk assembly. Might check E-bay. The fix-it-after-it-breaks kits are a quality product.
__________________
  #7
Old Jun 27th, 2013, 4:32 pm
Thanks so much for all your replies. I think I may have to just bite the bullet and buy the replacement latch. Hopefully he will ship to the UK
  #8
Old Jun 27th, 2013, 5:07 pm
K100Dennis's Avatar
K100Dennis K100Dennis is offline
Yes, the trunk latch kit is the go, excellent quality product. I fitted the "fix it before it breaks" kit to my '05, but the real answer is to keep the whole linkage system lubricated, including the 2 latch dogs where they slide over the pins and to apply downward pressure on the lid with 1 hand when opening & closing. The whole latch system has a nicer feel to it once the latch kit is installed. Very poor piece of OEM engineering, I always wonder if BMW let this type of thing out to others (suppliers).
__________________
Dennis
1987 Yamaha TY250R
1991 Aprilia Climber 280
1988 K100RT (sold, still missed)
2005 K1200LTE Light yellow metallic
  #9
Old Jun 27th, 2013, 5:23 pm
If they had been a bit more shrewd BMW could have made good money with a replacement kit! Fools! Ha Ha.
  #10
Old Jun 27th, 2013, 5:47 pm
azccj azccj is offline
I just installed the fix it before it breaks kit in my LT. I took off the trunk and put it upside down to install the kit. It went in without any problem and now the handle should last the lifetime of the bike....I hope. The only thing I would change with the kit, is to counter sink the screws so they don't stick out so much. They don't hit the painted part of the case but they are very close. I turned the heads on all the screws down a bit on my lathe and now the handle would rub on the case before the screws would.
The fix it before it breaks kit is a very nice piece of work, and very reasonable priced for the amount of machine required to make it.
  #11
Old Jun 27th, 2013, 7:21 pm
BecketMa's Avatar
BecketMa BecketMa is offline
did your upper right or left corner break? i've been thinkin that it should be possible to make one good, re-inforced one out of two units with opposite corners broken?
there must be some bonding agent to hold two pieces of the latch together? and then make a plate with a hole in in for the key, and bondthat to the entire latch?
Bob
__________________
"He was a foul caricature of himself, a man with no soul, no inner convictions, with the integrity of a hyena, and the style of a poison toad." H. S. Thompson
  #12
Old Jun 28th, 2013, 10:18 am
alexhallmalta alexhallmalta is offline
I just replaced my broken latch last night with the unit supplied from the vendor on this forum. It is CNC routered billet aluminium, first class machining and was a doddle to put together.
The only messy parts were drilling out the old blind rivets and grinding away two little tabs. An hours job max and all done on the dining room table, as I've had the trunk off for a lighter bike.
Cannot recommend the part highly enough, however it is fairly dear.
Al
__________________
2000 BMW K1200LT, 32K
1982 Suzuki GS 650G, 15K
1950 Douglas Mk4 Sport, 6,125 Miles,
1948 Douglas Mk3 Sport 1,813 Miles,
  #13
Old Jun 28th, 2013, 12:08 pm
gbaltyn's Avatar
gbaltyn gbaltyn is offline
How long did it take to install the "Fix it before it breaks" units with and without the whole truck being removed?
  #14
Old Jun 28th, 2013, 12:10 pm
norton's Avatar
norton norton is offline
+1 on the fix it before my SO with no fenesse breaks it latch kit.
  #15
Old Jun 28th, 2013, 12:12 pm
norton's Avatar
It took about an hour leaving the trunk on the bike, but very doable.
  #16
Old Jun 29th, 2013, 12:39 am
JNW003's Avatar
I tried first by leaving it on the bike, but my old eyes and working upside down didn't work for me, so I ended up taking the trunk off. It was much easier doing it that way. I took my time, and if I had to do it again, I think it would take about 1.5 - 2 hours total, now that I know how to take off the trunk. The hardest part getting off the trunk was figuring out how the interior shell comes out. I have some vinyl pry bars from Harbor Freight that made it much easier to avoid chipping the paint near the edge by the latch... Have fun whichever way you go!
  #17
Old Jul 25th, 2013, 10:49 am
dvhardy dvhardy is offline
go to ascycles.com
you can buy a better part and do it yourself?
  #18
Old Jul 25th, 2013, 10:54 am
AlaskaFish's Avatar
Question Re: K1200LT Trunk Latch
Originally Posted by dvhardy
go to ascycles.com
__________________
Hillsboro, Oregon
  #19
Old Jul 25th, 2013, 4:01 pm
kc5ero kc5ero is offline
Just by looking at the pictures, I am guessing ascycles is distributing the sponsor member product. As mentioned above, expensive but well built and much better than buying a new lower half of the trunk from BMW.
  #20
Old Jul 26th, 2013, 10:21 am
Foiler's Avatar
Foiler Foiler is offline
+1
  #21
Old Mar 20th, 2014, 10:53 pm
Upright's Avatar
Upright Upright is offline
Another happy "Fix It Before It Breaks" customer here. The kit is fantastic quality and comes with detailed instructions. Thanks Evan!
__________________
'99 K1200LTC
'00 R1100RT
'98 H-D Road King Classic
'86 Suzuki Cavalcade LX
'79 Yamaha XS1100
MOA #179460
IBA #57873
  #22
Old Mar 21st, 2014, 2:39 am
vespacar's Avatar
vespacar vespacar is offline
Nothing better to remind you to buy the kit than another members latch breaking. Been meaning to order the kit and just did it now. It looks to be one of those either fix it now cheaply, or roll the dice and fix it for more later. I went with the cheap.
Cheers,
Tross
__________________
2002 K1200lt
2010 Piaggio MP3 500
1982 Lambretta GP225
http://albytross.blogspot.ca/
  #23
Old Mar 21st, 2014, 6:10 am
pkpr1998's Avatar
pkpr1998 pkpr1998 is offline
+1, had mine replaced about 3 years ago, cost was around $ 340 but well worth it. That thing is near indestructible.
__________________
Brett
03 Anthracite-SOLD 6/2013
'13 GTL Dark Graphite
North Georgia
2005 CCR-Tetons
2006 CCR-Braselton
2008 CCR-Midway
2009 CCR-Rapid City
2011 CCR-Boise
2012 CCR-Duluth
2014 CCR-My Hometown
  #24
Old Mar 21st, 2014, 8:29 am
Upright's Avatar
Cheers,
Tross
That's exactly why I did mine this week!
__________________
'99 K1200LTC
'00 R1100RT
'79 Yamaha XS1100
MOA #179460
IBA #57873
  #25
Old Mar 21st, 2014, 9:11 am
C-A-D C-A-D is offline
Location: Helsinki, Finland, Europe, Northern hemisphere
+2
__________________
Born to be wild so why not
http://www.careforthewild.com/
  #26
Old Mar 21st, 2014, 11:04 am
JoeTerry's Avatar
JoeTerry JoeTerry is offline
He must be milling kits like crazy because I ordered mine on Monday of this week too. Must be spring fever and time to do some maintenance before riding season finally arrives (for those of us in the Wisconsin tundra)
__________________
Just Ride
  #27
Old Mar 21st, 2014, 1:07 pm
BilletsGalore BilletsGalore is offline
Thanks for the kind words, guys!! Yeah, there has been a spike in the "Fix It Before It Breaks" kits! And this topic explains that.
FYI, contrary to what has been mentioned here concerning the cause of failure of the BMW component, I'll explain.
Firstly, the OEM handle is a die-cast part. The material is a cheap zinc-like material. The design of the die-cast process for this part is just WRONG! There are major loads between two hinge locations that are only about 3/4 of an inch apart. YET the part hooks around and is connected to the very thin fascia. The reason for this is that the die-casting dies (VERY EXPENSIVE DIES) have a part of the mold that retracts. That is why the hook-shaped feature exists. If the two hinge locations were directly connected (as they are in my Replacement Handle), there would be no issue.
The other major problem is that the latching mechanism within the body of the lower trunk half was manufactured using a "progressive stamping" technique. It starts with a flat sheet and moves through a number of stages where shearing, punching, and forming occurs. THE problem is that the location tolerances of this process are not quite good enough for this application. There is excessive production variation, resulting in inconsistent loads on the closing mechanism--inconsistent from bike-to-bike, as well as side-to-side on a single bike.
Thanks again for the support over the years! I don't get rich from this little product at all, but it is a neat little niche business. And one more thing, the products sold by A&S are my products.
Regards,
Evan
  #28
Old Mar 21st, 2014, 9:47 pm
sweetride's Avatar
sweetride sweetride is offline
Smile Re: K1200LT Trunk Latch
One more satisfied fix it before it breaks customer. Works really well and seems to be more positive latching than before.
__________________
Stan
1999 K1200LT
2006 R1200GS
1996 R850R
  #29
Old Mar 22nd, 2014, 7:06 am
ArkyJohn ArkyJohn is offline
I just received my " fix it before it breaks" kit earlier this week, it looks very well made. My latch doesn't show any signs of failure, but, again I don't want to worry about it breaking while on a trip. Just some preventive maintenance. I hope I can put it on next week.
  #30
Old Mar 22nd, 2014, 10:02 am
cbpip's Avatar
cbpip cbpip is offline
Purchased Fix it Before it Breaks 2 years ago when I purchased the LT. Easy install and great kit to save hundreds in later repairs. If I had not found this forum with all of the wisdom from it's members this would have certainly been an expensive repair.
Quality product and thank you Evan for effort you put into the product!
__________________
2002 K1200LTC Pacific -Blue moon Beemer
2007 VFR800 RWB Interceptor -current
84 Yamaha Venture Royal -departed
84 Honda 750 Interceptor- departed
76 Honda 750 four-departed
65 Pan head (gone)
72 Rickman 6 day Enduro
Too many farkles to list, if you can thinkem they maybe on it
BMWMOA # 189093
BMWBMW LOCAL CHAPTER Member
BMW MARS CHAPTER Member
BMWRA # 41568
  #31
Old Mar 22nd, 2014, 10:08 am
smahon's Avatar
smahon smahon is offline
I'll add that about three years ago, after getting backed into by an oil tanker, I had a keep-it-or-ditch-it decision to make. It was a hard decision, but I chose to keep it. I knew at the time that my decision was for the long term, so it included the fix-it-before-it-breaks. I use my trunk every day and I am another happy customer. And during trips, when that trunck is fully loaded, with another bag loaded on top, the piece of mind offered by the strength of that latch is priceless!
__________________
Steve & Cheryl
'05 LT
  #32
Old Mar 23rd, 2014, 7:36 am
james216's Avatar
james216 james216 is offline
Did you use the replacement latch kit. If so. How hard is it to do?
__________________
2004 K1200LT. Big Mama
1999 Suzuki Intruder VL1500LC. Betty Lou.
I'm a 4 percenter.
  #33
Old Mar 23rd, 2014, 7:58 am
cbpip's Avatar
As long as you haven't aleeady broken the latch handle you can use the "Fix It Before It Breaks" replacement kit. Takes a about an hour or two to replace. Very much worth the price Evan asks. Well engineered.
__________________
65 Pan head (gone)
BMWMOA # 189093
BMWRA # 41568
  #34
Old Mar 23rd, 2014, 10:17 pm
Gruivis's Avatar
Gruivis Gruivis is offline
Is it possible for the latch to break after the Fix is applied? Just wondering if this reduces the risk or completely prevents it from happening.
__________________
Airwolf - 2005 Charcoal LT
2003 Antracite LT - 76K
2001 R1200C 24K
1999 Honda Magna - 5K (RIP)
  #35
Old Mar 24th, 2014, 7:52 am
Sure, anything is possible. But none have broken to date...the kit adds substantial strength and rigidity.
  #36
Old Mar 24th, 2014, 9:12 am
Voyager Voyager is offline
I don't see the vendor list at the home page anymore. How do I order the FIBIB kit?
__________________
2007 K1200LT, VOICE II, Navigator III+, Motorrad Communicator, K7MSW
  #37
Old Mar 24th, 2014, 9:19 am
DanDiver's Avatar
DanDiver DanDiver is online now
When closing the trunk, if you will press down on the top to compress the seal before latching, the parts easily slide into place. This takes the force off of the metal. I kept the stock latch and never felt the need to reinforce it.
Most of the time, because I kept so little in the trunk, I didn't latch it. I don't ever remember it flying up and that was after about 50 K miles and 8 years of daily riding.
__________________
Dano
Tampa, Fl.
12 K1600 GTL
02 K1200 LT (gone but not forgotten)
  #38
Old Mar 24th, 2014, 9:21 am
Dick's Avatar
Dick Dick is offline
It's in the Supporting Vendor forum - drill down thru the forums page for that. HTH.
__________________
Cheers
Dick
Boerne, TXican
  #39
Old Mar 24th, 2014, 9:32 am
I do the same and my wife remembers to do this most of the time. When we have the rack bag on top, that also helps a lot. I also removed the latches when the bike was fairly new and filed down the roughness from the latches so they wouldn't wear the pins so fast (they already had started to wear grooves in the pins). The smoother surface along with some grease lowered the latching effort substantially.
Still thinking that the FIBIB kit might be sound insurance.
__________________
  #40
Old Mar 24th, 2014, 1:43 pm
johnbaker15's Avatar
johnbaker15 johnbaker15 is offline
Here you go, main site http://www.lttrunklatch.com/
Fixit link, http://www.lttrunklatch.com/fix-it-b...-breaks--2.htm
__________________
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
You may not post new threads
You may not post replies
Forum Jump
Help With replacing Trunk Latch seahorst K1200LT 4 Apr 30th, 2011 9:59 pm
Synchronize Trunk Latch Hooks PoppaT K1200LT 3 Sep 20th, 2010 12:46 pm
Trunk Latch PePa K1200LT 0 Aug 15th, 2010 8:37 am
Greetings. Question about LT Trunk Latch Colors BilletsGalore K1200LT 9 Mar 1st, 2009 3:33 pm
K1200 LT Trunk Latch ste6240 K1200LT 15 Apr 18th, 2008 8:21 am
