What an unbelievable difference unplugging the airbox temp sensor makes! - BMW Luxury Touring Community
Thread Tools Display Modes
  #1
Old Jul 20th, 2011, 7:19 am
14wntr's Avatar
14wntr 14wntr is offline
Talking What an unbelievable difference unplugging the airbox temp sensor makes!
Yesterday in the 100F heat I unplugged my temp sensor and WOW-O-WOW what a difference it has made!! I can very honestly say that in the last two months my bike has never ever run this good! THIS is what a BMW is supposed to be like!! WAHOO!!! With the way it runs now I don't think it ever did not have the hesitation issue. Now I have to learn to drive it slow again because the ol girl really wants to go! If you are reading this and have not learned your lesson on your own take it from me and many others... get your butt out there and unplug the anchor! Makes me want to ride all the more... OHYEAH!!!!
__________________
2000 K1200LT-C "Tsukune"
2013 Honda NC700X "Moka"
President of BMW Motorrad Club Northern IL
Free K1200LT DIY Maintenance Videos
Old Jul 20th, 2011, 7:52 am
bobst2's Avatar
bobst2 bobst2 is offline
Re: What an unbelievable difference unplugging the airbox temp sensor makes!
i remember in a not to distance thread on pinging or the brown wire. mr ziegler wrench extrodinare said somthing to the affect of do not unhook air temp sensor possible internal engine damage or somthing to that affect.he will prob comment on this thread.or you may want to send him a PM.
  #3
Old Jul 20th, 2011, 8:27 am
AlaskaFish's Avatar
AlaskaFish AlaskaFish is offline
Wink Re: What an unbelievable difference unplugging the airbox temp sensor makes!
Bob, I am not John Z, and I did not sleep at a Holiday Inn Express last night, but my name is John, and I believe you may have gotten confused on the difference between the early LT's and the later ones. Not sure when they started providing the loop in the famous Brown Wire which can be snipped to prevent the hot weather hesitation issues, but the early LT's did not have the Brown Wire loop. So the early LT's cure for that hesitation was to disconnect the Airbox Temp Sensor, as the OP here did.
The warning for either method is that you should use only premium grade fuel thereafter due to the change in fuel mapping. And certainly, if your LT is one of those later ones with the Brown Wire which you have snipped, you do not need to disconnect the Airbox Temp Sensor!
HTH,
__________________
John & Marilyn Fisher
'00 K1200LTC "Katie"
'95 Triumph "Tigger"
'12 Triumph 800XC "Tigger II" (RIP)
'12 Triumph 1200 Explorer "Shadow Tigger"
Hillsboro, Oregon
  #4
Old Jul 20th, 2011, 10:29 am
Dick's Avatar
Dick Dick is offline
+1 on John F's explanation. As mentioned, there are a bunch of early model year LTs running around with the airbox temp sensor removed. It wuz a welcome tip from (I think, IIRC) Mark Neblett back in the day, and like the OP sez, it resulted in a new ride and took the worry away regarding leaving cleanly from the starting line.
  #5
Old Jul 20th, 2011, 10:37 am
motorhead's Avatar
motorhead motorhead is offline
Had modified mine splicing one lead threw a switch mounted top of stingray. A/B sensor on in sub 80* and off above that.
It has worked out very well rigged this way
__________________
"00" Canyon Red LTI ~ Well Farklized ~ Bug Splattered
Our "semi" quiet riot
*** Trailer Too ***
Twisties Required
  #6
Old Jul 20th, 2011, 11:48 am
jzeiler's Avatar
jzeiler jzeiler is offline
What I said was don't cut the brown wire (if you have one) AND pull the air temp plug at the same time. One or the other by itself is OK. Both gives you a too lean issue that can cause detonation (even on premium) that will damage the piston ring lands. Seen this in at least two engines so far.
__________________
2009 K1300GT
2009 R1200GS (Gone)
2005 Ocean Blue Blue Wizard
2006 Bushtec Turbo+2 Spell
2004 330 Ci Convertable
K4AN
CCR 06 Braselton CCR 07 Osage Beach CCR 08 Midway
CCR 09 Rapid City CCR 10 Killington, VT,CCR 11 Boise, CCR 12 Duluth
CCR 2013 Bend, CCR 2014 Backyard!
  #7
Old Jul 20th, 2011, 12:31 pm
motorhead's Avatar
My Y2K pings on premium fuel when modestly warm and at lower rpm under a load no matter A/B switch position .
No oil burning happening but then again don't see myself pulling engine apart to look.
__________________
*** Trailer Too ***
Twisties Required
  #8
Old Jul 20th, 2011, 12:53 pm
sgroover sgroover is offline
I have an 06 LT and not sure where this plug is. I looked under the fairing on the left side (while facing the front of the bike) and don't see anything close. I don't have a left radiator cap, but just a connector hose to the right side. When others said "left side", did they mean when sitting on the bike or standing it front of it.
I live in GA and the temps are always in the high 80's, 90's and 100's in the Summer. I would like to try this mod. Will my gas mileage suffer any? I like the 46 - 50 MPG I get now.
Thanks everyone!
Sammy
  #9
Old Jul 20th, 2011, 1:59 pm
14wntr's Avatar
left side sitting on it. See the other link titled "is this the airbox temp wire" in the links below.
__________________
  #10
Old Jul 20th, 2011, 2:17 pm
midwestrider's Avatar
midwestrider midwestrider is offline
I have a 2001 LT and I just removed the Cat Code plug under the trunk, also did the cannisterectomy while I was in there. I posted pics under the "Just where is this fabled brown wire" thread.
Been running premium ever since and have not noticed any pinging the it definitely doesn't bog anymore like it did.
__________________
Troy
2001 K1200LT-I
75,000+ miles
Grip Puppies
RAM mount for iPhone
RAM mount cupholder
DODK64 Floorboards (driver & passenger)
Alaska Leathers Sheepskin covers
Avon Storm II Ultras
ScalaRider G4 Powerset
NGK Iridium IX DCPR7EIX spark plugs
Spiegler SS Brake lines (fronts only installed so far)
Creative Concepts extended rear brake pedal
  #11
Old Jul 20th, 2011, 5:53 pm
bobst2's Avatar
thanks zig i knew there was a warning you had made. i just thought safe than sorry.
i stand corrected.
  #12
Old Jul 20th, 2011, 9:16 pm
Alpac Alpac is offline
I agree, it was like night an day for me too in hot weather after I disconnected the temp sensor on my 99LT. I eventually put a switch to be able to connect/disconnect the temp sensor thinking that in cold weather it would run better and would get better MPG with the temp sensor connected back but I did not see any difference so now it is off all the time.
__________________
Alain
Vieux motard que jamais
  #13
Old Jul 21st, 2011, 9:29 am
So I'm told that the 06 LT's do not have this plug / brown wire. So we don't have a way to alter the mapping in hot weather? Just curious. I see a plug next to my left (sitting on the bike) radiator cap, but I guess it's not the right plug for the airbox temp sensor.
Thanks for the guidance,
Sammy
  #14
Old Jul 21st, 2011, 10:43 am
C-A-D C-A-D is offline
Location: Helsinki, Finland, Europe, Northern hemisphere
Here in Finland hot weather is not that common problem BUT this and past summer have had days with >30C. I noticed clear difference / stalling above 2kRPM when the temperature was >28C. After reading these "brown wire" and "air temp sensor" threads from this site I installed a switch in my -99LT's temperature switch wire. As the one starting this thread said - WHAT A DIFFERENCE! Haven't turned that switch on since I cut the line...
__________________
Born to be wild so why not
http://www.careforthewild.com/
  #15
Old Jul 22nd, 2011, 7:24 pm
kgt1200's Avatar
kgt1200 kgt1200 is offline
Is this on certain year models or all LTs?
  #16
Old Jul 28th, 2011, 7:46 pm
joliver joliver is offline
I was just thinking about this problem. I have read many posts about canisterectomy, cutting the brown wire and unplugging the air temp sensor wire. I have not found a single message about finding and fixing/replacing the culprit part. There is of course a problem or we would not have this many fixes for the same symptoms. So what exactly is the problem and why is there no BMW supported fix for the problem?
Has BMW ever acknowledged the existance of symptoms (stalling) and offered to replace a part? I too have a 2000 LT with the same symptoms and I am going to unplug the air temp sensor this weekend. But would a new air temp sensor also fix the problem? Or does the fuel map need to be updated?
Please don't misunderstand. I am happy that someone (probably several of you) identified the symptoms and tried the three aproaches mentioned above and passed along your new found information. Thank you for doing that. I could not have done what you have done for I have not the knowledge. It just seems that there should be a BMW "authorized" fix. Am I way off base here?
Jonny Oliver
Concord, NC
1993 K1100LT
2000 K1200LT
  #17
Old Jul 28th, 2011, 11:41 pm
Spenceer Spenceer is offline
Smile Re: What an unbelievable difference unplugging the airbox temp sensor makes!
I live at 6200' elevation, my 2002 does not ping, no matter what.
  #18
Old Jul 29th, 2011, 1:17 am
motorhead's Avatar
The motronic unit was upgraded I think 3 times in the 10 year run the LT has had. With temperature and humidity being such a large contributor in combustion efficiency and this being so varied world wide ... issues that we read about IMO are pretty spotty at best.
Because so much of the finer details get left out in posts ... Running shit fuel, Have a Remus exhaust, fiddled with this and fucked with that get left of of posts, one somewhat has to read between the lines.
I'm guilty ... have a Remus and no chip upgrade, bike runs great !!, but pings when hot on premium fuel ... NO MATTER WHAT !
So I rev higher and shift later ... problem solved.
Hope you see my point
Jonny Oliver
Concord, NC
1993 K1100LT
2000 K1200LT
__________________
*** Trailer Too ***
Twisties Required
  #19
Old Jul 29th, 2011, 6:51 am
Boatzo's Avatar
Boatzo Boatzo is offline
My 99 has a Remus exhaust and a Rhinewest performance chip up grade. It runs fine on even 87 octane with ethanol although seems to like mid grade gas better so that is what I use. I get a very slight hesitation at times around 2500 rpm and I get some popping on deceleration. My gas mileage is only 42mpg. None of these symptoms bothers me at all.
I try to buy fuel at high volume name brand gas stations to hopefully get clean fuel. I put a dose of Seafoam in the tank every so often and all is well. Just my 2 cents worth.
__________________
Bill
Eastern Virginia (Middle Peninsula)
K3ZXV
05 Honda Sabre 1100
04 Triumph Speedmaster , Black with
California Sidecar Friendship II
99 K1200LT, Basalt Gray "DELILAH" (SOLD)
99 R1100RT ,Glacier Green (SOLD )
  #20
Old Jul 29th, 2011, 7:37 am
14wntr's Avatar
As the OP I should note that I have zero mods other than a few farkles. I am still suprized by how well the bike runs! I feel like I am riding someone elses ride!!
__________________
  #21
Old Jul 30th, 2011, 7:20 am
dshealey's Avatar
dshealey dshealey is offline
This has been discussed probably a hundred times or more, starting in early 2000. I posted several times about the issue, and think I had detonation damage on all four pistons from both removing the Cat Code Plug AND unplugging the air box sensor for a short time on my early 2001 LT. Here is the most recent post I did on the subject:
http://www.bmwlt.com/forums/showpost...6&postcount=11
In short, there is no simple answer on when or how you should make a modification, it depends on the year of your bike, and which Motronic is installed. Be warned, doing it wrong can lead to real problems.
__________________
I don't want to achieve immortality through my work...I want to achieve it through not dying.
David Shealey
Dandridge, TN
EX: '01 Black LT, BAT BYKE (Totaled at 110,000 miles)
IBA SS, BB, BBG, 10/10ths.
No bike now, but maybe in the future.
  #22
Old Jul 31st, 2011, 7:37 pm
Thank you, Mr. dshealey. Your last post (url above) is exactly the information that I was looking for. This site is so volumous that it is hard to see every post on a particular topic that you are interested in. It must be an absolute horror to monitor and classify. Thank you again for kindly sending the url to me.
Jonny Oliver
1993 K1100LT
2000 K1200LT
  #23
Old Aug 1st, 2011, 5:39 pm
rhawk's Avatar
rhawk rhawk is offline
For what it's worth...........
The Clymer manual says that the air inlet temp sensor is used by the Motronic to determine air \ fuel mixture - and - ignition timing.
The sensor is an " NTC " ( negative temperature coefficient )
The resistance of the sensor decreases as temp increases.
So I guess that the logical conclusion is that by showing the Motronic an open circuit, it's seeing high resistance......a very cold air box.......no need to retard timing to avoid detonation ?
  #24
Old Apr 21st, 2012, 9:53 am
nd4spd nd4spd is offline
Sorry to pull this one back to the surface... I've been reading and searching to determine which model years this effects. As in, which models have the brown wire, which have the cat code plug, etc. I know all of them would have the temp sensor. I have an '09 that has a minor hesitation in high temps. I'm assuming (since it's an '09) it would have the latest and greatest Motronic unit. Would any of these methods help out this model year...? Any further info would be greatly appreciated - THX!
Mark
  #25
Old Apr 21st, 2012, 12:44 pm
jzeiler's Avatar
These were all pre-05 fixes for the fuel map. The 05 came with RS pistons and larger throttle bodies and thus a new fuel map. I have not experienced it with my 05 in 73K. Have not seen any mention of it here either. I presume you are running premium fuel.
__________________
2009 K1300GT
2009 R1200GS (Gone)
K4AN
  #26
Old Apr 21st, 2012, 4:29 pm
Rlamar2398 Rlamar2398 is offline
Unhappy Re: What an unbelievable difference unplugging the airbox temp sensor makes!
I have a 2002 LTE and am new to this bike. Please excuse my ignorance, but where is this brown wire/loop. I observed a brown wire under the front seat that was not attached to the battery ground, is this the culprit everyone speaks of? When I replaced the battery I connected that wire to the ground, did I make a mistake?
__________________
Rich
2014 K1600GTL Exclusive
2002 K1200LT
1988 Honda Hurricane 1000 (sold 1990)
1986 Honda Nighthawk S (sold 1988)
1985 Honda Interceptor 500 (sold 1987)
  #27
Old Apr 21st, 2012, 10:35 pm
Yes - I am using premium fuel... Does anyone know if this is/was an issue w/ any other K bikes..? I have an '04 K1200RS and now I'm wondering if there is "brown wire" to look for.
  #28
Old Jun 17th, 2013, 2:03 am
bartman49 bartman49 is offline
Yay, unplugged my airbox temp sensor wires on '99 and it runs much better in warm weather or after bike gets warm in cooler weather. Had to take side fairing off because my hands are too big to get behind the radiator without doing so. Still a very tight fit. Found that someone had put the plug on upside down which made it very difficult to push in the wire retainer to pull the plug off. Maybe the sensor was installed upside down too. Does it matter if the plug is upside down?
Bartman
  #29
Old Jun 17th, 2013, 7:59 am
Ron02LT Ron02LT is offline
Just curious???
Does this effect other BMW's ? Like Oilheads?..might need to try it?
  #30
Old Jun 17th, 2013, 4:48 pm
james216's Avatar
james216 james216 is offline
So. An 04 cut the brown wire Or unplug the sensor?
__________________
2004 K1200LT. Big Mama
1999 Suzuki Intruder VL1500LC. Betty Lou.
I'm a 4 percenter.
  #31
Old Jun 17th, 2013, 4:53 pm
14wntr's Avatar
04 has the brown wire. You can watch my video on LT performance for the location. Forward to 08:22 IAT unplug vs brown wire vs cat code plug.
http://www.illinoisbmwriders.com/ins...lt-performance
__________________
  #32
Old Jun 18th, 2013, 3:42 pm
Xnight Xnight is offline
Ok really simple questions, on a 2009, which of the methods is applicable? and is it worth the risk of damage due to unplugging or cutting a wire?
yes or no will do for second question.
Thank you
__________________
K1200LT
  #33
Old Jun 18th, 2013, 7:00 pm
johnbaker15's Avatar
johnbaker15 johnbaker15 is offline
Thank you
See post #25, after 2004 no brown wire to cut, and after 2005 new fuel maps make unplugging the temp sensor unnessary .
__________________
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
  #34
Old Jun 18th, 2013, 7:01 pm
Sweet
__________________
K1200LT
  #35
Old Jul 26th, 2013, 12:58 pm
DriWashNGuard DriWashNGuard is offline
Hello, I just bought an 09 bmw lt. Did you change the air box sensor or brown wire to get better performance? I also have a little hesitation in HOT weather.
  #36
Old Jul 26th, 2013, 1:43 pm
saddleman's Avatar
saddleman saddleman is offline
Unplugging the air box sensor has worked on the 1999 to 2001 LT's. The brown wire for the second fuel mapping is only on the 2002 to 2004 LT's.
__________________
Dave
2004 Black LT
2000 Canon Red LT
You may not post new threads
You may not post replies
Forum Jump
Is this the airbox temp wire? (picture) 14wntr K1200LT 3 Jul 19th, 2011 4:13 pm
Tupperware's off,Where is the airbox temp wire? tampstick K1200LT 2 Apr 9th, 2006 7:05 pm
