Freeing frozen fasteners - BMW Luxury Touring Community
Thread Tools Display Modes
  #1
Old Mar 22nd, 2010, 10:49 am
CharlieVT CharlieVT is offline
For all of you that are mechanically inclined and dealing with frozen fasteners:
Penetrating Oils Compared
Machinist's Workshop magazine actually tested penetrants for break
out torque on rusted nuts. Significant results! They arranged a subjective
test of all the popular penetrants with the control being the torque
required to remove the nut from a "scientifically rusted" environment.
Penetrating oil .......... Average load
None ..................... 516 pounds
WD-40 .................... 238 pounds
PB Blaster ............... 214 pounds
Liquid Wrench ............ 127 pounds
Kano Kroil ............... 106 pounds
ATF-Acetone mix............ 53 pounds
The Automatic Transmission fluid (ATF)-Acetone mix was a "home brew" mix of 50 - 50 automatic
transmission fluid and acetone.
Note the "home brew" was better than any commercial product in this
one particular test. A local machinist group mixed up a batch and all now
use it with equally good results. Note also that "Liquid Wrench" is about as
good as "Kroil" for about 20% of the price.
Old Mar 22nd, 2010, 11:39 am
PMitchell's Avatar
PMitchell PMitchell is offline
Re: Freeing frozen fasteners
Great post Curtis! This was just cut 'n pasted into my reference library.
__________________
pm
Life is too short to do anything
other than that about which you
are absolutely passionate . . .
Ride till you can't!
"Der Weg ist das Ziel"
Morocco!
South Africa!
Spain, Tuscany, Provence & Andorra in 2012
Greece Fall 2013
In July, to The Dolomites of Italy, Alps of Switzerland & Austria and returning to Milan via the "Gold Coast" of the French Riveria.
'00 K1200LTC
'90 K75
'62 R 50/2 (Rode hard and put away wet)-Sold in '81
'63 Vespa 150 (1st and only dirt bike!) Sold in '67
  #3
Old Mar 22nd, 2010, 1:04 pm
Palerider's Avatar
Palerider Palerider is offline
I'm heading right back to the shop and mix some up, just as soon as I finish this apple..............good post Curtis and thanx for the heads up..............Jim......
  #4
Old Mar 22nd, 2010, 3:19 pm
kellenbenz's Avatar
kellenbenz kellenbenz is offline
Great information...thanks for passing it on Curtis!
Ron
__________________
545,000 miles on touring motorcycles
IBA 45658 MOA167437 BMWLT #3
2000 LTC 90600 miles totaled (Purchased new)
2003 LTE 164188 miles Silver (Purchased with 1687 miles)
2008 R1200T 70357 miles (Purchased with 16458 miles)
Total BMW miles 307,000
1982 GL1100 rode 84108 miles (bought with 12012 and sold at 96120)
1988 GL1500 rode 12067 miles (bought with 19893 and totaled at 31960)
1989 GL1500 rode 142208 miles (bought with 20302 and sold with 162510)
Goldwing miles 238,383
  #5
Old Mar 22nd, 2010, 4:13 pm
Palerider's Avatar
Just back from the shop...............ATF/acetone; mixed in an oiler can, is absolutely awesome...............Don't want to get it on ya' I'd bet though..................Thanx again Curtis............
  #6
Old Mar 22nd, 2010, 4:32 pm
LAF's Avatar
LAF LAF is offline
Great info for sure.
I been a Liquid Wrench kinda guy for awhile now. I guess I now know why, it works!
I do not have acetone but will source some and also mix a small pump oil can to try
Is the a chemical thing between the acetone and ATF, and or rust?
I mean that is a very significant reduction in force, so seems to me it draws into threads, or eats rust, or both?
Any explanation given?
__________________
Lee
10 Liquid Silver FJR1300
O7 Biarritz Blue Metallic LT Totaled 7/17/2010
ATGATT I am breathing proof.
BMW MOA #135959
  #7
Old Mar 22nd, 2010, 6:05 pm
jrh2020's Avatar
jrh2020 jrh2020 is offline
Gold Supporter
Check the label on your wife's nail polish remover, some of them are mostly acetone.
That suggests that it may be acting as a solvent.
Probably don't want to put it back on her shelf after you mix in the ATF though.....
Jim H.
__________________
Jim H.
K1200LT '00 for Touring, '73 Norton for fun
  #8
Old Mar 22nd, 2010, 8:30 pm
RonKMiller's Avatar
RonKMiller RonKMiller is offline
Dang, that's cool - and dirt cheap!
__________________
www.KonTourSeat.com "Like Butt-ahh!"
  #9
Old Mar 22nd, 2010, 9:10 pm
rdwalker rdwalker is offline
ATF and Acetone - sounds explosive! Will the Alcohol, Tobacco and Firearms crew get involved?
Good statistics, though - aside of the ATF/acetone mix, it looks like good ole Liquid Wrench stays right next to my tool set!
__________________
Robert in Northern NJ
'09 R12GS, '03 R1150RT
  #10
Old Mar 23rd, 2010, 5:37 am
I usually have a can of Acetone around the shop, available at hardware stores on the shelf with paint thinners, paint removers, etc.
YES, the stuff is very volatile and the vapors are explosive. You can't keep it in an unsealed container like an oil can, it needs to be tightly sealed or the acetone will be soon gone.
I suspect the reason the acetone/ATF mix works so well (if indeed the data is correct) is that the acetone penetrates like nothing else and pulls the ATF along with it.
  #11
Old Mar 23rd, 2010, 8:15 am
atrovarious's Avatar
atrovarious atrovarious is offline
Jim H.
Or use your own...
Jim H.
That's what WD40 is, a solvent.
__________________
Ghaison (Jason)
99 K1200RS Silver and Blue (Sold!)
2004 K1200LT FOR SALE!!!
Bluefield, VA
Sometimes you can get so fixated on the fact that you are right that you lose sight of the reality that it doesn't matter.
-some guy named Ghaison circa 2002
What I'm thinking right now.
  #12
Old Mar 23rd, 2010, 12:42 pm
Ajlelectronics's Avatar
Ajlelectronics Ajlelectronics is offline
Originally Posted by atrovarious
Or use your own...
Or not.
WD40 is the 40th incarnation of a Water Dispersant. I have yet to find a suitable use for it, apart from using the can to prop a door open!
In the UK we have a product called Plusgas which is one of the best penetrants available. I am told that diesel makes a good soak too.
__________________
Just pussin' through.
  #13
Old Mar 23rd, 2010, 6:19 pm
PMitchell's Avatar
Originally Posted by Ajlelectronics
Or not.
Here's the real answer . . .
and then you may ask What the hell is an Aliphatic Hydrocarbon
Well then, Click Here!
__________________
pm
Morocco!
South Africa!
Greece Fall 2013
'00 K1200LTC
'90 K75
  #14
Old Mar 23rd, 2010, 6:32 pm
c00k1e's Avatar
c00k1e c00k1e is offline
I would really like to know where diesel and PlusGas come on this list
__________________
"Whenever you find you are on the side of the majority, it is time to pause and reflect" Mark Twain
My Euro rides on YouTube
  #15
Old Mar 23rd, 2010, 7:33 pm
PMitchell's Avatar
PlusGas is mostly kerosene. Another marketing triumph to squeeze the consumer.
3 COMPOSITION/INFORMATION ON INGREDIENTS
Name EC No. CAS-No. Content Classification
REGULAR KEROSENE 60-100%
OLEYL HYDROXYETHYL IMIDAZOLINE 0-1%
OLEOYL SARCOSINE 0-1%
__________________
pm
Morocco!
South Africa!
Greece Fall 2013
'00 K1200LTC
'90 K75
  #16
Old Mar 27th, 2010, 6:27 pm
dglenn1's Avatar
dglenn1 dglenn1 is offline
Just tried this mixture on my grill. I have a ceramic grill similar to the Big Green Egg and the top vent adjustment runs with a threaded rod through a nut. I found mine rusted solid together last week. Many other owners with this problem have severely damaged their grills trying to get these two to break free from each other.
I had just read this forum post so I mixed the Acetone and ATF up and applied it liberally with a toothbrush to both sides of the nut. It soaked for about 10 minutes and came loose with firm twist.
Not very scientific as to it being the "best" solution, but it certainly worked in my case. I've ordered a back issue to read the full article just out of curiosity. Thanks for posting and thought you would like to hear from someone who tried it.
  #17
Old Mar 27th, 2010, 11:28 pm
saddleman's Avatar
saddleman saddleman is online now
As fast as acetone evaporates I would assume you would only mix just what you need each time to get the full effect?.
__________________
Dave
2004 Black LT
2000 Canon Red LT
You may not post new threads
You may not post replies
Forum Jump
Anyone use quick release fasteners?? oxbowfarm38 K1200LT 9 Apr 27th, 2010 1:10 pm
Frozen Carburetor robasay Humor 0 Dec 10th, 2009 8:44 pm
Dual lock fasteners retiredjj Bike Talk 7 Apr 22nd, 2008 1:13 pm
replacement fasteners sheldan2 K1200LT 2 May 19th, 2006 2:25 pm
Posts frozen? RMoore007 BMWLT Site Support Forum 1 Feb 17th, 2006 2:34 pm
