REAR DRIVE & TRANSMISSION GEAR LUBE QUESTION - BMW Luxury Touring Community
Thread Tools Display Modes
  #1
Old Apr 8th, 2011, 8:26 am
Lynn_Keen's Avatar
Lynn_Keen Lynn_Keen is offline
Rear Drive & Transmission Gear Lube Question
Don't mean to start another oil thread but I do have a question. I've been using ****** gear lube in all my bikes since back in 1999. I've recently moved to a new area and cannot find a convenient retail source for those products and I'm due for a major service on the LT. Yea, I know I can become a "dealer" but don't want to spend the $30 or so to do that. My usage is not sufficient to justify that.
Anyway, my question is; What are ya'll using for gear lube? I'm looking for something that's readily available in the retail market place and that is hi quality and compatible with the ****** that I've been using. Suggestions?
__________________
Lynn Keen
North East Florida
'99 Canyon Red RETIRED AT 93,000 MI
'05 GRAPHITE METALLIC retired at 87,000 MI
'01 R1150 GS- totaled
'02 R1150 GS sold
'85 K100/EML sidecar sold
'11 R1200RT currently being enjoyed
Old Apr 8th, 2011, 9:17 am
Lynn_Keen's Avatar
Re: REAR DRIVE & TRANSMISSION GEAR LUBE QUESTION
OK, I give up. sorry about posting this twice. Can't seem to figure out how to delete it. also the software doesn't seem to like it when I type ******! that is A M S O I L
__________________
Lynn Keen
North East Florida
'02 R1150 GS sold
  #3
Old Apr 8th, 2011, 10:58 am
dukey33's Avatar
dukey33 dukey33 is offline
I'm not a tribologist but as I understand it, part of meeting the API and manufacturer specification for a lubricant is being compatible with all oils meeting the same specification. Even synthetic and mineral base are fully compatible so long as they meet the same specs.
__________________
Dave
-2000 K1200LT
-1998 Shadow ACE Tourer
Life's too short to ride ugly motorcycles
  #4
Old Apr 8th, 2011, 1:07 pm
JPSpen's Avatar
JPSpen JPSpen is offline
At Large
I used to use Mobil 1...Now I use Bel-Ray Gear Saver.. It has greatly improved the shifting of the RT...
__________________
Live and direct from the new earthquake capitol of the U.S. Jones, Oklahoma
08 Can-Am Spyder (Miss Lindy's)
03 R1200CLC Capri Blue "Flipper" (Tis But A Scratch !)
01 R1100RT Glacier Blue "Lucky"
91 R100GS "It'sNotAMoneyPit"
The voices in my head may not be real, But they have some good ideas!
"I like the wind in my face and Boobies on my back. No, Wait, I got that backwards"
  #5
Old Apr 9th, 2011, 2:35 pm
jeffklt jeffklt is offline
When I went on the Wally's World 12 step program I switched from Mobil 1 to the NAPA brand, about 50k ago. Can't tell any difference. Sure don't miss Wally's World
__________________
Jeff in Myrtle Beach
'01 LTC
'99 Icon champagne
'02 KLR 650
TZ 185 2 stroke
Honda R100R beater
  #6
Old Apr 9th, 2011, 4:45 pm
ErnieA's Avatar
ErnieA ErnieA is offline
LD Traveler
You can order direct if you have the retailer's Distributor number. PM me if you would like some help.
__________________
Ernie A
Milwaukie, OR
Member: MOA, AMA, IBA, NRA, MERA
GS911 - Diagnostics Tool Available
2013 R1200GSW > 10k miles!
2002 K12LT Toscana Green - > 230k miles and counting!
2006 Suzuki DL1000 V Strom Silver/Blk - >21k (Sold)
SS1K (x4),BB,BtoB(<24),BBG, SS3k
  #7
Old Apr 9th, 2011, 8:14 pm
Voyager Voyager is offline
Re: Rear Drive & Transmission Gear Lube Question
Tom Cutter of Rubber Chicken Racing Garage fame says he has seen very good results with plain old Castrol Hypoy C. Unfortunately, I can't find that in my area so I will likely use either Mobil 1 synthetic or order the Castrol online or maybe buy the "A" brand that you are using now. If you are a BMWMOA member, I beleive they run ads in each issue about a way to order it online using a BMWMOA code.
__________________
2007 K1200LT, VOICE II, Navigator III+, Motorrad Communicator, K7MSW
  #8
Old Apr 10th, 2011, 8:24 am
Lynn_Keen's Avatar
Thanks for the suggestions. I was thinking about Mobile 1 but will also check out the MOA for the advertisement.
__________________
Lynn Keen
North East Florida
'02 R1150 GS sold
  #9
Old Apr 10th, 2011, 8:43 am
rmcclure's Avatar
rmcclure rmcclure is offline
Depending how much oil you would use in a year, the $30 may still be worth it. I did that last year and bought a case, and even with that, delivery and taxes, it was still a lot cheaper than any of the local retailers, plus it arrived at my door two days after I ordered it. I have a bit of a collection, so end up using more than a case every year.
__________________
Ross
K1200LT (99)
  #10
Old Apr 10th, 2011, 9:20 am
wa1200lt's Avatar
wa1200lt wa1200lt is offline
I use Royal Purple. Readily available, meets the specs and matches the color of the bike. It's a 3fer. What could be better?
Loren
__________________
WAK1200LT
Loren
Cave quid dicis, quando, et cui
  #11
Old Apr 10th, 2011, 1:14 pm
STARFIGHTER's Avatar
STARFIGHTER STARFIGHTER is offline
Redline heavy duty shockproof............................
__________________
Allan..Illinois, Oregon, Arkansas, and tomorrow the Universe
2003 K1200LT trike - Starfighter
2004 R1150RTP - Combat Touring
IBA #38152
BMW-MOA 97667
Patriot Guard Riders
...and man of leisure
  #12
Old Apr 10th, 2011, 3:46 pm
Loren
It doesn't match my gray LT. :-)
__________________
  #13
Old Apr 10th, 2011, 6:47 pm
tonygret's Avatar
tonygret tonygret is offline
Been using the Beemerboneyard stuff. Works for me.
http://www.beemerboneyard.com/trfidroil.html
  #14
Old Apr 10th, 2011, 8:19 pm
roadcrave's Avatar
roadcrave roadcrave is offline
Just a reminder, remember the thousand or so oil threads, It finally came down to BMW saying to use a lower-narow viscosity rear diff oil, the thicker oil up to 140viscosity was not coating the bearing is what i remember,,,im running royal purple 85-95,and have used ****** in the same viscocity...matthew
  #15
Old Apr 10th, 2011, 8:37 pm
That may be true, but I am skeptical. I am pretty convinced from all of the work that Charlie, John and others have done, that the issue has nothing to do with oil and everything to do with proper preload. I really believe that a properly preloaded bearing is going to live long and prosper with almost any quality gear oil.
__________________
You may not post new threads
You may not post replies
Forum Jump
Rear Drive: Premptive Strike old1951 K1200LT 22 Nov 2nd, 2013 10:51 am
Another Rear Drive Bites the Dust - Question lad K1200LT 63 Jul 19th, 2013 12:34 pm
Yet another rear end mystery! gdroege K1200LT 10 Oct 28th, 2007 12:59 pm
Rear Drive - Another One Bites The Dust! cccpastorjack K1200LT 47 Jul 14th, 2007 8:52 pm
rear drive interchangeability question slmorley K1200LT 3 Oct 5th, 2005 7:06 pm
