Mirror issues R1200RT and K1200LT - BMW Luxury Touring Community
Thread Tools Display Modes
  #1
Old Jan 30th, 2006, 12:56 pm
unicornadventures's Avatar
unicornadventures unicornadventures is offline
Here is a little trick I have applied to my R1200RT (works the same on the K1200LT).
It could happen that you hit the outside of a mirror during your ride or while moving the bike around.
A very smart guy at BMW came out with a fantastic idea!
Read more here
Old Dec 10th, 2006, 9:34 pm
roadcrave's Avatar
roadcrave roadcrave is offline
Gold Supporter
Mirrors
Another tip to prevent mirror damage, remove mirrors, drill 4 holes two at each end, one on each side of the holding pins that the ball pushes into, then install a small wire tie pulling the holding pins together, now you mirror will take allot more force to remove and no more mirrors coming off when hitting pot holes..matthew
  #3
Old Dec 17th, 2006, 7:26 am
ben1364 ben1364 is offline
Read more here
I have no first hand knowlege of the K LT mirrors but a 12" plastic wire tie works great on the R1200RT mirror and costs only a few cents. No drilling is required.
  #4
Old Dec 17th, 2006, 8:00 am
dshealey's Avatar
dshealey dshealey is offline
Read more here
What is new about that? We have been tethering LT mirrors since right after the LT came out. Some use plastic wire ties, others, like myself, use a loop of nylon covered stainless steel fishing leader.
__________________
I don't want to achieve immortality through my work...I want to achieve it through not dying.
David Shealey
Dandridge, TN
EX: '01 Black LT, BAT BYKE (Totaled at 110,000 miles)
IBA SS, BB, BBG, 10/10ths.
No bike now, but maybe in the future.
  #5
Old Dec 17th, 2006, 10:06 am
Dick's Avatar
Dick Dick is offline
Steve Shreeve (katnapinn) smacked a deer in the head with his right side mirror yesterday --- broke the mirror casing AND the heavy duty, thick, plastic tie that he had used as a tether. This isn't the first time we've heard of those thangs snapping and failing to perform as a tether. Much better solution is the coated and braided steel leader line as David Shealey described. Ole Toad's mirror(s) have been knocked off several times in the last 6 years and the leader tether is still in place. jm3cw.
__________________
Cheers
Dick
Boerne, TXican
You may not post new threads
You may not post replies
Forum Jump
k1200 LT v r1200RT bikesnumbnuts K1200LT 31 Nov 1st, 2005 10:06 pm
