drive shaft problem - BMW Luxury Touring Community
Thread Tools Display Modes
  #1
Old Jul 23rd, 2011, 5:33 pm
gary45 gary45 is offline
drive shaft problem
I was looking at a 2002 LT today, with the bike on the centerstand rotating the back wheel heard clunking scraping noise, seems the rear universal is causing this - anyone have experience with this type problem - looks like major expense
Gary
Markham, Ontario, Canada
1992 K1100LT
2000 V Star 650 and Velorex sidecar
Old Jul 23rd, 2011, 6:17 pm
casualemt's Avatar
casualemt casualemt is offline
Re: drive shaft problem
How many miles on the bike? Tire rubbing or caliper dragging? Rear wheel loose? clunking sound while the wheel is rotated in one direction continuously, or just back and forth? Need more info here...
__________________
RICH CANNON
2000 K1200LT "a great ride"
2002 GL1800 powerful, but boring..(gone)
1979 XS1100 (gone)
1986 VT500 Ascot (gone)
1972 Honda 500-4 (gone)
1961 Lambretta (way gone)
1962 Allstate Compact (gone but not forgotten)
  #3
Old Jul 23rd, 2011, 7:24 pm
it does it both directions, it's not the caliper or rotor both excellent, rubbing/clunking every 180 degrees, pretty sure it's driveshaft hitting inside tube, no play in rear end, I was looking for date code on tire when I found problem, the wheel on my K11 rotates smoothly/quietly on centerstand (as one would expect) - K12's the same? I've worked on K100s, /2s and my K11 - just want to know if anyone has noticed something like this with a driveshaft failure of some type - not my bike cannot take it apart, was thinking of buying it
US bike 77,000 miles
Gary
  #4
Old Jul 23rd, 2011, 7:53 pm
CharlieVT CharlieVT is online now
Gary
1992 K1100LT
Actual failure of the U-joint in the driveshaft of the K1200LT is probably very rare, I've never heard of it.
Final drive failures are probably the most common event, and of those failure of the crownwheel bearing is most common. Draining the FD gear lube should give you an indication as there are likely to be bearing retainer pieces.
However, since you seem to think that the problem is located in the driveshaft/swingarm area there are couple of known issues. The drive shaft has a rubber coupling and there have been cases of the rubber coupling failing; however loss to power to the rear is a symptom of this.
I know of one case where someone on installing a final drive failed to seat the input shaft U-joint properly onto the input pinion shaft of the final drive. The bike ran fine for quite a while but ultimately ended up clunking and the U-joint chewed up the insides of the swing arm. You should be able to check for something like this by simply pushing back the rubber boot at the swing arm/final drive junction.
HTH
  #5
Old Jul 23rd, 2011, 8:15 pm
Thanks Charlie - I drove this bike slowly in 1st and did not hear or feel anything - seems very strange - 90 miles away - poorly functioning whizzy brakes - probably best to look elsewhere
Gary
  #6
Old Jul 24th, 2011, 7:14 am
Boatzo's Avatar
Boatzo Boatzo is offline
Depending on the price that you can get it for Gary, might be a good deal? The repairs to things in that area aren't a real big deal. My LT had the rubber insert fail early on and the previous owner had it replaced under warranty. No significant damage was done, just some chafing inside the swing arm.
Don't know about the wizzy brakes, my 99 doesn't have servo assist. Could be the brakes just need flushing and bleeding or could be you are just not used to the feel of them. Let us know what you do. There is ample help and knowledge here on this forum and Curtis is a guru with final drives .
__________________
Bill
Eastern Virginia (Middle Peninsula)
K3ZXV
05 Honda Sabre 1100
04 Triumph Speedmaster , Black with
California Sidecar Friendship II
99 K1200LT, Basalt Gray "DELILAH" (SOLD)
99 R1100RT ,Glacier Green (SOLD )
  #7
Old Jul 24th, 2011, 8:01 am
Zeke's Avatar
Zeke Zeke is offline
Talking Re: drive shaft problem
HTH
The failure does happen. I had one a couple years ago, with the same symptoms. I posted it here with pics. Change out is pretty straight forward. This time Im doing a check BEFORE it fails. Good luck ride safe. Check under 140k-u joint april 2009
Zeke
__________________
40 years riding and still more places to see.
2002 K1200LT
IBA # 41935
  #8
Old Jul 24th, 2011, 10:29 am
Thanks Zeke - that sure looks like the problem, so the point is not drive it until it breaks - I was wondering if the pinion bearing could have faailed but that does not make any sense from the way it feels and acts
__________________
Gary
2000 K1200LT
Past rides
1992 K1100LT
2000 V Star 650/Velorex sidecar
1985 K100RT
1965 R60/2
1960 AJS 500 single
  #9
Old Jul 24th, 2011, 12:06 pm
Zeke's Avatar
Gary;
You're right. BEFORE it breaks. lol. I do all the maintenance but somethings you just don't think of. Live and learn and ride some more. Try and not make the same mistake twice.
Good riding.
__________________
2002 K1200LT
IBA # 41935
  #10
Old Jul 24th, 2011, 2:27 pm
deanwoolsey's Avatar
deanwoolsey deanwoolsey is online now
If your noise is happening at 180 degrees on the wheel its not likely the drive shaft as it turns much faster than the rear wheel due to reduction gearing.
__________________
  #11
Old Jul 24th, 2011, 9:00 pm
jzeiler's Avatar
jzeiler jzeiler is offline
Another cause is the rear half of the drive shaft is not "set" on the rear drive splines. There is a circlip that must be engaged or it can work its way up the shaft and begin to wobble.
__________________
2009 R1200GS
2005 Ocean Blue Blue Wizard
2006 Bushtec Turbo+2 Spell
2004 330 Ci Convertable
K4AN
CCR 06 Braselton CCR 07 Osage Beach CCR 08 Midway
CCR 09 Rapid City CCR 10 Killington, VT,CCR 11 Boise, CCR 12 Duluth
CCR 2013 Bend, CCR 2014 Backyard!
You may not post new threads
You may not post replies
Forum Jump
R1100S drive shaft leak dadicool59 Other R-Bike Discussion 0 Jun 6th, 2011 5:29 am
Drive shaft stuck ! itsallpoo K1200LT 5 Oct 28th, 2009 6:01 am
Drive shaft problem K1200LT-TH K1200LT 7 Dec 20th, 2008 6:30 am
Final Drive murray K1200LT 22 Sep 28th, 2008 9:02 am
Drive Shaft Phasing and Rubber Cush Hilton K1200LT 8 Jan 13th, 2007 6:48 pm
