Electric center stand K1200LT - BMW Luxury Touring Community
Thread Tools Display Modes
  #1
Old Oct 3rd, 2011, 10:38 am
socram socram is offline
Anyone knows where I can find or anyone want to sale a used electric center stand for my 2000 BMW K1200LT, E-mail me at (Ligameccorp98@msn.com)
Marcos Ruiz
Old Oct 3rd, 2011, 9:58 pm
johnbaker15's Avatar
johnbaker15 johnbaker15 is offline
Re: Electric center stand K1200LT
Marcos,
The center stand for your year was only manual, no power. The power center stand was added in 2005 and with all the electrical work you would have to do to upgrade to your bike it would be simpler to buy a 2005 than try to change yours.
__________________
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
  #3
Old Oct 4th, 2011, 5:38 am
kk610lt's Avatar
kk610lt kk610lt is offline
I do believe that folks have retro-fitted electric centerstands to older bikes.
Try communicating with the trike conversion companies to hook you up with an electric centerstand. Or, there is always Beemer Boneyard, forum want ads, or e-bay.
__________________
kk610lt
2007 K 1200 LT
2004 R 1150 GS Adventure
2002 K 1200 LT (totaled by a SUV 10-7-08)
1988 Concours
Why do bullets bounce off of Superman, but he ducks when you throw a gun at him?
  #4
Old Oct 4th, 2011, 6:38 am
Thank you
Marcos Ruiz
  #5
Old Oct 4th, 2011, 6:43 am
New2rt's Avatar
New2rt New2rt is offline
If you can simply swap an electric for a manual it would be an easy task but you would loose the safety aspect of an interlock system. You can add an interlock by having two switches. One to cut the power to the control relay and a second (push button) to supply a ground for the relay coil.
+12V from battery to a on/off switch to 30 on the relay, jump 30 to 86 on the relay, 87 to the CS motor, wire from 85 to a push button switch, other side of push button to ground.
You need to cut the power when not using, it would really suck if the stand deployed while moving.
or....
  #6
Old Oct 4th, 2011, 11:56 am
palarimer's Avatar
palarimer palarimer is offline
Center stand retrofit has been done, search on 'retrofit center stand' you'll find a few threads some with good pictures like this one ....
http://www.bmwlt.com/forums/showthre...it+centerstand
__________________
-Preston
02 K1200 LTC | 94 K75 RT
  #7
Old Oct 6th, 2011, 8:19 am
Marcos Ruiz
  #8
Old Oct 6th, 2011, 5:17 pm
Tallyho's Avatar
Tallyho Tallyho is offline
You might also check the failure rate for the power center stand before making a conversion. There are several threads addressing this. I don't know anyone with an 05 or later with any kind of miles on it that has not had it replaced at least once if not several times.(Hopefully while still under warranty.) They are not especially robust. It's a nice idea but you've probably noticed they are no longer an option with the K1600.
__________________
Bob Morrow #4204
2002 K1200LTE "Green Hornet" LT 4 Two
"Kyrie Eleison down the road that I must travel"
  #9
Old Oct 6th, 2011, 10:50 pm
cws cws is offline
Its more a case of rebuilding, rather than replacing, and this is now pretty well documented. We also found a supplier for the starter motor that drives it, making it less of an issue all round. Its nice to have the EHCS (and its a cool party trick that still sucks 'em in!)
__________________
  #10
Old Oct 9th, 2011, 8:17 pm
dridnouer dridnouer is offline
I read BMWLT had an article on rebuilding the electric center stand (EHCS). Know where I can find the article? Info on the electric motor supplier? Mine just quit this weekend on a ride through the Smokies.
  #11
Old Oct 9th, 2011, 8:54 pm
cws cws is offline
Joe's original article with updated notes about oil amounts
http://www.bmwlt.com/files/displayim...album=15&pos=7
Ari's pics and descriptions
http://www.bmwlt.com/forums/showthre...highlight=EHCS
My video on how to quickly remove the EHCS, without disturbing the tupperware
http://www.youtube.com/watch?v=Ey7siMk-XSs
Bighoppers thread about fixing a cracked EHCS case
http://www.bmwlt.com/forums/showthread.php?t=46384
The replacement starter motor, just US$37.95
http://emsglobaldirect.com/p-820-hs-50n.aspx
__________________
  #12
Old Oct 18th, 2011, 6:29 am
Jimbus Jimbus is offline
Hi CWS and others.
I just wanted to thank you guys for the very useful and extremely detailed information.
The motor was so cheap that I have ordered two (one for me and one for another k1200lt rider).
You all gave me confidence to take my unit from the bike when it stopped working (2006 k1200lt 26500 miles), take it apart and try to find out why.
The only fault found was corrosion on the earth brush screw in the motor and now I have the unit working perfectly on the bench.
My only final reservation is some fairly heavy corrosion on the exposed actuator rod but as far as I can tell it is not leaking now so will put it back in the bike and hope. Does anyone know of a source for a replacement rod?
Any help would be gratefully received
Regards
Jimbus
  #13
Old Oct 18th, 2011, 11:54 am
jzeiler's Avatar
jzeiler jzeiler is offline
I would at least clean up the rod with some emery paper to make it as smooth as possible. Will help the seals last. No source yet but I guess I need to get the dimentions and hit my friendly machine shop up for a replacement cost.
__________________
2009 R1200GS
2005 Ocean Blue Blue Wizard
2006 Bushtec Turbo+2 Spell
2004 330 Ci Convertable
K4AN
CCR 06 Braselton CCR 07 Osage Beach CCR 08 Midway
CCR 09 Rapid City CCR 10 Killington, VT,CCR 11 Boise, CCR 12 Duluth
CCR 2013 Bend, CCR 2014 Backyard!
You may not post new threads
You may not post replies
Forum Jump
Electric center stand issues starvingdrummer K1200LT 13 Sep 1st, 2011 6:17 am
Center Stand Failure..Electric browad K1200LT 9 Nov 1st, 2009 10:18 am
Electric center stand retro fit kit seriousracer Batteries, Chargers, & Electrical 3 May 14th, 2009 7:12 pm
Electric Center Stand spokane1200lt K1200LT 11 Sep 9th, 2008 11:13 am
Electric Center Stand jstrans K1200LT 1 Aug 30th, 2008 4:50 pm
