Bleeding brakes K1200LT - BMW Luxury Touring Community
Thread Tools Display Modes
  #1
Old May 5th, 2008, 7:59 am
Caveno Caveno is offline
Hi - I have a 2002 K1200LT.
I went to change the front brake pads and when I split the caliper apart to remove it from the front wheel, some brake fluid leaked out. I attempted to bleed the brakes from the valve under the seat but my front brakes still don't work, though they are not as spongy as they were. Also, my brake light and the engine warning light's are on. I dug myself into a whole here.
On some of the forums they mention another reservoir under the seat, but I don't see it, I just see the one for the back brakes. I have two reservoir's on the handlebar for the front breaks and I made sure those are full and no air went into the brake line from the master cylinders.
Thanks a lot.
Old May 5th, 2008, 10:06 am
jzeiler's Avatar
jzeiler jzeiler is offline
Re: Bleeding brakes K1200LT
First off never split the calipers. You can remove them by forcing the pistons back and they will then slide off. But you don't even need to remove them to replace the pads as they come out the back side of the calipers. Ok now to the fix.
The front brakes are fed from one of the two chambers in the rear reservoir. It is just behind the right saddle bag. There are two fill caps, one for each chamber.
The front reservoir does not feed the front brakes, it is just the control circuit that provides an input to the ABS unit.
Fill the rear reservoir and run a hose from the front caliper back to the rear reservoir. Open the bleed valve and turn on the key and hit the front brake lever. It will pump from the reservoir to the caliper and via the hose back to the reservoir. Once all the bubbles are gone you should be OK.
The flashing lights will go out after the roll test if you have fixed your problem.
__________________
2009 R1200GS
2005 Ocean Blue Blue Wizard
2006 Bushtec Turbo+2 Spell
2004 330 Ci Convertable
K4AN
CCR 06 Braselton CCR 07 Osage Beach CCR 08 Midway
CCR 09 Rapid City CCR 10 Killington, VT,CCR 11 Boise, CCR 12 Duluth
CCR 2013 Bend, CCR 2014 Backyard!
  #3
Old May 5th, 2008, 10:07 am
vernvernvern's Avatar
vernvernvern vernvernvern is offline
Thumbs up Re: Bleeding brakes K1200LT
You didn't need to remove the caliper to replace the pads.
However, since you have a leak near the pads , I'd say you'll need a new kit to replace seals in the caliper. That might be a good mechanics job if you aren't comfortable doing it.
Just my .02 cents worth.
By the way..........good safe brakes are important to me!
__________________
4/10/2013 80,685 Silver '02LT now on 11/4/2013 it has 101,887 miles on the clock. This bike replaced the '03LT that I chose not to repair the engine in that had 150,000 miles on it. I will slowly list a few items from it on Ebay when I find/make the time to do it.
73 years young!
04 Honda Reflex.....Hers (it mostly sits)
Converted HD rider.
Love this bike and still waiting for my first speeding ticket. LOL
Vern
  #4
Old May 5th, 2008, 10:39 am
Thanks a lot for your help.
I don't see the rear reservoir, I only see the one for the rear brakes which is under the seat on the back right side, is that what you're talking about?
Thanks.
  #5
Old May 5th, 2008, 11:42 am
BecketMa's Avatar
BecketMa BecketMa is offline
On the 99 and 00, the front brake has the reservoir on the handle bars.
__________________
"He was a foul caricature of himself, a man with no soul, no inner convictions, with the integrity of a hyena, and the style of a poison toad." H. S. Thompson
  #6
Old May 5th, 2008, 11:51 am
BecketMa's Avatar
Here you go:
http://www.bmwlt.com/forums/showthread.php?t=35420
__________________
  #7
Old May 5th, 2008, 12:45 pm
This is a 2002 LT w the servo assist system.
  #8
Old May 5th, 2008, 2:40 pm
jzeiler's Avatar
The one under the seat is correct. There are two chambers, one feeds the rear wheel and control circuit and one feeds the front wheel circuit. there are two fill caps and two level sensors. You may have to undo the right side battery cover body work (two screws at the front of the saddle bag when opened) to gain access to both chambers. The front wheel circuit is the chamber to the rear (hardest to get to).
This should help.
__________________
2009 R1200GS
K4AN
You may not post new threads
You may not post replies
Forum Jump
Bleeding brakes on 2002 LT fdgibbons K1200LT 10 Oct 2nd, 2006 9:35 pm
Bleeding Brakes on the Big K markbreen K1200LT 3 Jan 18th, 2006 3:41 am
Bleeding Brakes Colin1952 K1200LT 8 Jan 17th, 2006 2:06 pm
