What Type Coolant? - BMW Luxury Touring Community
Thread Tools Display Modes
  #1
Old Jun 11th, 2007, 12:11 am
dwillie's Avatar
dwillie dwillie is offline
What Type Coolant?
I have the LT stripped down and was hoping to change the coolant out tomorrow(Monday). I didn't think ahead fast enough and wouldn't you know, my nearest dealer can't get the BMW brand until end of the week. Are there any other brands anyone would suggest? Could I find an appropriate type at the local auto store? Anything to look for or avoid? Thanks for the help. d.
Old Jun 11th, 2007, 7:46 am
was's Avatar
was was is offline
You can use a non-BMW coolant available at auto parts stores. You want to find one that has ethylene glycol based antifreeze and no nitrates or phosphates. 50:50 water to antifreeze ratio; you can mix your own (but make sure that you use distilled water, not tap water) or buy the premix. The BMW coolant contains ethylene glycol, diethylene glycol, sebacic acid, sodium hydroxide, 2-ethylhexanoic acid, corrosion inhibitors, defoamers, silicates, and dyes, so don't worry if these are listed as components of a non-BMW product. If you are flushing the system you will need 3.93 qts for the radiator, coolant circuit, and reserve tank. Massaging that lower hose between the radiators will help burp out air bubbles. HTH.
__________________
Bill
Guilford, CT
'99 Canyon Red K1200 LT - Buddah Bike
  #3
Old Jun 11th, 2007, 9:36 am
tbarstow's Avatar
tbarstow tbarstow is offline
What Type Coolant?
Search for the post about coolant from 2 weeks ago, I believe that the coolant for the HD V-Rod meets the BMW specs.
__________________
Tim Barstow
2004 GSA Silver
2007 X Challenge
  #4
Old Jun 11th, 2007, 9:38 am
Sunderland Sunderland is offline
I believe you can find the same type of antifreeze at a BMW or Mercedes auto dealer.
  #5
Old Jun 11th, 2007, 2:48 pm
EncoreJoe EncoreJoe is offline
Yes, I made a special trip to the Gulf Coast BMW motorcycle dealer to get the OEM stuff for my first anti-freeze change.
The coolant is BMW branded automotive coolant. I passed several Houston area BMW automotive dealers on my way through rush hour traffic on the way to the cycle dealer.
Live and learn!
Joe
__________________
EncoreJoe
"Ride, boldly ride, ... If you seek for Eldorado!"
'10 Triumph Tiger 1050
  #6
Old Jun 11th, 2007, 3:54 pm
dwillie's Avatar
Thanks much for the respones. My dealer was out of the BMW brand, and would have to order it. I found a branded product that fit the bill perfectly at a local Mercedes/Volvo dealer. (Off the immediate subject here but); I'm really enjoying the Paul Sayegh maintainece videos. Very easy to understand for an intermediate mechanic like myself. I highly recomend the video to anyone who works by themselves and needs a little help. dwillie.
You may not post new threads
You may not post replies
Forum Jump
Possible coolant leak into the oil RealWing K1200LT 52 Feb 20th, 2007 11:58 am
Oil Type chris1951 K1200LT 12 Aug 22nd, 2006 9:53 pm
Renewing engine coolant DavidPaul K1200LT 4 Aug 14th, 2006 8:16 pm
Should I add coolant? flyby K1200LT 5 Jun 19th, 2006 8:25 am
Coolant loss Q Rondeau K1200LT 1 Oct 24th, 2005 11:17 am
