Steps - Changing Front Brake Pads - BMW Luxury Touring Community
Thread Tools Display Modes
  #1
Old Apr 25th, 2011, 9:59 am
MtnRider MtnRider is offline
I found a great write-up, article for the rear brake pads.....but can't find anything, step by step for changing out the front brake pads.....
Do I need to take off the front wheel?
Do I need to take the calipers off the disk?
What about pushing the pistons out??? Do I open the bleeder, as to not push the brake fluid back through the system (could damage the ABS)???
I would love a step by step with pics..... Anyone?
__________________
2007 Adv Equipped VStrom
1988 Honda NX650
Old Apr 25th, 2011, 11:05 am
jzeiler's Avatar
jzeiler jzeiler is offline
Re: Steps - Changing Front Brake Pads
Need to know what year you have. Late 2001 and up no need to pull the calipers. Just the spring plate and holding pin to get the pads out. Early bike you have to pull the calipers.
__________________
2009 R1200GS
2005 Ocean Blue Blue Wizard
2006 Bushtec Turbo+2 Spell
2004 330 Ci Convertable
K4AN
CCR 06 Braselton CCR 07 Osage Beach CCR 08 Midway
CCR 09 Rapid City CCR 10 Killington, VT,CCR 11 Boise, CCR 12 Duluth
CCR 2013 Bend, CCR 2014 Backyard!
  #3
Old Apr 25th, 2011, 7:49 pm
AlaskaFish's Avatar
AlaskaFish AlaskaFish is offline
Wink Re: Steps - Changing Front Brake Pads
What John says here is correct. To add some info, if your calipers say "Brembo" you have the early style which will need to be reomved to change pads. If they say "BMW" you can get away with just pulling the pads similar to the rear caliper.
HTH,
__________________
John & Marilyn Fisher
'00 K1200LTC "Katie"
'95 Triumph "Tigger"
'12 Triumph 800XC "Tigger II" (RIP)
'12 Triumph 1200 Explorer "Shadow Tigger"
Hillsboro, Oregon
  #4
Old May 24th, 2011, 10:18 pm
I worked on a 2002....so they had the BMW brakes.
For the rear, I went ahead and removed the two bolts that hold the brake assembly. That way I could have some room to work. There were two cotter pins to remove and then pull out the two pins....and the brake pads pulled out easily. I pressed the calipers in....and slid in the new pads.
On the front, I did not have to remove the brakes and there was just one cotter pin and a single pin. Same....push in the calipers, slide in the new pads...etc...
This was the easier brake job I have ever done in my life. Anyone paying a dealer big money to do this job....well, you are wasting your dough.
__________________
1988 Honda NX650
  #5
Old May 25th, 2011, 12:41 pm
jzeiler's Avatar
Just note that the front and rear bolts on the rear caliper are unique and not interchangeable. But no real need to remove them.
__________________
2009 R1200GS
K4AN
  #6
Old May 26th, 2011, 10:37 am
krider08 krider08 is offline
Any feedback if the stainless steel brake pins are of any good?
I see these on the UK ebay sites.
  #7
Old May 26th, 2011, 10:55 am
Drumbum Drumbum is offline
wish mine was so simple. I have an 03 and the pistons in the calipers do NOT want to compress on both sides at the same time (yes i pulled the cap on the res). I am going out to give it another go as the pads are just about gone and I will not be without a ride heh.
  #8
Old May 26th, 2011, 7:43 pm
jzeiler's Avatar
How about a link as I have no idea what a brake pin is anyway. The only one I know of is the one that keeps the pad from coming out. Why would you want to "upgrade" that?
__________________
2009 R1200GS
K4AN
  #9
Old May 26th, 2011, 7:45 pm
jzeiler's Avatar
Posted on your other post as well. Put the calipers back on empty and use the old pads to lever the pistons back. As one side goes in install the new pad there and continue to use the old pad on the other side to push the piston back in. You did spray it down with brake kleen before you pushed them back I hope?
__________________
2009 R1200GS
K4AN
  #10
Old Oct 7th, 2011, 11:27 am
BecketMa's Avatar
BecketMa BecketMa is offline
I just replaced the front pads on my 00.
Remove the two bolts holding the caliper in place. Push the caliper against the disc brake to push the pistons in. They have to be pushed in enough so that the pads will slip over the disc brake--very tight fit to get the caliper past the well.
I used C-lamps to push the pistons in; worked like a charm on the first pad.
The second one was a real PITA!
I'd push in one piston and its mate would extend. Two C-clamps got the pistons on one side pushed in. But one of the pistons on the opposite side of the caliper extended.
I struggled in vain trying to get the pads over the disc brake.
Eventually it occurred to me to open the speed bleeder!
I was then able to compress all four pistons and get the dam thing over the disc and bolted back in.
Best from Gorham ME
Bob
__________________
"He was a foul caricature of himself, a man with no soul, no inner convictions, with the integrity of a hyena, and the style of a poison toad." H. S. Thompson
You may not post new threads
You may not post replies
Forum Jump
Glue on the Brake Pads rab1967 K1200LT 8 Nov 20th, 2009 6:41 pm
Front Brake - is this right? myk_edwards K1200LT 16 May 27th, 2009 9:03 am
Front brake fluid and Will Be Selling the bike Jabrown K1200LT 11 Oct 22nd, 2007 1:07 pm
OEM rear brake pads CharlieVT K1200LT 1 Jul 13th, 2007 10:14 am
Changing brake pads.... unleashd K1200LT 4 Apr 12th, 2006 6:53 pm
